| Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here. |
I was wondering if someone could help me figure out what is wrong with this file I made it in corel then saved as dxf and when I try to make a toolpath in vcarve it gets all messed up I think there might be hidden nodes or something that I can't find. I am making a sign for a doghouse will put dogs name in middle. thank you Rob |
| It may be that those segments are splines and the software imported to(V-Carve) cannot handle/convert them as simple lines and arcs? I have never used V-carve, so I cannot say for certain. DC
__________________ Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade. |
| One of Many is correct - the two shapes you have in your DXF are splines and few CAM packages recognize splines. The thing to do is open it in ACAD and save it as a R-12 DXF. I did this for you but the file is too large to post. I can E-mail it if you would like. Doing this will take a spline and convert it to a polyline which all CAM packages will recognize and process. I learned this trick from GER21 on this forum, by the way. Scott
__________________ Consistency is a good thing....unless you're consistently an idiot. |
| Hi Rob, Glad to see you managed to find a work around with the DXF file - Thanks mxtras. We recommend that Corel Draw designs should be Exported as either EPS or AI version 7 or older. These file formats will retain any smooth bezier geometry that exists and generally give better results. I hope this helps for the future, Tony |
| CAD file to CNC | sc351cobra | General CAM Discussion | 0 | 12-18-2006 03:07 PM |
| Need help with a dwg file | Kuhlmann75 | General CAM Discussion | 8 | 10-10-2006 08:11 PM |
| php file | larry53 | Forum Questions or Problems | 1 | 09-14-2005 10:26 AM |
| .PSC file? | boomer187um | Autodesk Software (Autocad, Inventor etc) | 0 | 08-29-2005 10:15 PM |
| Anyone want to help me with a file? | nervis1 | Mastercam | 19 | 05-12-2005 05:06 PM |
