Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 03-04-2007, 01:22 AM
andrew_g is on a distinguished road
VISTA - AutoCAD 2007
Got a new lap top with vista, went to load AutoCAD - its not happy - not compatible.
Looked at the AutoCAD site - seems the problem is being addresses, but not fix at the moment. Anybody have any ideas on a time frame?
Anybody had the same issues or problems?
Old 03-04-2007, 08:33 AM
ger21's Avatar
Did you read through the support group? Guesses seemed to think 1-3 months for a patch.
Found a few tips.
After installing, right click the launch icon and choose properties. On
the Compatibility tab set compatibility to WinXP SP2 and turn on 'Run
as Administrator'.
Old 05-22-2007, 09:15 PM
Hand_UP is on a distinguished road
Autocad and Vista with a Router
I have been using Autocad for 20 years now and never have been this dissapointed in both Microsoft and Autodesk for not being prepared for this.
I have had to cope with the combo at work and productivity has gone down for me. None the less, once you run the program with compatability mode to WinXP and run it with administrator setting, it runs with but only 5 or 6 crashes a day. . . :?
The speed of my new 'Vista' compatable computer makes up for that and now i really know how to use the Recover Drawing pallette.
If you are going thru a network... be ready to wait, and wait, and wait! Solution: once the waiting begins (you will know when that is by the way) just unplug the ethernet cable from your computer. Autocad wakes up immediately for me every time! Plug back in and let windows do its thing.
An update sure would have been handy considering all the $$$ they (Autodesk) make with having to upgrade every release or pay more $$$.
Good luck.
Old 05-23-2007, 06:25 AM
ger21's Avatar
There is a new version of AutoCAD that works with Vista....2008
Old 07-02-2007, 12:03 PM
grizzly98 is on a distinguished road
Angry Autocad Vista compatability
As far as I am able to discover the only version of Autocad thats compatable with Vista is 2008 - BUT - it's not compatable with Vista 64 bit - I know I've got the useless op system!
Old 09-06-2007, 08:07 PM
cutter is on a distinguished road
grizzly 98, I am using Inventor 2008 And Mechanical, with Vista x64 Ultimate. It likes it better than it did on xp 32 bit.
MS Vista? prototect Mach Software (ArtSoft software) 1 02-24-2007 04:31 PM
Vista and Mach??? ifttinker Mach Software (ArtSoft software) 6 02-19-2007 02:58 PM
Here it comes...Windows Vista... fatal-exception Mach Mill 2 02-08-2007 09:56 PM
Autocad 2007 *.dxf to Mastercam 8 premierpatterns Mastercam 4 12-03-2006 12:41 PM
