Results 1 to 5 of 5
Thread: autocad
    Oct 2006
    Norway
    autocad
    hello!
    I'm about to start making a cnc machine.
    Can I get AutoCad to work with my cnc machine?
    Can anyone describe what i should do to make this work?
    Is there a add-on or something that make autocad work with cnc machines?
    Please tell me a bit. I'm kinda newbie
    Jun 2006
    What you need is software (cad/cam) to make g-code from your acad. drawings. Somthing like BobCAD or MasterCAD etc.
    Registered Karl_T's Avatar
    Mar 2004
    Dassel,MN,USA
    auto-cad is for design of parts. You need another step to make code that your machine runs to actually make the parts. There are many options and expense levels for this, commonly called CAM software.
    Start cheap. First learn a bit about hand coding your machine, also called G-code. There's a free ($75 to purchase) trial program you can find on this NG called NcPlot. It will convert from auto-cad to G-code.
    Karl
    Mar 2003
    Shelby Twp, MI....USA
    If you're using 2002 or newer, you can use the free macro I wrote that will export g-code from within AutoCAD.
    AutoCAD 2 G-Code macro
    Moderator CNCRob's Avatar
    Feb 2005
    you could also consider SheetCam. www.sheetcam.com
    Robbie
  • Posting Permissions
