Results 1 to 3 of 3
Thread: Points on arcs
    Nov 2004
    Points on arcs
    When I get files from some of my customers in DXF format I open them in Auctocad. On the arcs I have hundreds of points. When I bring the file into Mach 3 it takes forever and the gcode file is huge and the router never gets to the feed rate that I set. How do I reduce them?
    Gary
    Oct 2003
    If you're sure all the points are on the same arc, can't you just create a new three-point arc using the first point, last point, and one of the other points? Then you could erase all the old arc geometry.
    Software For Metalworking
    http://closetolerancesoftware.com
    Mar 2003
    Shelby Twp, MI....USA
    Quote Originally Posted by mrainey
    That's what I'd do. Hopefully you don't have to deal with hundreds of arcs.
