Results 1 to 6 of 6
Thread: AutoCAD to Mach 3
    Feb 2006
    AutoCAD to Mach 3
    I am using AutoCAD 2000 for my designs and exporting them as DXF files to import into Mach 3. I am somewhat green on AutoCAD. How can I save (or export) just a single layer as a DXF file? Also, I would like to use the text function for some engraving. When exported to Mach 3 it does not show up. Any help would be appreciated.
    Vince
    Mar 2003
    Shelby Twp, MI....USA
    Copy what you want and paste it into a new drawing and save that as your .dxf
    Unless you have Express Tools, you can't use the native text. You might want to try this, it's cheap. http://www.freefirestudio.com/outline.htm
    Feb 2006
    Hey as to the text, check out the text wizard that comes with Mach3. I works real well.
    Evan Brainard
    Windmere Design
    Autodesk Inventor Consultant
    windmeredes@comcast.net
    Feb 2006
    I did not realize that was in Mach 3, thanks for the heads up.
    Vince
    Gold Member mxtras's Avatar
    May 2005
    Or - on the command line, type 'dxfout'. In the dialog box, go to options and click the box next to "select objects". Name the file, select the entities you want and you just wrote a DXF without interrupting your drawing.
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Feb 2005
    I tried using that macro in autocad but everytime I do I get a runtime error? I have drawn up about 20 circles to cut in autocad and it does cut them in mach 3 but I am still having problems with it cutting all the OD first but I need the ID or there is just no way to cut them with out the circles flying off the machine. Do you think Simple CNC for $35 would be better?
  • Posting Permissions
