Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 11-14-2003, 08:38 AM
wjbzone's Avatar
wjbzone is on a distinguished road
Gcodein - lisp program to read cnc files into autocad
This is a link to a zip file that contains gcodein.fas and a readme.txt file.
You can use it to read a cnc mill file into Autocad. I also have a lathe version I will post on my website later.
intergate.com/~wjb1/wjbzone/autocad/gcodein.zip
Bill
Old 11-14-2003, 08:53 AM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
What does that do?
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 11-14-2003, 09:00 AM
wjbzone's Avatar
You can read a cnc gcode file into an Autocad layer.
1. Launch your Autocad application.
2. Use appload to load the gcodein.fas.
3. Type gcodein at the Autocad command line.
4. Browse locate your cnc gcode file.
The cnc file is read into the current Autocad layer as lines and arcs.
You can step one line at a time or set the number of lines to step.
I use to verify my code before I run it on my machine.
Bill
Old 11-14-2003, 09:03 AM
CNCadmin's Avatar
Site Owner
OK, thanks I understand now.
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 11-14-2003, 04:43 PM
ger21's Avatar
It would be nice if the step number stayed the same so you could just hit enter or right click to step through, right now I had to type the step amount each time. Other than that, it seems to work pretty good.
Old 11-14-2003, 10:13 PM
wjbzone's Avatar
"It would be nice if the step number stayed the same so you could just hit enter..."
Gerry,
That's the way it works. At each pause in execution, the default step number is displayed at the beginning of the command line.
i.e.
if the default is 1 the command line reads:
"1 Enter Step Increment (0 to Continue)"
if the default is 20 the command line reads:
"20 Enter Step Increment (0 to Continue)"
The number at the beginning of the line (the 1 or the 20 shown above) is the default number of steps if you just hit the enter key.
The only time you should have to type a number is when you want to change the default (can be any positive number).
Type a 0 (zero) to run without a pause.
Let me know that is not working for you.
I'll try to make that more obvious in next revision.
Bill
Old 11-15-2003, 07:18 AM
ger21's Avatar
My mistake, it does seem to work properly. One thing I noticed with code generated from MeshCAM, It crashed if the first move was:
G1 Z0.00 F10.00
I'm guessing it didn't have a place to start with just the Z-value in the first line.
Old 11-15-2003, 09:25 AM
wjbzone's Avatar
You got me on that one. Looks like a G0 or G1 with a zero move at the start of the program is a problem. I'll get that fixed as soon as I have a chance. Got to to some painting first today.
Will post again as soon as it's fixed.
Bill
Old 11-18-2003, 07:12 AM
wjbzone's Avatar
I got the program updated. Fixed the problem with the first move.
The link on the first post of this thread is the current version.
Bill
Old 11-18-2003, 08:32 AM
mrainey is on a distinguished road
Can you use this with AutoCAD 14 and if so, how? I've never run across a .fas file before.
  #11   Ban this user!
Old 11-18-2003, 10:18 AM
wjbzone's Avatar
Sorry mrainey,
I don't believe a .fas file can be read into Autocad 14. The lisp routine uses several visual lisp functions. These are supported by Autocad 2000 and above.
Bill
  #12   Ban this user!
Old 11-20-2003, 09:18 AM
wjbzone's Avatar
Another update to the gcodein program has been posted. I also put the lathe version (gcodeinL) on my website. (in the Autocad section)
Bill
Learning to Program CNC Turning Center Farmer G-Code Programing 13 09-12-2005 12:03 AM
Autocad user has newbie SW/CNC questions cadesignr Solidworks 7 02-11-2005 01:19 PM
solid works cnc files krustykrab Mastercam 38 06-19-2004 09:53 AM
New CNC Controller Program for DOS manfong Product Announcements & Manufacturer News 10 10-10-2003 11:30 AM
MDT flow wires to program cnc 3d wjbzone Autodesk Software (Autocad, Inventor etc) 1 06-24-2003 07:59 AM
