Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 03-14-2006, 06:46 PM
ger21's Avatar
Polyline Circles
Does anyone need to have circles drawn as segmented polylines? Someone on the Mach3 Yahoo group wanted a way to do it, so I wrote this quick macro to do it. It doesn't convert circles, it will draw them as polylines.
If you wish to make a toolbar button for it, enter the following for
the button macro:
^C^C-vbarun PLCircle.dvb!PLCircle.PLCircle
The macro itself must be located in a folder in the support file
search path for the button to work.
Old 04-27-2006, 06:07 PM
JoelDirn is on a distinguished road
You should be able to do the same thing with the command "donut".
Just give it the same inside & outside diameter.
- Joel -
Old 04-27-2006, 06:18 PM
ger21's Avatar
Not exactly the same. The macro draws a "circle" made of of many short, straight segments. The donut command uses a polyline made up of 2 arc segments.
Thanks for the tip, though.
Old 07-10-2006, 11:19 PM
gharpe is on a distinguished road
you could use the polygon command with many sides. Is it a circle composed of straight line segments?
Old 07-11-2006, 05:27 AM
ger21's Avatar
Another good tip. Thanks. So many ways to do things in AutoCAD, it's hard to think of them all.
Old 10-18-2006, 01:49 PM
Uncle Buck is on a distinguished road
why would you want it as polylines?
for machining, i find it more of a pain...
bigger file sizes too
Old 09-13-2008, 10:10 PM
ger21's Avatar
I needed a quick way to draw a circle made up of multiple arcs, so modified the original macro here into this new one. Just tell it how many segments you want, and you'll get a circle composed of a single polyline containing that # of arc segments.
Old 09-15-2008, 10:53 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
Handy that!
Incidentaly, you can make a text file of X and Z values, rename it with an SCR extension and type SCRIPT in AutoCAD and it'll import all the X and Z values straight into your drawing. You need to have PLINE as the first line in the file though.
I found this dead handy for importing exactly what you are doing, except my little lines were for elipses and aspheres. I had to EXPLODE the Polyline to make all the little lines.
So the SCR file format would be:
PLINE
15.0000,02.881022
15.0010,02.881022
etc
I love deadlines- I like the whooshing sound they make as they fly by.
