Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 12-17-2005, 03:59 PM
Sanghera is on a distinguished road
Autocad Scale function
I have a vector outline of an object, but I need to scale it to an exact size. I can use the scale feature on Autocad, but it seems like I would have to guess at the actual size of the object. I can scale by a factor of 2 or 3, but when you need to scale to a certain size how do you do that?
Thanks.
Old 12-17-2005, 04:11 PM
Al_The_Man's Avatar
You can use reference length, you pick a ref. length on the object and then enter what length it should be. I think this is what you want?
Old 12-17-2005, 07:52 PM
yup, after I posted this I figured that out. Woops sorry.
Thanks.
Old 12-17-2005, 08:32 PM
How exactly do you scale in just one direction? I can use scale to scale uniformly in all axes, however if the object only need to be scales in the y direction, how is that done?
Thanks.
Old 12-17-2005, 09:49 PM
ger21's Avatar
Use the block command. Make it a block, then insert a reference of it. You can scale the block in one direction when inserting. Once inserted and scaled, explode it and you should have what you want.
Old 12-18-2005, 01:05 AM
Thanks Gerry, and Al.
Thanks.
