Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 02-10-2012, 07:56 AM
mattfurches is on a distinguished road
Another spline question
In inventor 2012 I have a ahape that needs to be created using a spline. However when I import the 3d model into mastercam it sees the spline as lines instead of arcs. Is there any simple way to convert the spline into an arc in inventor before i export the model?
Old 02-14-2012, 12:23 PM
jeff 888 is on a distinguished road
How are you doing the import into mastercam? Are you just opening the inventor file or are you saving to a step/ iges first?
Old 02-14-2012, 12:47 PM
i was just opening the ipt file
Old 02-15-2012, 09:07 AM
You could try exporting the part file to a step and trying to import it that way. I know for me I have had a number of issues with splines importing and have since learned how to draw them in mastercam.
Or if the model is one that will be 2.5d machined then you could save it as a dxf and import that.
Help with Spline jesuscowboy General Metal Working Machines 5 10-04-2010 03:38 PM
Spline question and looking for help to build turboless General Metalwork Discussion 5 05-22-2009 01:57 PM
Need A Quote- Take a look spline job turboless Employment Opportunity 0 05-21-2009 10:04 PM
spline help,mc9.1 GRANDPA Mastercam 10 03-10-2007 06:00 AM
Spline scottsss Autodesk Software (Autocad, Inventor etc) 13 07-14-2003 10:30 PM
