Results 1 to 4 of 4
Thread: Saving DXF that Xilog plus will understand
    Jan 2012
    Espaņa
    Hi guys,
    I am in the process of "inheriting" a SCM tech machining center for wood. The previous owner is quite set in his ways and only knows one method for each thing he does with the machine.
    In order to get the machine to do text, the process we use is to write the text in autocad, explode it, descomp (maybe not the right translation, sorry, my autocad is in Spanish), erase the extra lines created, and then create a contour using polyline. Save as R12 DXF, and then open it in xilog plus.
    The problem is that I want to be able to export vector graphics from illustrator and get xilog plus to understand them. Attached is an example of a little pig I created by taking a photo, using live trace in illustrator and saving to DXF.
    Autocad opens the pig just fine, but won't create a contour, because it says there is no valid area to make a contour, or any number of errors. I have tried creating regions, using a spline to pline lisp, and everything I can think of, with no success. Xilog plus says "Exception bla bla, file is empty".
    I am at the end of my wits, any suggestions/help/alternative processes will make me extremely happy.
    Additional notes/data:
    - I am using illustrator CS5, which does not have R12 DXF among its export options, I have either R13, R14, 2000, 2004/2005/2006. I have tried various options.
    - Autocad I'm using is 2007
    - Xilog plus, as far as I have experienced, only understands R12 DXF.
    Thanks a lot guys!
    Attached Files Attached Files
    Feb 2012
    Brasil
    Test AutoCad 2000 and save as how AutoCad2000.dxf and close before open in the xilog.
    Sorry my english, but i dont speak. Only Portuguese and Italian
    Jan 2012
    Espaņa
    muito obrigado! I will try DXF2000 :-)
    Registered ward83's Avatar
    Feb 2013
    palestine
    hi can any one help me i need xilog plus ??
  1. Record 110 and Xilog Plus
    By YorkyJD in forum CNC Machining Centers
    Last Post: 03-01-2012, 12:45 PM
  2. scm tech 80 (xilog)
    By lallijon in forum G-Code Programing
    Last Post: 08-01-2011, 05:53 PM
  3. Xilog Post
    By junglist in forum EnRoute
    Last Post: 06-17-2011, 12:04 AM
  4. Need Help!- XILOG softweare
    By Damir_Coma in forum CNC-Zone
    Last Post: 04-03-2011, 05:01 AM
  5. Xilog+ and W7
    By Malgiliath in forum Commercial CNC Wood Routers
    Last Post: 10-24-2010, 04:04 PM
