Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 12-20-2011, 11:18 AM
Stampede is on a distinguished road
Constraining sketches.
I'm trying to constrain a circle to the origin, but it will not constrain. How I'm doing it is, I choose a circle, click the origin, type in the dimension. But it is still green. What do I need to do?
Thanks.
Old 01-09-2012, 06:01 PM
klhoard is on a distinguished road
(I'm assuming you're using Inventor)
Create your circle, then make two dimensions, clicking the **center** of the circle and the origin. Once the dimensions are created, change them to 0 and your circle will be constrained to the origin.
Old 01-10-2012, 12:17 AM
legendboy is on a distinguished road
you can also draw your circle center point on the orgin, select the center point and click the lock icon in the constraints menu
Need Help!- Derived Sketches - How does one...... Aquatic Solidworks 10 03-13-2011 03:47 PM
