Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 11-26-2011, 12:00 AM
jimmyjames1981 is on a distinguished road
Autodesk inventor professional to cnc router?? Need help :(
Ok, here goes, i have Autodesk inventor 7 professional and have about 100 drawings and am trying to figure out how cnc router services can use my drawings without redrawing them on theyre own software, this has been really costly for me. What formats do cnc routers usually use? And how can i convert dxf/dwg to those formats?
Old 11-26-2011, 01:27 AM
BurrMan is on a distinguished road
A cnc router will read "gcode". This is created by a CAm package that toolpaths your inventor geometry... Most CAM packages will read your dxf/dwg files in. If you are using a service, you will send them your drawing and they will toolpath it.
Old 11-26-2011, 06:57 AM
ger21's Avatar
Most router users should have no problems with .dxf, and I'd expect them to prefer .dxf.
As far as redrawing goes, you probably need to ask them why they need to redraw them and see if you can get them better quality files, if that's the issue.
I recently did a job cutting 25 sheets if plywood. They were large gear shaped parts for a theater set.
Some of the parts in the .dxf's I received consisted of over 2000 line segments. I was able to redraw them and get the segments down to the 150 range.
This reduced the run time by about 20 minutes per sheet, or about 8 hours.
Old 11-29-2011, 03:11 PM
Im not really sure why they cant open them either, i send them 3 different formats of dxf's and they say they cant open them, in 2004,2000 and R12 dxf format.... I can personally open them in solid works and autocad with no problems, maybe its not on my end but theyre end, maybe they use lousy programs.......
Old 11-29-2011, 04:12 PM
Get the 3d model out of it and send only 2d curves in the dxf format...
Old 11-29-2011, 04:17 PM
do you mean the isometric view i have in my drawings? So top, right, left and bottom views only?
Old 11-29-2011, 04:48 PM
So like this model here. Try open this in Inventor, then save the dxf and see if they can open it.
Old 11-30-2011, 02:43 AM
judleroy's Avatar
judleroy is on a distinguished road
Dxf files are no good for exporting 3d models. The first question is do you need a 3d model to cut the parts? They may just need a 2d profile if the parts are flat and have no 3d surfaces. If that's the case then dxf will work for 2d profiles. If you need the 3d geometry then use the export command. I believe it's under the file menu. Try .sat , .Iges , or .step and see if they can open those. Good luck.
Judleroy
Autodesk Inventor help coykiesaol General CAD Discussion 1 11-02-2010 08:39 AM
Mastercam and Autodesk Inventor Bartsimsonii Mastercam 0 11-23-2007 03:27 PM
AutoDesk Inventor jrotruck Solidworks 2 08-21-2007 11:07 PM
The power of Autodesk Inventor sanddrag General CAM Discussion 1 06-06-2006 09:08 AM
Any Autodesk Inventor 8 users here? Spinnetti General CAM Discussion 4 03-17-2004 06:05 AM
