| Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here. |
Hey guys, I'm in dire need of help here, I am quite new to CAD and have a pretty major problem. I have a file that i have asked a local machinie shop to laser for me, but they said there is problems with the file. First of all it was duplicate line issues, so i did LOTS of googling to research the 'overkill' tool This worked for the most part, but there seemed to be some lines it could not remove, i could not manually find these. So after more infestigation i THINK I found them and removed them, however now i am having issues with the machine not seeing lines. The company thinks its somthing to do with layers and lines being hidden, i honestly have no idea whats wrong ![]() Could someone please help me if i upload my file? (also how can i upload my file? Thank you in advance for help, i really need this! Craig |
| This may do what's require. I have rotated to the XY plane and moved to Z0. Check before machining! Edit. OK. I've omitted the cutouts......NOW corrected Last edited by Kiwi; 11-08-2011 at 09:16 PM. Reason: Edit..Added cutouts. |
ok a couple of things, and based on what we do . The cut will be in the "z" axis ( your view is in the Y so the laser only sees a layered line) Cut line are polylines to 2 dec places. ( this is more to do with "kerfing" of the corner radii but just plain good house keepin') Each cut is an individual "item" ( yours is a "block" ) This makes it easier to set the cut path, lead ins - out etc. Now the cut width is also an issue with laser, thicker material will not have a straight cut because of the focal point of the cut. might not apply to you in this job, but always ask what is the cut width ( say 1.6 mm rule of thumb) Regards Paul |
