Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 09-13-2011, 05:43 AM
jason25 is on a distinguished road
Parametric dimensions
hello, I am hoping someone can help with an Autocad problem I ran into.
I am working on what I thought was a easy project that is getting tricky...for me. What I have is a taper that just has charted dimensions. Everytime I get a new one, I have to redraw it to get the values for my CNC. I am trying to create a "template" so that I enter the variables from the print and all of my dimesions update. The part that I am stuck at is this: The green line is supposed to be offset at a given distance from the blue lines. I can get the vertical lines to be parallel, vertical, and at a given distance. I can also get the angled lines to be parallel, but how do I create the parametric constraint for the spacing?
Old 09-15-2011, 05:36 AM
any ideas?
Old 09-20-2011, 05:47 AM
figured it out - I needed to use aligned dimension and then type 2L for 2 lines. I kept missing typing 2L.
Need Help!- new to parametric programming dougdownunder Commercial CNC Wood Routers 1 04-24-2012 02:48 PM
Free Parametric 3D CAD av.vwyk General CAD Discussion 0 11-16-2010 07:56 AM
Need Help!- Parametric programing Wolf Pack Haas Lathes 2 04-30-2010 10:47 AM
Autodesk Parametric Jon83 Autodesk Software (Autocad, Inventor etc) 6 03-17-2010 05:43 AM
New to Parametric Programming weaston G-Code Programing 4 02-27-2007 07:40 AM
