Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 08-01-2011, 02:09 AM
geoff3881 is on a distinguished road
Unhappy Splines and areas with Auto CAD LT 2000i
When using AutoCAD LT 2000i I have areas which are enclosed by straight lines and splines.
When I use the area calculation feature it appears to join the end points of the spline with a straight line. I click on the spline end point as requested.
How do you make it input the spline form ?
Thanks,
Geoff
Old 08-01-2011, 08:25 AM
ger21's Avatar
Create a region from your spline and straight lines. Then use the object option of the area command and select the region.
Old 08-02-2011, 03:37 AM
Smile Splines Area AutoCAD
Hi Gerry,
Thanks for your help. It works fine !
I was not familiar with the "region" term.
Geoff
help with fields displaying objects' areas hownewsday General CAD Discussion 1 03-02-2011 08:41 AM
Boundaries - Tool contact areas mattpatt SolidCam 2 03-03-2010 06:14 PM
2000i or something better? kbillan General CAD Discussion 0 10-25-2008 11:00 AM
How to profile/contour and avoid areas? Shepard Mastercam 3 12-03-2007 05:11 PM
Adding extra work areas AcryNom General CNC (Mill and Lathe) Control Software (NC) 1 05-16-2007 01:13 PM
