Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 05-18-2011, 07:21 PM
bmx4637 is on a distinguished road
Cool Geometric patterns?
Hey all,
I did a search and couldn't find anything so I'm just going to ask you guys. Are you able to design geometric patterns (besides circles and squares) in AutoCAD. Such as the shape of a Rotor in a Wankel engine, or type in a formula that is a shape?
Thanks,
Alex
Old 05-18-2011, 10:19 PM
I often draw a single gear tooth then reproduce as many as I need in a complete gear, say 20 teeth. To do this, I use a polar array @ 18 degrees.
For a Wankel with three lobes, you could reproduce one lobe three times with a polar array @ 120 degrees.
Dick Z
DZASTR
Geometric dimensioning and tolerances tds11223 Mechanical Calculations/Engineering Design 2 06-04-2010 09:02 AM
TRW Geometric Threading Heads with Dies J-Mccoin 2009 EBAY ADS 1 11-05-2009 01:27 PM
Using a geometric die head on a lathe dkbgs General Metalwork Discussion 4 12-13-2008 05:15 PM
Taps & Dies - Geometric Threading - Tapping Heads - Gages widgitmaster General Metalwork Discussion 10 01-05-2007 07:34 PM
Geometric Tolerance BlueChip General CAM Discussion 9 11-02-2003 03:29 PM
