Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 08-21-2005, 09:46 AM
quammi is on a distinguished road
real basic question.
what is a dxf file? i mean, i know what a dwg file is, when i make designs i always save them as a dwg file. what is a dxf file, and what is it used for? i know I will behaving to work them soon, and i am CLUELESS to what they are.
Old 08-21-2005, 09:48 AM
Al_The_Man's Avatar
I am not sure of the origin, but it is a drawing exchange file, which allows other programs such as CadCam and Corel Draw etc to import the file and convert to what whatever the program uses.
Old 08-21-2005, 09:56 AM
ger21's Avatar
.dxf is just a different format of the drawing file. Autodesk documents it, so other CAD (and CAM) software can read .dxf's into their programs. There are different versions of .dxf, with newer ones supporting more types of entities. If you're saving them in AutoCAD for use with another program, generally v12 .dxf will give the best results.
Old 08-21-2005, 10:53 AM
so in short, if i save a drawing as a dxf file, on autocad, i can then use it with say, mastercam, to iniate tool paths? is that about right?
Old 08-21-2005, 11:16 AM
ObrienDave's Avatar
ObrienDave is on a distinguished road
Quammi,
Basically, you are correct.
If you created the drawing, and know it is geometrically correct, then you can use it.
If you got it from someone else, then you should check the part geometry to the
actual print values.
I have recieved DXF print files where someone thought it was easier to change the
print dimensions than it was to update the model or the print geometry.
NEVER assume anything.
ObrienDave. MasterCam since V6. Gcode since 1983.
Be careful, the nose you punch today may belong to the butt you have to kiss tomorrow.
Old 08-21-2005, 11:17 AM
Al_The_Man's Avatar
Basically yes, on any program that has 'Import DXF' as an option.
Old 08-21-2005, 03:28 PM
ger21's Avatar
Usually, but not necessarily. CAM programs usually prefer certain types of entities. For 2D .dxf's some prefer polylines, others don't. Still others don't care. For 3D, it can be even more complicated. It may take a little experimentation before you get the hang of what works best, but that is how it works.
