Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 03-17-2011, 05:00 PM
justin bowser is on a distinguished road
Any special tricks to make .dxf files convertable to G-Code?
I have just bought a small three axis router/engraver and am having some difficulties pulling .dxf files into various programs that are supposed to create G-code. When the file is pulled in the programs create no code and some say nothing is found to create code from!
Here's my scenario:
- I open ACad 205 and pull in a jpeg.
- I then create a second layer and make a tracing of an area of the jpeg using the spline tool.
- I save as a .dxf file
Do I need to somehow make this second layer a standalone single layer drawing? If so how is that accomplished as I can't delete the layer 0 even after deleting the jpeg from it.
Old 03-17-2011, 05:50 PM
Bubba's Avatar
Bubba is on a distinguished road
Justin,
First off, many cam programs are sensitive to the VERSION of the dxf file. Do your save as dialogue as no later than V14 DXF. I have seen some that even required V12.
Next, I have seen some that will not handle splines and need regular lines/arcs.
So you might need to explode the splines to allow execution.
Also, the cams I am aware of will not recognize "blocks" and need to be exploded.
Art
Old 03-17-2011, 05:51 PM
ger21's Avatar
You can't explode splines in AutoCAD to get a usable entity.
Most .dxf to g-code programs don't allow splines. Saving as a .v12 dxf will convert the splines to polylines, which should get you working. Another option is to download a lisp program to convert splines to polylines, like this.
Splines to Plines | Cadalyst
You may want to look at the AutoCAD macro that I wrote to create g-code from within AutoCAD.
The CNC Woodworker
Old 03-17-2011, 06:12 PM
Thanks to you both. I will save this as a V12 file and see what happens...
Old 03-18-2011, 04:54 AM
That seems to have done it!
Need Help!- IGS FILES AND G CODE vagelism22678 General CAM Discussion 1 08-17-2011 04:41 PM
G code and tap files geoff3881 G-Code Programing 1 01-01-2011 07:23 AM
Need Help!- Simple G-code to make, please help ): waxmund G-Code Programing 3 10-07-2010 07:29 AM
2 g code files Jaby SolidCam 0 12-17-2008 05:02 AM
