Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 03-16-2011, 10:16 AM
MychesterCNC is on a distinguished road
AutoCad or Aspire...?
Is anyone very familiar with both programs? I now have Aspire V.3 (full version, I paid for it) as well as AutoCad 2011. I'm not sure if it was overkill to buy both, but I have them now, and am just learning to use either and to learn CNC machining with a desktop unit.
Does anyone have a strong opinion on which I should concentrate my efforts on learning? Does one do all that the other does and more, or is one more of an industry standard than the other? Or are there strong advantages of one over the other? I dont have any actual jobs in mind, but I want to be able to make parts (hobby type things) with a desktop unit in both 2 and 3D at some point. Is one much easier to learn than the other...?
Any pointers or opinions from someone who is very familiar with both would be appreciated!
Thanks!
Old 03-16-2011, 11:20 AM
jhowelb is an unknown quantity at this point
From my experience, Autocad is a high end drafting cad package the is the source of more frustration than product. It requires a LOT of study and commitment to work with it.
Aspire, while presenting challenges, will draw most everything one might need and trace bitmaps and modify existing dxf's.
It will also provide you with the gcode to produce your carvings, patterns and 2.5d figures.
My vote goes to Aspire, and I also have both!
"Error of Opinion may be tolerated where Reason is left free to combat it." - Thomas Jefferson
Old 07-06-2011, 01:19 PM
Pplug's Avatar
Pplug is on a distinguished road
I've used both and I can definitely recommend Aspire. It should do almost everything that your router would need it to. The only limitation for aspire would be printing your plans out with all the title blocks and extra crap that autocad is known for.
Http://www.glenspeymillworks.com *Techno LC4896 - 2.2Kw Water Cooled Spindle | *Moving Table Mill from an Omis 3 CMM, 500Lb granite base, Hitachi router, Mach3
Help: Autocad 2000 (Autocad Error aborting) Holmes_ca Autodesk Software (Autocad, Inventor etc) 5 05-07-2010 08:07 AM
AutoCAD 2000 to AutoCAD LT 2010? 2kjettaguy Autodesk Software (Autocad, Inventor etc) 2 08-15-2009 09:33 AM
Aspire!!! cabnet636 Vectric 62 02-23-2009 11:15 AM
