| Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here. |
I am a die hard Autocad user. Tried others, but having spent the time learning Autocad, seems a waste to pick up anything else. Question for the Autocad users, what are you using for CAM. So far I have tried several, and found all of them required file conversion to IGES, STL, other, and results were miserable. Currently using Alphacam which will import a dwg file and read it as a solid. Work I am doing is complex curves, and making molds for producing them. The version of Alphacam (router) I use is limited in solid machining options, I could upgrade to the Mill version, I will require 4th axis eventually. WHat are you using? |
| Hi I use autocad 2012 and alphacam 7.5 (advanced router) I know what you mean transferring files it can be a nightmare. However if you draw in autocad type into the command line "igesexport" select the parts you want then import into alphacam you should not have problems but it puts everything on 1 layer. I draw some harder parts in autocad and the easy bits just in alphacam. Poly lines from autocad work better than splines, just convert with the PE command. Hope this helps |
| Hi Gerry On the older autocad i use "save as" AutocadR/12LT2DXF and it imports into alphacam ok (most of the time!) The import is standard on the alphacam advanced router , im not sure on other alphacam's - anyone wanting them changing to .ard for alphacam i could save it for them (providing 100's of people dont want it doing !!) cheers |
