| Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here. |
I'm trying to use Acad Batch Plot, I know how to use it but, I can't get it to actually print. It checks off like it has printed but it does'nt print. I have all the path right, I tried in on other people's machines and get the same result. What can it be? I'm on a network and am printing to a network printer.
__________________ Thank You, Paul G Site Owner-Webmaster- Administrator www.rfqwork.com www.cnczone.com www.welderzone.com |
| Can you print anything other than batch jobs? How about to a local printer with batch jobs? 'Rekd
__________________ Matt San Diego, Ca ___ o o o_ [l_,[_____], l---L - □lllllll□- ( )_) ( )_)--)_) (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
First off, what version of AC are you running? It took me ages to set up the utility to run project batches in 2002. Then after I thought I was through the hard part, it didn't work for the next project! Basically I gave up after my Co. bought "Print exec." which combines the billing dept. to the output of our plotters (not good )Before we started using that program I was looking into a download I found Here. Might help.. I can try to bring up my script for batch plotting tommorow in work if you like. Here's another APP I just found Hurricane |
| I'm using 2002 and thank you I would love to try your script.
| I use the W2k command window to copy the plot files to the network printer. (start-run-cmd) change to drive and directory where plot files are located. determine your printers network path: mine is \\server1\engineering pcl use the dos command: copy *.plt "\\server1\engineering pcl" Bill |
| I found the problem, I was picking the printer NOT the PC3 file. It needs the pc3 file to print not the printer path.
| NC Plot v2 Beta 5 | MetLHead | NCPlot G-Code editor / backplotter | 3 | 09-14-2008 04:20 PM |
| Boot disk for EZ-Track DX, batch file? | mmm2003 | Bridgeport and Hardinge Mills | 8 | 01-31-2007 11:47 AM |
| Batch plot? | CNCadmin | Autodesk Software (Autocad, Inventor etc) | 2 | 08-04-2004 07:52 AM |
