Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 07-29-2005, 08:06 AM
buscht's Avatar
buscht is on a distinguished road
Question Need help with Spline to DXF to Polyline
I'm having a problem that is confusing me and need some help.
I know that if I save an Autocad drawing with splines as a R12 DXF file, it will change the spline over to a polyline and then I can machine it.
The problem is that sometimes when I do this, the resulting line is not smooth anymore. It has thousands of little jagged steps.
I have done this before and gotten smooth lines so I'm thinking that there is a setting that I'm missing.
I tried adjusting the DXF export precision from 1 to 16, but never really got the results I wanted.
Any suggestions will be welcome.
THanks
Trent
Old 07-29-2005, 08:16 AM
ger21's Avatar
Do you mean like a stairstep effect?
Old 07-29-2005, 08:20 AM
buscht's Avatar
Yes, they are only about .001 to .002 in size.
Old 07-29-2005, 08:38 AM
ger21's Avatar
I haven't seen that. I thought it might be a system variable, but can't find one. If you can't figure it out, you could use the spline to polyline lisp from Cadalyst magazine. This is a new one. http://new.cadalyst.com/code/browsey...ullyear=2005#6
I've been using the one from December 2003.
Old 07-29-2005, 09:04 AM
buscht's Avatar
Thanks Gerry, that Lisp routine worked pretty well. I just had some minor end clean ups to do, but very easy.
Trent
Old 07-29-2005, 09:15 AM
ger21's Avatar
One thing I've noticed with it, is that sometimes it clips or extends the ends of the splines. It doesn't happen often, and it's usually a drwaing that I didn't do. It also converts 3D splines to 3D polylines. That's how I'm doing those MDF panels.
Old 07-29-2005, 09:30 AM
buscht's Avatar
Gerry, the Dec 2003 version clipped and and extended the splines. I tried the newer version and it worked alot better.
Old 07-29-2005, 09:43 AM
ger21's Avatar
Thanks. I'll try that one too.
