Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 01-13-2011, 07:58 AM
shovel74 is on a distinguished road
3D AutoCAD design for cnc router
I am new to cnc routing but have experience with AutCAD. I am interested in using a cnc router to cut out and rout pockets for a custom bass, but I'm not sure how to start the design. If I build a 3D model in AutoCAD, does it need to account for the thickness of the router bit or will it follow an outside or inside edge (how does it know which to use)?
Old 01-13-2011, 10:59 AM
ger21's Avatar
It depends on the CAM software you use.
Old 01-13-2011, 11:12 AM
Thanks for the reply, ger21. The wood shop I will use says it has Visual Mill to translate. Does this sound right?
Old 01-13-2011, 11:21 AM
ger21's Avatar
Model it actual size, and Visual Mill will take care of the rest.
You should ask them what file format the model needs to be in, and if they have any special requirements for the model.
Old 01-13-2011, 11:23 AM
Great! Thanks again for the information.
Help: Autocad 2000 (Autocad Error aborting) Holmes_ca Autodesk Software (Autocad, Inventor etc) 5 05-07-2010 08:07 AM
Newbie- Help with first router design please! =] MynamesKenny19 DIY-CNC Router Table Machines 15 02-11-2010 10:36 AM
Router design fnm Open Source CNC Machine Designs 7 02-08-2009 09:20 PM
My CNC Router Design CNC_Brent DIY-CNC Router Table Machines 1 02-19-2008 04:38 PM
my router design? shootingarts DIY-CNC Router Table Machines 8 08-29-2005 11:14 PM
