| Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here. |
Dear Sir, I have an autocad map that need to be imported in 3d max. so what I did is to export this map from autocad as a bitmap image. then import this map in 3d max ,the problem that its size is in pixels and I’ll be using Meters and Cm as measuring units. how can I have the same measures I had on Autocad. thanks. _________________________ http://www.rosettastonediscount4u.com/ |
| Well, you didn't really define what capacity you wanted to use your map in 3D Studio. You'd only save it as a BMP (or any other image format) if you were going to use it as a backdrop or a material applied to an object inside 3D Studio. As I suspect that's not the result you were after, you probably want to simply import your .dwg file from within 3D Studio (File>Import>dwg) and it will have all of the same units it did in Autocad. Hope that helps. |
| Newbie- How do I make CAD/CAM size match machined size? | RedCoder | Benchtop Machines | 5 | 12-07-2010 04:13 PM |
| Via shape/size and wire size. | Drools | PCB milling | 0 | 08-14-2009 09:47 AM |
| Drawing Size and Cut Size Differ - Plasma | ADucci | LinuxCNC (formerly EMC2) | 5 | 10-05-2007 04:52 AM |
| Drawing Size and Cut Size Differ - Plasma | ADucci | Mach Plasma / Laser | 0 | 10-04-2007 08:49 AM |
| X3 base size or minium bench size | kenrc | Benchtop Machines | 2 | 02-04-2007 06:50 AM |
