Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 10-26-2010, 10:57 AM
Patternboy is on a distinguished road
Autocad 2011-undo & redo zoom
Good day,
I would like to know if it's possible to cancelled the undo & redo command on the zoom command, when I do a undo command, all the zooming in and out will be taking in consideration when doing an undo command, can I stop this, all I want to undo is what I have draw in my drawing.
I hope you understand what I am asking.
Thank you for your help.
PatternBoy
Old 10-26-2010, 06:04 PM
ger21's Avatar
I don't believe so. Zooming is a command, and undo undoes the last command.
Old 10-27-2010, 08:27 PM
There is no option somewhere that will allow the undo just on the drawing part.
Thanks for the reply.
PatternBoy
Old 11-03-2010, 11:41 AM
Chalkbot is on a distinguished road
There is no option for that, but there is an option to group all your zoom and pan actions together as one for the purpose of undo.
For example, if you:
Draw a line
Zoom out
Pan
Pan
Zoom in
Draw a line
The first undo will be the last line you drew, the next one will undo all of the zooming and panning you did, a third undo would be the first line you drew.
To enable this style of undo, type ZOOMCTL and set the value to 16.
Hope that helps.
Old 11-04-2010, 07:20 AM
Hi Chalkbot
I have tried it and it's work, thanks. But I had to go into the options, Users preferences, Undo/ Redo and check the Combine Zoom and Pan commands, it did'nt work onthe command line, said unkown command.
PatternBoy
Newbie- Zoom graph while program running (18-T)? polarbeer Fanuc 0 07-19-2008 07:01 AM
Pan and Zoom Andre' B NCPlot G-Code editor / backplotter 1 12-07-2007 04:55 PM
Why surfcam doesn't have UNDO feature? qmas99 Surfcam 16 04-16-2007 08:45 PM
Really, only one undo! MikeA Mastercam 1 09-27-2003 09:23 AM
Zoom Turbine Mastercam 11 05-17-2003 05:33 PM
