| Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here. |
Hello, I've been using Auto CAD 2000, and I am able to draw in 2D , but if I am correct Ace Converter as well as other, dxf to g-code converters need all part drawn with Polylines, can I conver my circles and sqare lines ect.. to plines ?? I get the following, Command: pedit Select polyline or [Multiple]: Object selected is not a polyline Select polyline or [Multiple]: or do I have to re-draw my file ??? I tried to redraw but my circles look ok in CAD, but when I generate G-code with ACE I get.. what looks like and inverted arc, any help would be great !!! Thanks, |
| Try this site www.tahlcam.com they have a complete CAM plug-in for 2 1/2 D programming inside AutoCAD 2000 and 2002. It will create what you want from the circles you draw. I think you will like it. Cheers, Jim 883-1536 Tucson Last edited by CNCadmin; 07-08-2003 at 09:00 AM. |
| Circles can't be plines, all lines can be joined into plines. Make sure when your drawing that the object is on 0,0,0.
__________________ Thank You, Paul G Site Owner-Webmaster- Administrator www.rfqwork.com www.cnczone.com www.welderzone.com |
| Pedit will convert a line to a pline, if you just click on it first when you enter pedit. Boundary will take an enclosed area, delimitated by lines or arcs, and convert it into a single closed pline on the current layer. Very handy. Zeph |
| Isn't that quite expensive? Gerry
| well for the kind of stuff I'm doing, I can use the demo No Problem, Plus I did not have to learn anything new ( not that I mind but the ) *.dxf converter I was trying where not cutting it..... and I did not have the control that I have here. This lets me conver my current drawings ... ( dont have to redraw anything to Plines ) and go from *.dwg to Gcode in a few minutes ( not of this save to *.dxf then gcode ) I did run into a few problem but not sure if its my doing or the software.. (for now I make sure I have my part to right scale before I start. I will be cutting mostly airplain parts... ( Ribs, ect...) I would give the demo a try !!! Specially if you already know CAD, and want to cut you time to convert G-CODE in half, If my projects where to grow past the 1000 line demo, I would still buy it.. My main hobby is RC Flying .. not CNC (sorry guys) anything to get me back in the air..... Luis, |
| Is the demo time restricted, or just 1000 line?
| Converting jpeg. to dfx.file | tozlakes | CNC Plasma and Waterjet Machines | 16 | 12-23-2004 03:40 PM |
| Coping a object around a axis? | CNCadmin | OneCNC | 4 | 10-15-2004 07:17 AM |
| Rapid prototype CNC laser resin. (Stereolithography) | ynneb | CNCzone Club House | 3 | 04-25-2004 08:17 AM |
