| Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here. |
Could someone point me the way to draw the aluminum angle brackets used for skate bearings in Inventor? I started in sketch mode with an angle, did an offset, connected and trimmed to create an end view. I extruded this to the desired length. I could then create new sketches to drill the holes in the sides for the bearings. All fine. But I can not get the mounting hole through the center of the angle, much less the flat spot for the bolt. Seems like I need a new work plane or something. I’ve also tried to sketch the side view, extrude to the thickness of the aluminum, and then create the opposite side, but I really got lost here. Hope I’ve explained my self OK. I am using Inventor 9. Thank you, Steve |
| There is an area that shows all the extrusions and sketches you have done, in tree form. It also has a folder that you can expand which has the X/Y/Z work planes in it. When I want to drill a hole in a part, a tube for example - I choose a work-plane that is perpendicular to the part, then click on the Sketch button. This will give you a sketch workspace on that plane. Then just do your hole as normal.
__________________ (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452 |
Nikolas |
| Substitute for aluminum angle in jgro's plans? | ljoe1969 | JGRO Router Table Design | 11 | 10-10-2010 12:49 AM |
| Inventor users? | wjbzone | Autodesk Software (Autocad, Inventor etc) | 43 | 10-12-2006 01:28 PM |
| How strong? (Linear rails, aluminum structure) | WoodSnarfer | Mechanical Calculations/Engineering Design | 13 | 07-15-2005 11:29 AM |
| CNC Aluminum | studysession | General Metal Working Machines | 6 | 02-12-2005 09:39 AM |
| aluminum extrusion | georgebarr | DIY-CNC Router Table Machines | 19 | 11-04-2004 09:43 AM |
