Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 10-05-2010, 12:45 PM
Dale gribble is on a distinguished road
How to draw / model an epicycloidal curve in autocad or inventor
Hi, I slowly building a 4th axis for my router and one of the item's I'm looking to make is a roots blower. My problem is that i don't no how to draw epicycloidal curves in autocad or inventor. I found a formula here on wiki
http://en.wikipedia.org/wiki/Roots_type_supercharge
Any information on this matter would be gratefully received
Kind regards
Dale gribble
Old 10-06-2010, 06:45 AM
I managed to work out a method in inventor see uploaded pics. 1st pic is of the construction which is a copy of the wiki diagram, to create the epicycloidal curve i used a 3 point curve. I not 100% if it's a true epicycloidal curve but animates well in an inventor assembley.
ID:	116308   Click image for larger version
ID:	116309   Click image for larger version
Old 01-11-2011, 10:00 PM
PCFlyer is on a distinguished road
I had the same thought - no luck yet with Inventor. I found a routine for Solidworks that generates an epicycle. Need to convert to VBA to work in Inventor.
How's your blower coming?
PCFlyer
Old 01-12-2011, 12:43 PM
Hi, I'm have to re-design my rotary axis, need to change it from worm gear to a toothed belt drive and add taper roller bearing all round. Then I'll give the shape I've created in inventor a try.
Regards
Dale
AutoCAD & Inventor 2010 Shared Network Issue RoboFutbol Autodesk Software (Autocad, Inventor etc) 1 07-21-2010 10:02 AM
AutoCAD/Inventor LT wages Autodesk Software (Autocad, Inventor etc) 2 04-06-2009 11:35 PM
Draw TRUMPF TC5000R NC CODE IN AUTOCAD Hodge Post Processor Files 3 07-17-2008 07:37 AM
Need Help!- Autocad or Inventor with Excel RoutnAbout Autodesk Software (Autocad, Inventor etc) 2 06-14-2008 05:54 PM
Corel draw - autocad question laser! Sandor_nl Laser Engraving & Cutting Machines 3 02-26-2008 08:24 AM
