| Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here. |
I have a dfx file that is appox 48" x 48" I would like to change the scale to be 24" x 36" can this be done in auto cad ? thanks for your time ghostlx
__________________ http://www.pure-teck.com/home.html |
| The only way to scale different amounts in X and Y is to first make it a block, then insert a new block, scaled by .5in X and .75 in Y. Then explode the block. AutoCAD will only scale uniformly on regular entities.
Scale 48 x 48 by .75 = 36 x 36. Then in 3D rotate along one edge by 48.1897 degrees. ARCOS(24/36) Now project it to a flat surface, and the scaling is done.
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. Last edited by neilw20; 08-13-2010 at 04:34 PM. Reason: oops that should be 24/36. |
| ghostlx
| Need Help!- How can I convert .nc files into .nci files | AlphaD | Fanuc | 2 | 07-08-2009 01:45 PM |
| Problem- milling tools files, changing cutter sizes. | chaz6966 | BobCad-Cam | 4 | 02-26-2009 08:46 PM |
| Need Help!- Convert files to Inventor files. | bartL | Autodesk Software (Autocad, Inventor etc) | 7 | 02-03-2009 11:38 PM |
| Converting Illustrator files to Gcode files | acoop101 | General Metal Working Machines | 1 | 06-05-2008 03:53 PM |
| Changing imported files | cncuser1 | Mastercam | 3 | 04-11-2007 07:09 PM |
