Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 07-22-2010, 08:23 PM
horty24 is on a distinguished road
Jpeg to dxf minus splines
Hi everyone, new to this awsome site and also to the autocad world. Ive tried searching with no detailed luck. I want to know how to convert an image JPEG or BITMAP to DXF file without having splines. I have used the program inkscape which does a great job in tracing the image and converts then can save as a DXF but it leaves it will a million splines. I need the image to be converted to an image free of splines. I need it to be polylines and or arcs. Elipses are no good either. This is for an industrial laser cutter.
Any help would be greatly appreciated. I have done manual tracing but that takes forever. lol
Thanks everyone.
Old 07-22-2010, 09:25 PM
ger21's Avatar
If you have the file in AutoCAD, save it as a v12 .dxf file, then close it, and open the .dxf The splines should be gone.
Or, try using this v12 .dxf export plugin for Inkscape.
http://mydxf.blogspot.com/2008/11/inkscape-r12-dxf.html
Problem- No minus Z icecube Stepper Motors and Drives 2 06-11-2009 08:18 PM
Y axis moves minus but not plus daedalus0x1a4 Bridgeport and Hardinge Mills 1 05-04-2009 11:00 AM
Need Help!- Plus and Minus Reversed cncboss6 Mach Wizards, Macros, & Addons 2 04-06-2009 08:31 PM
Problem- axis goes plus or minus on it's own glentner General CNC (Mill and Lathe) Control Software (NC) 0 10-24-2008 07:53 PM
Starting at MINUS Z depth problem SScnc Vectric 5 09-20-2008 08:58 PM
