| Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here. |
Hi, What are the software options available for generating G-code from within AutoCAD? My google search only returned exactcam ( fierycut ) product. I didnt find any discussion on exactcam or fierycut sw in any of the forums here. Have anyone used it? Any reviews? The demo version looks very neat. Are there any other similar products out there, that can support toolpath, g-codes, nesting etc. from within the autocad environment? Considering the powerful LISP&VB.NET framework available within autocad, I was expecting to find more powerful&affordable autocad tools for this task. |
| Probably because Acad is a CAD program not a CAM pgm. Al.
| There's also these. http://www.timeguy.com/cradek/autocad http://www.wjbzone.com/wjbzone-acad.html There used to be these. http://www.autocode.com/ http://www.tahlcam.com/
Hi, In Autocad, polylines can be exploded by using "Explode" command. Like that is there any Command available to explode splines and ellipse. Actually my requirement is to convert the drawn splines or ellipse into polylines. I found one command called "Pellipse" where in you can specify its value as 0 or 1. If you specify its value as 1 and then draw the ellipse, it gives a series of poly arcs and then you can use the Explode command to explode it. But I want a command which can explode the already drawn ellipse (or Splines). I am expecting a quick reply from you as it would be a great help for me to continue with my work. |
| http://www.cadalyst.com/cad/autocad/splines-plines-4704 http://www.cadalyst.com/gis/hot-tip-...june-2005-8753 I think the first one is better, but can't remember for sure.
We use the FieryCut nesting software. The software creates G-code for laser, plasma, waterjet, wire. The software is simple and very convenient in use, the interface convenient and clear. www.exactcam.com/Products.htm www.exactcam.com/SampleNesting.htm www.exactcam.com/SampleCutting.htm
The Lisp & VB tools be able to create easy software but don't be used for creating very difficult the nesting software. The Fierycut software is written on C ++ and integrated with AutoCAD |
| Tags |
| autocad, autocam, exactcam, fierycut, g-code |
| AutoCAD 2 G-Code macro | ger21 | Autodesk Software (Autocad, Inventor etc) | 224 | 11-06-2011 12:02 PM |
| Draw TRUMPF TC5000R NC CODE IN AUTOCAD | Hodge | Post Processor Files | 3 | 07-17-2008 07:37 AM |
| AutoCaD to G-code/CAM | droddis | Autodesk Software (Autocad, Inventor etc) | 21 | 01-25-2008 08:47 AM |
| AutoCad to lathe g code | allanwinks | Autodesk Software (Autocad, Inventor etc) | 1 | 12-16-2007 01:40 PM |
| AutoCAD R14 3d Model to G-code to CNC | Sanghera | Autodesk Software (Autocad, Inventor etc) | 6 | 01-20-2005 06:22 AM |
