Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 06-09-2010, 01:45 AM
riverracer is on a distinguished road
'05 lt settings
hi,
we are about to reformat our drive with autocad 2005 lt, and was wondering if there is a way to either find or export the config settings. ie: toolbars and plot settings and other general settings.
which folder/where should we look?
what *.extension should we look for?
have googled but no luck.
just trying to avoid spending hours setting the program the way we like it all over again.
thanks
Old 06-09-2010, 06:26 AM
ger21's Avatar
I think it's the .mns file.
Old 06-10-2010, 01:26 AM
FYI
found this
C:\Documents and settings\Yourname\Application data\Autodesk\Autocad 200?\R16.1\enu\ ---
Copy whole enu file from existing computer to usb and then replace enu with this copied enu into the computer that you want to add custom tools to.
thanks
DSP settings rocabig Excitech routers 5 12-04-2009 03:46 AM
We Cim cut settings slammedxonair DynaTorch 2 11-17-2009 03:50 PM
Need Help!- Mach3 CV settings vs. G-100 Plugin CV settings Bfarn Machines running Mach Software 7 12-17-2008 10:45 AM
Settings piedpipertraps DynaTorch 7 10-15-2008 05:30 PM
dnc settings jamesr Fanuc 1 02-02-2006 02:13 PM
