| Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here. |
I need to make a plate that will blank off a hole left after modifying a machine at work. The attached PDF shows my attempts so far, it's a simple 12mm (1/2") thick plate & only the holes internal to the outer profile need to be accurate to any degree. I've tried to draw a smooth & flowing profile around these holes that will machine with a 16mm cutter but it just doesn't 'look' right, both in the drawing & in the prototype. I'm so much of a beginner at design that I don't even have the words to describe what I'm trying to achieve, can anyone see what I mean & point me in the right direction? |
| On the two long sides, try a large arc tangent to the top and bottom bolt hole offsets. Tht'll give you one long curve instead of the 2-3 that you have now.
| This might explain it better. I'm trying to radius the plate around the holes by drawing larger circles around those holes. I then need to draw arcs & straight lines from these circles to form the profile. Is there an easy way to join these arcs to the circles so that a 16mm cutter will give me a smooth profile? |
| Assuming you're using AutoCAD, to draw an arc, Use the Circle - tangent - tangent option. Drawing a line tangent to two circles is more difficult. The first example here explains how to do it. http://jwilson.coe.uga.edu/emt669/St.../Tangents.html
| After using AutoCAD for almost 15 years, I learned something new today. It's been my understanding that drawing a line tangent two two circles using the Tangent Osnaps didn't work in AutoCAD. While searching this morning, I discovered that it doesn't work if you're drawing a polyline. If you use the Line command, it works fine. Since I always used polylines, it never worked for me. This is a huge discovery. So, rather than going through the trouble spelled out in the link above, just use the Line command, and tangent snap to each arc.
| Smooth Profile Cuts | ecope | TurboCNC | 3 | 04-09-2012 01:40 PM |
| Just IN- Smooth Linear Motion in Compact Spaces with Low-Profile Redi-Rail® | Pacific Bearing | Product Announcements & Manufacturer News | 0 | 09-22-2009 04:44 PM |
| What is a Smooth Stepper and ... | gotfdirtball | Mach Software (ArtSoft software) | 1 | 03-16-2009 07:43 PM |
| Beginner full profile threading question | SRT Mike | General Metalwork Discussion | 0 | 07-22-2008 11:40 PM |
| text not smooth? | DEW | BobCad-Cam | 4 | 04-05-2006 08:20 AM |
