Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 05-26-2010, 08:21 PM
mikejkd is on a distinguished road
connecting points
I want to put a bunch of zyx points on the screen and be able to connect them with a surface. How do I do this? I have a bunch of point of my side yard and want to make a virtual map of the land.
Old 05-27-2010, 05:50 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
Here's how I get X,Y points into AutoCAD:
Your co-ordinates should be separated by a comma. Numbers only. Each co-ordinte pair on one line.
Make sure the first line contatins the word "PLINE"
Make sure the file is saved with an .SCR extension.
Run AutoCAD and type the command "SCRIPT" and select the .SCR file you just made.
You can then select PLINE and EXPLODE it if you want.
Dunno if it works for X, Y, Z but it works for X, Y so don't see why not
So your .SCR file would be in the following format:
PLINE
0,0
123,456
132,165
etc...
Lemme know how you get on!
I love deadlines- I like the whooshing sound they make as they fly by.
connecting points in a drawing !! Danno Dolphin CADCAM 6 12-11-2009 07:09 AM
Problem- 6 points moving MCR-B II Okuma 10 10-20-2009 11:14 PM
Points to Surfs JDcam Rhino 3D 4 01-26-2009 11:04 AM
Need Help!- POINTS el gordo Mastercam 1 10-04-2008 10:41 PM
position of points TPPJR OneCNC 3 01-04-2006 12:19 PM
