Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 05-09-2010, 10:08 AM
Cyclone500 is on a distinguished road
AutoCad Fonts and Images
I looking for a way to load fonts and scan images into Auto Cad to get a .dxf for a plasma table. I have tried a few free cad programs and I can save the fonts as a .dxf, but Auto Cad won't load the file. I am not opposed to buying a program, but I would like to make sure I get one that will work. Any Hints - Recommendations?
Also, I am new to this forum, it seems to take forever to load. The first page will come up but it is a while before I can scroll down. Is there anything to change or is it just the ads?
Old 05-09-2010, 10:14 AM
Al_The_Man's Avatar
If you need to load dxf or dwg files into your version of AutoCad and are having a problem, try A9Tech it has not let me down yet and its free.
Old 05-09-2010, 10:18 AM
ger21's Avatar
I've used this in the past for getting .dxf text into AutoCAD.
http://www.dwgtool.com/outline.htm
I've also used Insert>Raster image and then traced over it.
And as Al said, use A9 converter to convert to a version that AutoCAD can open.
As far as the site loading slow, it may be your connection is not that fast. It's very fast for me. If it does seem to hang, try hitting refresh and see if that helps.
Old 05-12-2010, 10:45 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
ProCad will load dxf files and behaves exactly as Autocad so you'll be familiar with it, the free version (for domestic use only is 2009 version)
http://www.progesoft.com/
look down the bottom of the screen for the 2009 version
I love deadlines- I like the whooshing sound they make as they fly by.
New Machine Build- Some images of my 4Axis CNC Thaokhau DIY-CNC Router Table Machines 4 07-02-2011 05:39 AM
Help: Autocad 2000 (Autocad Error aborting) Holmes_ca Autodesk Software (Autocad, Inventor etc) 5 05-07-2010 08:07 AM
AutoCAD 2000 to AutoCAD LT 2010? 2kjettaguy Autodesk Software (Autocad, Inventor etc) 2 08-15-2009 09:33 AM
images aprentiss HURCO 1 10-12-2008 09:18 AM
Autocad fonts (letters) to .dxf files fiedd General CNC (Mill and Lathe) Control Software (NC) 15 02-08-2005 05:54 PM
