Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 05-09-2005, 05:51 PM
JW Peters is on a distinguished road
3D wireframe surface
Hello All; I am new to Autocad. Took a beginners coarse at the local vocational school. I don't know how to render a surface on a 3D wireframe. I need the surface so GMAX can find my object. Can someone tell me how to render a surface on my wireframe in Autocad or GMAX? Thanks JP
Old 05-09-2005, 06:43 PM
ger21's Avatar
I'm assuming you drew it with 3D polylines, or splines? If so, there are no surfaces, and you'll need to create meshes. Use the surface commands, edgesurf, tabsurf, rulesurf, and revsurf. Use surftab1 and surftab2 to change the mesh density.
If I'm not understanding you correctly, could you post the drawing so I can take a look at it.
Old 05-09-2005, 07:10 PM
Hi ger21; I don't know if it is 3D polylines or splines. The drawing is generated with propriatery software. Is there a way that I can figure out if it is 3D polylines or splines, or convert it to 3D polylines or splines? I will email the author. He lives in England and probably won't respond until tomarrow. I can't post the drawing to a public forum. Sorry. I can email it to you with the expectation that you won't reveal the contents or purpose. Thanks JP
Old 05-09-2005, 07:23 PM
ger21's Avatar
I sent you an email.
projecting text onto a boolean created surface Bigfoot1 BobCad-Cam 0 03-18-2005 03:25 PM
Graphics Pad for freehand carving with CNC router foamcutter General CAM Discussion 16 03-02-2005 09:16 AM
Using the difference function ? Ken_Shea OneCNC 20 09-21-2003 06:11 AM
Surface Hatching option ? Ken_Shea OneCNC 2 06-13-2003 12:28 PM
creating surface Mortek OneCNC 5 05-20-2003 10:11 AM
