Results 1 to 6 of 6
Thread: jpeg convert to dxf...can I do this?
    Registered mredican's Avatar
    Apr 2005
    My CNC router is run with Kcam3 software. I use QuickCAD 8 to design with and save it as a dxf file. I'm wanting to do some inlay work and have some jpeg files that I want to incorporate in my CAD designs. Can I do this and how do I get it to convert to dxf so Kcam3 will run?
    Nov 2004
    UK
    yes you can their are many jpeg , gif , tiff etc convertors available
    search with google for jpeg2dxf and you will find many ways
    anydwg.com springs to mind for one
    Dave
    Mar 2003
    Shelby Twp, MI....USA
    If you're planning on doing inlays, I doubt you'll get useable results from a raster to vecotr conversion. Your best bet would be to import the .jpg into the CAD program, and trace it.
    Feb 2004
    [B] I'm interested[/B]
    in learning more about your process of doing this. Sunday night I drew an Oak leaf in Autocad using splines and when I used sheetcam to process it I ended up with over 8000 lines of gcode. Not only that but my machine frozeup at line N160 when I tried to run it .
    Ger you copied a picture I put on CNCZone for a baluster and that worked great how did you do that?
    Jerry
    Mar 2003
    I think Eric did that, not me. Splines will always be broken up into lots of short, straight segments.
    www.joescnc.com joecnc2006's Avatar
    Aug 2004
    Even Mach2-3 will do it, Import Image. then chose depth of black.
    1. G-Code to DXF
      By WayneHill in forum OpenSource Software
      Last Post: 05-20-2013, 10:28 PM
    2. DXF Catalog
      By CNCdude in forum Product and Manufacturer Announcements
      Last Post: 08-26-2004, 10:07 PM
    3. DXF or PLT files
      By signIT in forum DIY CNC Router Table Machines
      Last Post: 07-01-2004, 05:57 PM
    4. convert smartcam to dxf format?
      By imfool in forum General CAM Discussion
      Last Post: 03-23-2004, 10:15 PM
