| Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here. |
Hi- Just wondered if anyone can help me, I am currently using Autodesk 2009 to program my nail gun cnc building garden sheds. Here's a brief description of how I’m using it- I have use Autodesk as a basic cad software (my boss spent a fortune on it, not sure if it was a good sales man or my boss doesn’t have a clue). So to create a nail path its basically one straight line broken into many lines, each break of the line is where a nail will be fired by my cnc. So here's my dilemma- On this nail gun CNC I'm using it takes too long to program. To nail up a simple frame of a garden building 1- I have to select one out of three different nail paths 2- I have to adjust the height 3- I have to draw a cad drawing with the uprights on it 4- I have to copy the nail path on top of these uprights then delete any un used geometry. I have made many parametric programs using Xilog Plus for SCM machinery. I would use this if I could but it needs to export as a .dxf file. Surely there is a way in autodesk where I can make my program using a simple table formula. i.e Nailpath 1= 50mm wide 2= 70mm wide 3= 100mm wide Height = 2000mm Position of upright 1= 500mm postion of upright 2 = 750mm Any help much appreciated |
| Are you using AutoCAD? Autodesk is the company, they have many different products. If AutoCAD, you can write an Autolisp program or VBA macro to do what you want.
| Hi Ger Thanks for the reply. I have Autocad 2009 installed on the laptop but I use inventor. I am willing to use autocad, if like you say I can program in that. I will have a look into it and see how I get on. Which way would you recommend? Is it something I can do as a novice? Cheers |
| Have you figured this out? I can think of a couple of ways to do this with Inventor. You can drive a part file via and XLS file, allowing you to enter the data into a table and then updating the part to drop out the path, then save the face of the part as a DXF. Unfortunately I have Inventor 2010, and won;t be able to give you and example that you can open. |
| Hi No still haven't figured this out yet If you can explain to me what needs to be done I can have a go myself, or explain it to a firm in England called Quadra Solutions who supplied the software. Cheers |
| SolidCAM & Autodesk Inventor | Alfonzo | SolidCam | 3 | 11-30-2009 11:35 PM |
| Just learning Autodesk | mike strong | Autodesk Software (Autocad, Inventor etc) | 5 | 12-15-2008 09:02 AM |
| Mastercam and Autodesk Inventor | Bartsimsonii | Mastercam | 0 | 11-23-2007 03:27 PM |
| AutoDesk Inventor | jrotruck | Solidworks | 2 | 08-21-2007 11:07 PM |
| Any Autodesk Inventor 8 users here? | Spinnetti | General CAM Discussion | 4 | 03-17-2004 06:05 AM |
