Hi there,
Does anybody have a working post processor for a HAAS SL20 lathe for autodesk fusion 360 i can get an ST20 from the posts page but it seems slightly different to the code that is used in the SL20.
what does not work ? the Fusion 360 post processors are relative easy to modify except more difficult stuff like life tooling.
I programm a Doosan 220LY with a C and Y axis with Fusion 360 and for this I modified a post processor for a Haas ST20 SSY.
Yes, I made a commercial post for a customer in the past for this machine. There are indeed diferences. There are for example no radial drilling cycles possible, and some cycles are different. Also most of them have a livetool holder that runs in reverse (so m3 is m4) The problem is, the documentation for this machine is pretty limited.
You can contact me if you want to invest in a postprocessor.
