Wanted postprocessor for tria 4000/morbidelli u13
Results 1 to 14 of 14
Thread: Wanted postprocessor for tria 4000/morbidelli u13
    Jan 2015
    Default Wanted postprocessor for tria 4000/morbidelli u13
    Hello, i have two problems with the cnc
    1. i don't have the backup disk for the cnc
    and currently the cnc isn't working because i doesn't calibrate. It moves slowly on the x axys and then it freeze when i press calibrate function.
    i was advised to get a copy of the backup disk and try to reinstal the main program.
    2.
    i want the post processor that will convert the files from xilog 3 to the correct .pgm file for the tria 4000/morbidelli u13
    I believe that this is what i need in order to convert the files: [COLOR=#000000]cnv75new.exe[/COLOR].
    thank you very much
    Default Re: Wanted postprocessor for tria 4000/morbidelli u13
    I think for the Tria 4000 you might need cnvrt.exe I might be wrong? but I have both files (also cnv75.exe) for you, can you PM me your email address?
    Jan 2015
    My email is 4ridersro at Gmail. Com
    Ok Ive emailed them to you
    Jan 2015
    Maybe some of you have any manuals for this morbidellii will be very grateful
    [url]https://sites.google.com/site/morbidelliauthor504/manuals[/url] I only have these
  7. #7
    Jan 2015
    o now basically the cnc is broken. It has problems with the x,y origin. it doesn't position itself. error 605 error x axys drive. After that a fuse is activated. The cnc doesn,t calibrate
  8. #8
    Jan 2015
    i found the 605 error: x axis fault drive
    cause: no drive power. For other causes consult the DRIVE techincal documentation.
    Reset the overload switch. Consult the after-sales service.
    My problem: Where is the overload switch ?
  9. #9
    In the large panel at the back, it's one of the white circuit breakers... Do you have the wiring diagram? once the program runs the axis faults will go away. my machine brings up the same errors but if i run the program they errors disapear
  10. #10
    Jan 2015
    I need the plc disk for morbidelli u13 and tria 4000 type al750
  11. #11
    Jan 2015
    Update : i have managed to make it work by copying the files from al385 to my al750. Now i have other problem with tool data: the error is invalid fixturing.
    Fix. i did manage to resolve this problem to.
    Now its up and running. I need to learn the manual now for g code.
    i still need the post processor. and a way to convert the dwg files to pgm. thank you
  12. #12
    Jun 2012
    australia
    [QUOTE=4riders;1642548]o now basically the cnc is broken. It has problems with the x,y origin. it doesn't position itself. error 605 error x axys drive. After that a fuse is activated. The cnc doesn,t calibrate[/QUOTE]
    Hi, my u13 did exactly the same thing and it turned out to be the limit switch on the x axis was a bit seized up so stripped it and lubed and all has been good since
  13. #13
    Dec 2017
    Old thread but I'm searching for a copy of cnvrt.exe and cnv75new.exe. If anyone can help me out it would be much appreciated!
  14. #14
    Mar 2018
    Portugal
    Helo, i´m from Portugal, and i have similar problems with a morbidelli u13 cnc. Could you please email me both cnvrt.exe and cnv75.exe please?
    My email adress is: [email]nunomiguel.barbosa@gmail.com[/email]
  15. #15
    novynaf's Avatar
    Aug 2022
    hi i am looking for the cnv75new.exe file for my morbidelli u13 tria4000
    my email is [email]yvon1964@otmail.com[/email]
