Stuck again ;)
Results 1 to 14 of 14
Thread: Stuck again ;)
    Feb 2014
    United Kingdom
    Default Stuck again ;)
    Another part doing the grey matter in
    Made from a bar, the bar extends out to right of the picture.
    My idea was to machine the end of the bar so its square to the sides, then hog out the bulk of the recess leaving 1/32 finish allowance, this pocket is about 3/8" deep - these parts work ok in CAM
    Then i wanted to use a ball-end tool to run a finish pass on the curved fillets, this part refuses to CAM, can't seem to find a contour selection that works? Using a 2d profile path.
    Next i was going to machine the lower curved edge, in steps, releasing the part on the last step. (not sure if this will work)
    Probably either a simple task and i cant see it or i'm going about it totally wrong
    .stl attached.
    Any suggestions?
    Attached Thumbnails Attached Thumbnails Stuck again ;)-screen-shot-2018-02-08-21-49-a
    Attached Files Attached Files
    Bending bits of metal in Hertfordshire - https://ddmetalproducts.co.uk
    Mar 2008
    Default Re: Stuck again ;)
    Check that your selection filter allows picking edges. Or you can create a sketch, project the edges you want to use, then run your toolpaths on those.
    Member precisionmetal's Avatar
    Oct 2010
    I'm seeing an STL file (a mesh). It's also enormous, so I believe it's been scaled 25.4x, since it shows as being 508mm tall?
    I believe my approach would be to convert it to a BRep, then extract the edges and re-draw the part.
    ... and then do the CAM work.
    Feb 2014
    United Kingdom
    Thanks, i'll check that. not done sketches/projection yet, will have a look.
    Feb 2014
    United Kingdom
    Quote Originally Posted by precisionmetal View Post
    Yes, i work in mm so it likely is scaled on import.
    Sorry, no idea what a BRep is yet, or what extraction is i'm afraid.
    I have a lot to learn i think.
    Feb 2014
    United Kingdom
    Hmm, in the end i just replaced the roughing tool with the ball-end, removed stock-to-leave and it works. Must be using the wrong machining strategies maybe?
    The last path is a straight tool, this is the one that would sever the part from the parent stock, no idea if this will work but gotta be worth a try
    The bar is 5/8" thick.
    Attached Thumbnails Attached Thumbnails Stuck again ;)-screen-shot-2018-02-09-08-19-a
  7. #7
    Feb 2014
    United Kingdom
    Well, the part worked nicely but i have a lot to learn.
    As seen in the picture - i hogged the cavity out with a ball end mill but this has left grooves on the lower face.
    What would i need to be doing to stop this?
    It's not crucial as it's all cosmetic but does not look right i think.
    Attached Thumbnails Attached Thumbnails Stuck again ;)-ballnose-grooves-jpg
  8. #8
    Oct 2010
    Possibly do the flat area with a bull nose end mill, then use the ball to do the corners only.
    You could also use a much smaller ball end mill, and 3d profile that entire area (time consuming, but if most of the material was roughed away first, might not be bad).
  9. #9
    Feb 2014
    United Kingdom
    Clearly i am doing something not quite right - this part has consumed many hours today, yes i have made one part but i'm not happy with it.
    I have since managed to create a path to rough out the cavity with a flat end mill, but for the last two hours i cannot get a selection that will allow me to run a single finish pass over the contour with the ball-end tool, it just wants to machine the whole area again, tried practically every strategy in the box.
    Is it because i am machining off the end of a long bar but have not modelled the bar maybe? Not even sure if that matters.
    I just cant find a roughing / finishing strategy that will allow a flat tool to hog the junk and leave a good face followed by a ball end to finalise the curves and vertical faces.??
  10. #10
    Oct 2010
    As I mentioned previously, I believe the part needs to be re-drawn.
    It appears to have started life as an STL (mesh), and I have had a issues in the past trying to machine anything in that form.
    I would suggest modeling the part from scratch, and then trying to machine that.
    PM
  11. #11
    Feb 2014
    United Kingdom
    I drew it this week, in Fusion, from scratch ??
    I merely exported as a sty so i could put it on forum.
    Dave
    Edit - here's a share link....
    A360
  12. #12
    Oct 2010
    Here you go:
    https://www.dropbox.com/s/vklt9wh2wh...ntour.f3d?dl=0
    I added one process to your existing Setup_1 so you could look at a possible option.
    Note... you can play with the lead-in/out settings to extend the path a bit off the ends of the part if necessary.
    PM
  13. #13
    Feb 2014
    United Kingdom
    Thanks for that, appreciated.
    I think most of my issues stem from trying to get the Z height from the contour instead of just selecting "Stock Top -Xmm"
  14. #14
    Oct 2010
    There are definitely many ways to "skin the cat" in Fusion (well, in *any* CAM program). :-)
Stuck again ;)
Stuck again ;)
