Problem Fusion 360 and 4th Axis Issue--STUMPED!!
Results 1 to 2 of 2
Thread: Fusion 360 and 4th Axis Issue--STUMPED!!
    Sep 2007
    Question Fusion 360 and 4th Axis Issue--STUMPED!!
    We just got a new HRT160 4th axis for our Haas Mini so my experience level with 4th axis in general is pretty low. My issue is this,
    My first project for using my 4th axis is basically a cube with the same machining being done on each of the rotating sides. In F360 under Pattern, I use "circular pattern" with 4 instances. The code starts off with a facing operation, several milling operations, followed by a couple drilling operations to be repeated on all 4 sides.
    For some reason the facing and milling operations would all move to a safe Z height before the A axis rotates the part. Once the drilling cycle starts it would run correctly on the first side, then go up to the retract height but would drop back down to machine zero (tool change height) before the A axis starts rotating, which doesn't allow for enough clearance. First I tried adjusting the clearance/retract heights but this a no effect on the Z axis prior to the A axis rotating. So then I started analyzing the code and was surprised that the end of cycles between the milling operations and the drilling operations were identical. I cannot find anything in the code that would make the drilling operations return to Z zero before rotating the A xis but does not require the milling operations to do the same. I have even tried separating the drilling operations into its own program, still has the same results.
    At this point I dont know if its a F360 setting or a HAAS setting that is causing the issue.
    Thanks in advance for any help. Below is the code,
    O01001 (HYD CUBE)
    (Using high feed G1 F500. instead of G0.)
    (T2 D=0.201 CR=0. TAPER=118deg - drill)
    (T3 D=0.1094 CR=0. - flat end mill)
    (T4 D=0.0625 CR=0. - flat end mill)
    (T7 D=2. CR=0. TAPER=45deg - face mill)
    (T8 D=0.1875 CR=0. - flat end mill)
    (T9 D=0.173 CR=0. TAPER=118deg - drill)
    N10 G90 G94 G17
    N15 G20
    N20 G53 G0 Z0.
    (Face Top)
    N30 T7 M6
    (FACE MILL 45)
    N35 S5000 M3
    N40 G54
    N45 M11
    N50 G0 A0.
    N55 M10
    N60 M8
    N70 G0 X-3.4033 Y-2.42
    N75 G43 Z2.1 H7
    N80 T8
    N85 G0 Z1.7
    N90 G1 Z1.45 F20.
    N95 Y2.42
    N100 G2 X-2.6467 I0.3783 J0.
    N105 G1 Y-2.42
    N110 G3 X-1.89 I0.3783 J0.
    N115 G1 Y2.42
    N120 G0 Z2.1
    N125 G53 G0 Z0.
    (Face Top)
    N135 M11
    N140 G0 A270.
    N145 M10
    N155 G0 X-3.4033 Y-2.42
    N160 G43 Z2.1 H7
    N165 G0 Z1.7
    N170 G1 Z1.45 F20.
    N175 Y2.42
    N180 G2 X-2.6467 I0.3783 J0.
    N185 G1 Y-2.42
    N190 G3 X-1.89 I0.3783 J0.
    N195 G1 Y2.42
    N200 G0 Z2.1
    N205 G53 G0 Z0.
    (Face Top)
    N215 M11
    N220 G0 A180.
    N225 M10
    N235 G0 X-3.4033 Y-2.42
    N240 G43 Z2.1 H7
    N245 G0 Z1.7
    N250 G1 Z1.45 F20.
    N255 Y2.42
    N260 G2 X-2.6467 I0.3783 J0.
    N265 G1 Y-2.42
    N270 G3 X-1.89 I0.3783 J0.
    N275 G1 Y2.42
    N280 G0 Z2.1
    N285 G53 G0 Z0.
    (Face Top)
    N295 M11
    N300 G0 A90.
    N305 M10
    N315 G0 X-3.4033 Y-2.42
    N320 G43 Z2.1 H7
    N325 G0 Z1.7
    N330 G1 Z1.45 F20.
    N335 Y2.42
    N340 G2 X-2.6467 I0.3783 J0.
    N345 G1 Y-2.42
    N350 G3 X-1.89 I0.3783 J0.
    N355 G1 Y2.42
    N360 G0 Z2.1
    N365 M5
    N370 G53 G0 Z0.
    (2D .1875 Rough Top)
    N380 M9
    N385 M1
    N390 T8 M6
    N395 S6000 M3
    N400 G54
    N405 M11
    N410 G0 A0.
    N415 M10
    N420 M8
    N430 G0 X-2.7707 Y1.6
    N435 G43 Z2.1 H8
    N440 T3
    N445 G0 Z1.7
    N450 G1 Z1.5394 F15.
    N455 Z1.3888
    N460 X-2.7704 Y1.5999 Z1.3855
    N465 X-2.7696 Y1.5996 Z1.3823
    N470 X-2.7683 Y1.5991 Z1.3794
    N475 X-2.7665 Y1.5984 Z1.3767
    N480 X-2.7644 Y1.5976 Z1.3744
    N485 X-2.7619 Y1.5967 Z1.3725
    N490 X-2.7591 Y1.5956 Z1.3711
    N495 X-2.7561 Y1.5945 Z1.3703
    N500 X-2.7531 Y1.5934 Z1.37
    N505 X-2.7513 Y1.5927
    N510 G2 X-2.6727 Y1.5588 I-0.2945 J-0.7899
    N515 G3 X-2.6554 Y1.5522 I0.0424 J0.0859
    N520 G2 X-2.4715 Y1.4786 I-0.2263 J-0.8315
    N525 G3 X-2.4604 Y1.4852 I0.0036 J0.0066
    N530 G1 Y1.5927
    N535 G3 X-2.4698 Y1.6021 I-0.0094 J0.
    N540 G1 X-3.2455
    N545 G3 X-3.2548 Y1.5927 I0. J-0.0094
    N550 G1 Y1.5229
    N555 G3 X-3.2421 Y1.5102 I0.0128 J0.
    N560 X-3.136 Y1.5111 I0. J6.2473
    N565 G2 X-3.03 Y1.512 I0.106 J-6.2464
    N570 X-2.871 Y1.4921 I0. J-0.6463
    N575 X-2.7211 Y1.4354 I-0.1744 J-0.6869
    N580 G3 X-2.7009 Y1.4277 I0.0438 J0.0852
    N585 G2 X-2.3383 Y1.2071 I-0.1785 J-0.7018
    N590 G3 X-2.3284 Y1.2109 I0.0042 J0.0038
    N595 G1 Y1.5927
    N600 G3 X-2.3377 Y1.6021 I-0.0094 J0.
    N605 G1 X-3.3656
    N610 G3 X-3.3749 Y1.5927 I0. J-0.0094
    N615 G1 Y1.4028
    N620 G3 X-3.3622 Y1.3901 I0.0128 J0.
    N625 X-3.1961 Y1.391 I0. J15.3236
    N630 G2 X-3.03 Y1.3919 I0.1661 J-15.3227
    N635 X-2.8936 Y1.374 I0. J-0.5289
    N640 X-2.7658 Y1.3232 I-0.1511 J-0.5662
    N645 G3 X-2.7421 Y1.3142 I0.0456 J0.0843
    N650 G2 X-2.3658 Y1.044 I-0.139 J-0.5908
    N655 G3 X-2.3409 Y1.0301 I0.0249 J0.0154
    N660 G1 X-2.2211
    N665 G3 X-2.2083 Y1.0428 I0. J0.0128
    N670 G1 Y1.5927
    N675 G3 X-2.2177 Y1.6021 I-0.0094 J0.
    N680 G1 X-3.5176
    N685 G3 X-3.527 Y1.5927 I0. J-0.0094
    N690 G1 Y1.2508
    N695 G3 X-3.5142 Y1.238 I0.0128 J0.
    N700 G1 X-3.03 Y1.2398
    N705 G2 X-2.9325 Y1.227 I0. J-0.3765
    N710 X-2.8411 Y1.191 I-0.1128 J-0.4209
    N715 G3 X-2.773 Y1.1652 I0.1361 J0.2565
    N720 G2 X-2.4587 Y0.8915 I-0.1057 J-0.4387
    N725 G3 X-2.4389 Y0.878 I0.0198 J0.0078
    N730 G1 X-2.069
    N735 G3 X-2.0563 Y0.8908 I0. J0.0128
    N740 G1 Y1.5927
    N745 G3 X-2.0656 Y1.6021 I-0.0094 J0.
    N750 G1 X-3.6696
    N755 G3 X-3.679 Y1.5927 I0. J-0.0094
    N760 G1 Y1.0988
    N765 G3 X-3.6662 Y1.086 I0.0128 J0.
    N770 G1 X-3.03 Y1.0878
    N775 G2 X-2.9541 Y1.0752 I0. J-0.2348
    N780 X-2.8856 Y1.0403 I-0.0878 J-0.2572
    N785 G3 X-2.8424 Y1.0236 I0.0549 J0.0781
    N790 G2 X-2.5793 Y0.7387 I-0.0368 J-0.2979
    N795 G3 X-2.5661 Y0.726 I0.0133 J0.0006
    N800 G1 X-1.917
    N805 G3 X-1.9042 Y0.7388 I0. J0.0128
    N810 G1 Y1.5927
    N815 G3 X-1.9136 Y1.6021 I-0.0094 J0.
    N820 G1 X-3.8219
    N825 G3 X-3.8312 Y1.5927 I0. J-0.0094
    N830 G1 Y0.9338
    N835 X-3.03
    N840 G2 X-2.9392 Y0.8738 I0. J-0.0987
    N845 G1 X-2.88
    N850 G2 X-2.7312 Y0.725 I0. J-0.1487
    N855 G1 Y0.5738
    N860 X-1.752
    N865 Y1.37
    N870 Y1.5927
    N875 G3 X-1.7522 Y1.5956 I-0.0187 J0.
    N880 G1 X-1.7551 Y1.6137
    N885 X-1.7556 Y1.6169 Z1.3703
    N890 X-1.7561 Y1.62 Z1.3711
    N895 X-1.7565 Y1.6229 Z1.3725
    N900 X-1.757 Y1.6256 Z1.3744
    N905 X-1.7573 Y1.6279 Z1.3767
    N910 X-1.7576 Y1.6297 Z1.3794
    N915 X-1.7578 Y1.6311 Z1.3823
    N920 X-1.758 Y1.6319 Z1.3855
    N925 Y1.6322 Z1.3888
    N930 G0 Z2.1
    N935 G1 X-2.4604 Y-1.6321 F500.
    N940 G0 Z1.7
    N945 G1 Z1.3888 F15.
    N950 G19 G3 Y-1.6134 Z1.37 J0.0187 K0.
    N955 G1 Y-1.5927
    N960 Y-1.4852
    N965 G17 G3 X-2.4715 Y-1.4786 I-0.0076 J0.
    N970 G2 X-2.6554 Y-1.5522 I-0.4074 J0.7511
    N975 G3 X-2.6727 Y-1.5588 I0.0252 J-0.0924
    N980 G2 X-2.7513 Y-1.5927 I-0.3732 J0.7559
    N985 G3 X-2.7478 Y-1.6109 I0.0033 J-0.0088
    N990 G1 X-2.3375 Y-1.6021
    N995 G3 X-2.3284 Y-1.5927 I-0.0002 J0.0094
    N1000 G1 Y-1.2109
    N1005 G3 X-2.3383 Y-1.2071 I-0.0057 J0.
    N1010 G2 X-2.7033 Y-1.4283 I-0.5418 J0.4822
    N1015 G3 X-2.7189 Y-1.4342 I0.0174 J-0.0696
    N1020 G2 X-2.8698 Y-1.4918 I-0.3263 J0.6285
    N1025 X-3.03 Y-1.5119 I-0.1602 J0.6266
    N1030 X-3.136 Y-1.511 I0. J6.2473
    N1035 G3 X-3.2421 Y-1.5101 I-0.106 J-6.2464
    N1040 X-3.2548 Y-1.5229 I0. J-0.0128
    N1045 G1 Y-1.5927
    N1050 G3 X-3.2455 Y-1.6021 I0.0094 J0.
    N1055 G1 X-2.2177
    N1060 G3 X-2.2083 Y-1.5927 I0. J0.0094
    N1065 G1 Y-1.0428
    N1070 G3 X-2.2211 Y-1.0301 I-0.0128 J0.
    N1075 G1 X-2.3409
    N1080 G3 X-2.3658 Y-1.0439 I0. J-0.0293
    N1085 G2 X-2.7421 Y-1.3142 I-0.513 J0.3173
    N1090 G3 X-2.7658 Y-1.3232 I0.0219 J-0.0933
    N1095 G2 X-2.8936 Y-1.374 I-0.2789 J0.5154
    N1100 X-3.03 Y-1.3919 I-0.1364 J0.511
    N1105 X-3.1961 Y-1.391 I0. J15.3236
    N1110 G3 X-3.3622 Y-1.3901 I-0.1661 J-15.3227
    N1115 X-3.3749 Y-1.4028 I0. J-0.0128
    N1120 G1 Y-1.5926
    N1125 G3 X-3.3656 Y-1.602 I0.0094 J0.
    N1130 G1 X-2.0656 Y-1.6021
    N1135 G3 X-2.0563 Y-1.5927 I0. J0.0094
    N1140 G1 Y-0.8908
    N1145 G3 X-2.069 Y-0.878 I-0.0128 J0.
    N1150 G1 X-2.4389
    N1155 G3 X-2.4587 Y-0.8915 I0. J-0.0213
    N1160 G2 X-2.773 Y-1.1652 I-0.4216 J0.1668
    N1165 G3 X-2.8411 Y-1.191 I0.068 J-0.2823
    N1170 G2 X-2.9325 Y-1.227 I-0.2043 J0.3849
    N1175 X-3.03 Y-1.2398 I-0.0975 J0.3636
    N1180 G1 X-3.5142 Y-1.238
    N1185 G3 X-3.527 Y-1.2508 I0. J-0.0128
    N1190 G1 Y-1.5927
    N1195 G3 X-3.5176 Y-1.6021 I0.0094 J0.
    N1200 G1 X-1.9136 Y-1.602
    N1205 G3 X-1.9042 Y-1.5926 I0. J0.0094
    N1210 G1 Y-0.7388
    N1215 G3 X-1.917 Y-0.726 I-0.0128 J0.
    N1220 G1 X-2.5661
    N1225 G3 X-2.5793 Y-0.7387 I0. J-0.0133
    N1230 G2 X-2.8423 Y-1.0236 I-0.2998 J0.0129
    N1235 G3 X-2.8857 Y-1.0403 I0.0118 J-0.0951
    N1240 G2 X-2.9542 Y-1.0752 I-0.1563 J0.2224
    N1245 X-3.03 Y-1.0878 I-0.0758 J0.2222
    N1250 G1 X-3.6662 Y-1.086
    N1255 G3 X-3.679 Y-1.0988 I0. J-0.0128
    N1260 G1 Y-1.5927
    N1265 G3 X-3.6696 Y-1.6021 I0.0094 J0.
    N1270 G1 X-1.7613
    N1275 G3 X-1.752 Y-1.5927 I0. J0.0094
    N1280 G1 Y-0.5737
    N1285 X-2.7312
    N1290 Y-0.725
    N1295 G2 X-2.88 Y-0.8737 I-0.1488 J0.
    N1300 G1 X-2.9392
    N1305 G2 X-3.03 Y-0.9337 I-0.0908 J0.0387
    N1310 G1 X-3.8312
    N1315 Y-1.37
    N1320 Y-1.5927
    N1325 G3 X-3.831 Y-1.5956 I0.0187 J0.
    N1330 G1 X-3.8282 Y-1.6137
    N1335 X-3.8276 Y-1.6169 Z1.3703
    N1340 X-3.8271 Y-1.62 Z1.3711
    N1345 X-3.8267 Y-1.6229 Z1.3725
    N1350 X-3.8263 Y-1.6256 Z1.3744
    N1355 X-3.8259 Y-1.6279 Z1.3767
    N1360 X-3.8256 Y-1.6297 Z1.3794
    N1365 X-3.8254 Y-1.6311 Z1.3823
    N1370 X-3.8253 Y-1.6319 Z1.3855
    N1375 X-3.8252 Y-1.6322 Z1.3888
    N1380 G0 Z2.1
    N1385 G1 X-3.423 Y-1.6321 F500.
    N1390 G0 Z1.7
    N1395 G1 Z1.4487 F15.
    N1400 G19 G3 Y-1.6134 Z1.43 J0.0187 K0.
    N1405 G1 Y-1.5927
    N1410 Y-0.6608
    N1415 G17 G3 X-3.4358 Y-0.648 I-0.0128 J0.
    N1420 G1 X-3.4892
    N1425 G3 X-3.502 Y-0.6608 I0. J-0.0128
    N1430 G1 Y-1.5926
    N1435 G3 X-3.4926 Y-1.602 I0.0094 J0.
    N1440 G1 X-3.2804
    N1445 G3 X-3.271 Y-1.5926 I0. J0.0094
    N1450 G1 Y-0.5088
    N1455 G3 X-3.2838 Y-0.496 I-0.0128 J0.
    N1460 G1 X-3.6412
    N1465 G3 X-3.654 Y-0.5088 I0. J-0.0128
    N1470 G1 Y-1.5927
    N1475 G3 X-3.6446 Y-1.6021 I0.0094 J0.
    N1480 G1 X-3.1281
    N1485 G3 X-3.1187 Y-1.5927 I0. J0.0094
    N1490 G1 Y-0.775
    N1495 Y-0.3438
    N1500 X-3.8062
    N1505 Y-1.5927
    N1510 G3 X-3.806 Y-1.5957 I0.0187 J0.
    N1515 G1 X-3.8032 Y-1.6137
    N1520 X-3.8026 Y-1.617 Z1.4303
    N1525 X-3.8022 Y-1.6201 Z1.4311
    N1530 X-3.8017 Y-1.623 Z1.4325
    N1535 X-3.8013 Y-1.6256 Z1.4344
    N1540 X-3.8009 Y-1.6279 Z1.4367
    N1545 X-3.8006 Y-1.6298 Z1.4394
    N1550 X-3.8004 Y-1.6311 Z1.4423
    N1555 X-3.8003 Y-1.632 Z1.4455
    N1560 X-3.8002 Y-1.6323 Z1.4487
    N1565 G0 Z2.1
    N1570 G1 X-3.502 Y1.6318 F500.
    N1575 G0 Z1.7
    N1580 G1 Z1.4487 F15.
    N1585 G19 G2 Y1.613 Z1.43 J-0.0187 K0.
    N1590 G1 Y1.5927
    N1595 Y0.6608
    N1600 G17 G3 X-3.4892 Y0.648 I0.0128 J0.
    N1605 G1 X-3.4358
    N1610 G3 X-3.423 Y0.6608 I0. J0.0128
    N1615 G1 Y1.5926
    N1620 G3 X-3.4324 Y1.602 I-0.0094 J0.
    N1625 G1 X-3.6446
    N1630 G3 X-3.654 Y1.5926 I0. J-0.0094
    N1635 G1 Y0.5088
    N1640 G3 X-3.6412 Y0.496 I0.0128 J0.
    N1645 G1 X-3.2838
    N1650 G3 X-3.271 Y0.5088 I0. J0.0128
    N1655 G1 Y1.5927
    N1660 G3 X-3.2804 Y1.6021 I-0.0094 J0.
    N1665 G1 X-3.7969
    N1670 G3 X-3.8062 Y1.5927 I0. J-0.0094
    N1675 G1 Y0.835
    N1680 Y0.3437
    N1685 X-3.1187
    N1690 Y1.5927
    N1695 G3 X-3.119 Y1.5956 I-0.0187 J0.
    N1700 G1 X-3.1218 Y1.6137
    N1705 X-3.1224 Y1.6169 Z1.4303
    N1710 X-3.1228 Y1.62 Z1.4311
    N1715 X-3.1233 Y1.623 Z1.4325
    N1720 X-3.1237 Y1.6256 Z1.4344
    N1725 X-3.1241 Y1.6279 Z1.4367
    N1730 X-3.1244 Y1.6297 Z1.4394
    N1735 X-3.1246 Y1.6311 Z1.4423
    N1740 X-3.1247 Y1.6319 Z1.4455
    N1745 X-3.1248 Y1.6322 Z1.4487
    N1750 G0 Z2.1
    N1755 G53 G0 Z0.
    N1765 M11
    N1770 G0 A270.
    N1775 M10
    N1785 G0 X-2.7707 Y1.6
    N1790 G43 Z2.1 H8
    N1795 G0 Z1.7
    N1800 G1 Z1.5394 F15.
    N1805 Z1.3887
    N1810 X-2.7704 Y1.5999 Z1.3855
    N1815 X-2.7696 Y1.5996 Z1.3823
    N1820 X-2.7683 Y1.5991 Z1.3794
    N1825 X-2.7665 Y1.5984 Z1.3767
    N1830 X-2.7644 Y1.5976 Z1.3744
    N1835 X-2.7619 Y1.5967 Z1.3725
    N1840 X-2.7591 Y1.5956 Z1.3711
    N1845 X-2.7561 Y1.5945 Z1.3703
    N1850 X-2.7531 Y1.5934 Z1.37
    N1855 X-2.7513 Y1.5927
    N1860 G2 X-2.6727 Y1.5588 I-0.2945 J-0.7899
    N1865 G3 X-2.6554 Y1.5522 I0.0424 J0.0859
    N1870 G2 X-2.4715 Y1.4786 I-0.2263 J-0.8315
    N1875 G3 X-2.4604 Y1.4852 I0.0036 J0.0066
    N1880 G1 Y1.5927
    N1885 G3 X-2.4698 Y1.6021 I-0.0094 J0.
    N1890 G1 X-3.2455
    N1895 G3 X-3.2548 Y1.5927 I0. J-0.0094
    N1900 G1 Y1.5229
    N1905 G3 X-3.2421 Y1.5102 I0.0128 J0.
    N1910 X-3.136 Y1.5111 I0. J6.2473
    N1915 G2 X-3.03 Y1.512 I0.106 J-6.2464
    N1920 X-2.871 Y1.4921 I0. J-0.6463
    N1925 X-2.7211 Y1.4354 I-0.1744 J-0.6869
    N1930 G3 X-2.7009 Y1.4277 I0.0438 J0.0852
    N1935 G2 X-2.3383 Y1.2071 I-0.1785 J-0.7018
    N1940 G3 X-2.3284 Y1.2109 I0.0042 J0.0038
    N1945 G1 Y1.5927
    N1950 G3 X-2.3377 Y1.6021 I-0.0094 J0.
    N1955 G1 X-3.3656
    N1960 G3 X-3.3749 Y1.5927 I0. J-0.0094
    N1965 G1 Y1.4028
    N1970 G3 X-3.3622 Y1.3901 I0.0128 J0.
    N1975 X-3.1961 Y1.391 I0. J15.3236
    N1980 G2 X-3.03 Y1.3919 I0.1661 J-15.3227
    N1985 X-2.8936 Y1.374 I0. J-0.5289
    N1990 X-2.7658 Y1.3232 I-0.1511 J-0.5662
    N1995 G3 X-2.7421 Y1.3142 I0.0456 J0.0843
    N2000 G2 X-2.3658 Y1.044 I-0.139 J-0.5908
    N2005 G3 X-2.3409 Y1.0301 I0.0249 J0.0154
    N2010 G1 X-2.2211
    N2015 G3 X-2.2083 Y1.0428 I0. J0.0128
    N2020 G1 Y1.5927
    N2025 G3 X-2.2177 Y1.6021 I-0.0094 J0.
    N2030 G1 X-3.5176
    N2035 G3 X-3.527 Y1.5927 I0. J-0.0094
    N2040 G1 Y1.2508
    N2045 G3 X-3.5142 Y1.238 I0.0128 J0.
    N2050 G1 X-3.03 Y1.2398
    N2055 G2 X-2.9325 Y1.227 I0. J-0.3765
    N2060 X-2.8411 Y1.191 I-0.1128 J-0.4209
    N2065 G3 X-2.773 Y1.1652 I0.1361 J0.2565
    N2070 G2 X-2.4587 Y0.8915 I-0.1057 J-0.4387
    N2075 G3 X-2.4389 Y0.878 I0.0198 J0.0078
    N2080 G1 X-2.069
    N2085 G3 X-2.0563 Y0.8908 I0. J0.0128
    N2090 G1 Y1.5927
    N2095 G3 X-2.0656 Y1.6021 I-0.0094 J0.
    N2100 G1 X-3.6696
    N2105 G3 X-3.679 Y1.5927 I0. J-0.0094
    N2110 G1 Y1.0988
    N2115 G3 X-3.6662 Y1.086 I0.0128 J0.
    N2120 G1 X-3.03 Y1.0878
    N2125 G2 X-2.9541 Y1.0752 I0. J-0.2348
    N2130 X-2.8856 Y1.0403 I-0.0878 J-0.2572
    N2135 G3 X-2.8424 Y1.0236 I0.0549 J0.0781
    N2140 G2 X-2.5793 Y0.7387 I-0.0368 J-0.2979
    N2145 G3 X-2.5661 Y0.726 I0.0133 J0.0006
    N2150 G1 X-1.917
    N2155 G3 X-1.9042 Y0.7388 I0. J0.0128
    N2160 G1 Y1.5927
    N2165 G3 X-1.9136 Y1.6021 I-0.0094 J0.
    N2170 G1 X-3.8219
    N2175 G3 X-3.8312 Y1.5927 I0. J-0.0094
    N2180 G1 Y0.9338
    N2185 X-3.03
    N2190 G2 X-2.9392 Y0.8738 I0. J-0.0987
    N2195 G1 X-2.88
    N2200 G2 X-2.7312 Y0.725 I0. J-0.1487
    N2205 G1 Y0.5738
    N2210 X-1.752
    N2215 Y1.37
    N2220 Y1.5927
    N2225 G3 X-1.7522 Y1.5956 I-0.0187 J0.
    N2230 G1 X-1.7551 Y1.6137
    N2235 X-1.7556 Y1.6169 Z1.3703
    N2240 X-1.7561 Y1.62 Z1.3711
    N2245 X-1.7565 Y1.6229 Z1.3725
    N2250 X-1.757 Y1.6256 Z1.3744
    N2255 X-1.7573 Y1.6279 Z1.3767
    N2260 X-1.7576 Y1.6297 Z1.3794
    N2265 X-1.7578 Y1.6311 Z1.3823
    N2270 X-1.758 Y1.6319 Z1.3855
    N2275 Y1.6322 Z1.3887
    N2280 G0 Z2.1
    N2285 G1 X-2.4604 Y-1.6321 F500.
    N2290 G0 Z1.7
    N2295 G1 Z1.3887 F15.
    N2300 G19 G3 Y-1.6134 Z1.37 J0.0187 K0.
    N2305 G1 Y-1.5927
    N2310 Y-1.4852
    N2315 G17 G3 X-2.4715 Y-1.4786 I-0.0076 J0.
    N2320 G2 X-2.6554 Y-1.5522 I-0.4074 J0.7511
    N2325 G3 X-2.6727 Y-1.5588 I0.0252 J-0.0924
    N2330 G2 X-2.7513 Y-1.5927 I-0.3732 J0.7559
    N2335 G3 X-2.7478 Y-1.6109 I0.0033 J-0.0088
    N2340 G1 X-2.3375 Y-1.6021
    N2345 G3 X-2.3284 Y-1.5927 I-0.0002 J0.0094
    N2350 G1 Y-1.2109
    N2355 G3 X-2.3383 Y-1.2071 I-0.0057 J0.
    N2360 G2 X-2.7033 Y-1.4283 I-0.5418 J0.4822
    N2365 G3 X-2.7189 Y-1.4342 I0.0174 J-0.0696
    N2370 G2 X-2.8698 Y-1.4918 I-0.3263 J0.6285
    N2375 X-3.03 Y-1.5119 I-0.1602 J0.6266
    N2380 X-3.136 Y-1.511 I0. J6.2473
    N2385 G3 X-3.2421 Y-1.5101 I-0.106 J-6.2464
    N2390 X-3.2548 Y-1.5229 I0. J-0.0128
    N2395 G1 Y-1.5927
    N2400 G3 X-3.2455 Y-1.6021 I0.0094 J0.
    N2405 G1 X-2.2177
    N2410 G3 X-2.2083 Y-1.5927 I0. J0.0094
    N2415 G1 Y-1.0428
    N2420 G3 X-2.2211 Y-1.0301 I-0.0128 J0.
    N2425 G1 X-2.3409
    N2430 G3 X-2.3658 Y-1.0439 I0. J-0.0293
    N2435 G2 X-2.7421 Y-1.3142 I-0.513 J0.3173
    N2440 G3 X-2.7658 Y-1.3232 I0.0219 J-0.0933
    N2445 G2 X-2.8936 Y-1.374 I-0.2789 J0.5154
    N2450 X-3.03 Y-1.3919 I-0.1364 J0.511
    N2455 X-3.1961 Y-1.391 I0. J15.3236
    N2460 G3 X-3.3622 Y-1.3901 I-0.1661 J-15.3227
    N2465 X-3.3749 Y-1.4028 I0. J-0.0128
    N2470 G1 Y-1.5926
    N2475 G3 X-3.3656 Y-1.602 I0.0094 J0.
    N2480 G1 X-2.0656 Y-1.6021
    N2485 G3 X-2.0563 Y-1.5927 I0. J0.0094
    N2490 G1 Y-0.8908
    N2495 G3 X-2.069 Y-0.878 I-0.0128 J0.
    N2500 G1 X-2.4389
    N2505 G3 X-2.4587 Y-0.8915 I0. J-0.0213
    N2510 G2 X-2.773 Y-1.1652 I-0.4216 J0.1668
    N2515 G3 X-2.8411 Y-1.191 I0.068 J-0.2823
    N2520 G2 X-2.9325 Y-1.227 I-0.2043 J0.3849
    N2525 X-3.03 Y-1.2398 I-0.0975 J0.3636
    N2530 G1 X-3.5142 Y-1.238
    N2535 G3 X-3.527 Y-1.2508 I0. J-0.0128
    N2540 G1 Y-1.5927
    N2545 G3 X-3.5176 Y-1.6021 I0.0094 J0.
    N2550 G1 X-1.9136 Y-1.602
    N2555 G3 X-1.9042 Y-1.5926 I0. J0.0094
    N2560 G1 Y-0.7388
    N2565 G3 X-1.917 Y-0.726 I-0.0128 J0.
    N2570 G1 X-2.5661
    N2575 G3 X-2.5793 Y-0.7387 I0. J-0.0133
    N2580 G2 X-2.8423 Y-1.0236 I-0.2998 J0.0129
    N2585 G3 X-2.8857 Y-1.0403 I0.0118 J-0.0951
    N2590 G2 X-2.9542 Y-1.0752 I-0.1563 J0.2224
    N2595 X-3.03 Y-1.0878 I-0.0758 J0.2222
    N2600 G1 X-3.6662 Y-1.086
    N2605 G3 X-3.679 Y-1.0988 I0. J-0.0128
    N2610 G1 Y-1.5927
    N2615 G3 X-3.6696 Y-1.6021 I0.0094 J0.
    N2620 G1 X-1.7613
    N2625 G3 X-1.752 Y-1.5927 I0. J0.0094
    N2630 G1 Y-0.5737
    N2635 X-2.7312
    N2640 Y-0.725
    N2645 G2 X-2.88 Y-0.8737 I-0.1488 J0.
    N2650 G1 X-2.9392
    N2655 G2 X-3.03 Y-0.9337 I-0.0908 J0.0387
    N2660 G1 X-3.8312
    N2665 Y-1.37
    N2670 Y-1.5927
    N2675 G3 X-3.831 Y-1.5956 I0.0187 J0.
    N2680 G1 X-3.8282 Y-1.6137
    N2685 X-3.8276 Y-1.6169 Z1.3703
    N2690 X-3.8271 Y-1.62 Z1.3711
    N2695 X-3.8267 Y-1.6229 Z1.3725
    N2700 X-3.8263 Y-1.6256 Z1.3744
    N2705 X-3.8259 Y-1.6279 Z1.3767
    N2710 X-3.8256 Y-1.6297 Z1.3794
    N2715 X-3.8254 Y-1.6311 Z1.3823
    N2720 X-3.8253 Y-1.6319 Z1.3855
    N2725 X-3.8252 Y-1.6322 Z1.3887
    N2730 G0 Z2.1
    N2735 G1 X-3.423 Y-1.6321 F500.
    N2740 G0 Z1.7
    N2745 G1 Z1.4487 F15.
    N2750 G19 G3 Y-1.6134 Z1.43 J0.0187 K0.
    N2755 G1 Y-1.5927
    N2760 Y-0.6608
    N2765 G17 G3 X-3.4358 Y-0.648 I-0.0128 J0.
    N2770 G1 X-3.4892
    N2775 G3 X-3.502 Y-0.6608 I0. J-0.0128
    N2780 G1 Y-1.5926
    N2785 G3 X-3.4926 Y-1.602 I0.0094 J0.
    N2790 G1 X-3.2804
    N2795 G3 X-3.271 Y-1.5926 I0. J0.0094
    N2800 G1 Y-0.5088
    N2805 G3 X-3.2838 Y-0.496 I-0.0128 J0.
    N2810 G1 X-3.6412
    N2815 G3 X-3.654 Y-0.5088 I0. J-0.0128
    N2820 G1 Y-1.5927
    N2825 G3 X-3.6446 Y-1.6021 I0.0094 J0.
    N2830 G1 X-3.1281
    N2835 G3 X-3.1187 Y-1.5927 I0. J0.0094
    N2840 G1 Y-0.775
    N2845 Y-0.3438
    N2850 X-3.8062
    N2855 Y-1.5927
    N2860 G3 X-3.806 Y-1.5957 I0.0187 J0.
    N2865 G1 X-3.8032 Y-1.6137
    N2870 X-3.8026 Y-1.617 Z1.4303
    N2875 X-3.8022 Y-1.6201 Z1.4311
    N2880 X-3.8017 Y-1.623 Z1.4325
    N2885 X-3.8013 Y-1.6256 Z1.4344
    N2890 X-3.8009 Y-1.6279 Z1.4367
    N2895 X-3.8006 Y-1.6298 Z1.4394
    N2900 X-3.8004 Y-1.6311 Z1.4423
    N2905 X-3.8003 Y-1.632 Z1.4455
    N2910 X-3.8002 Y-1.6323 Z1.4487
    N2915 G0 Z2.1
    N2920 G1 X-3.502 Y1.6318 F500.
    N2925 G0 Z1.7
    N2930 G1 Z1.4487 F15.
    N2935 G19 G2 Y1.613 Z1.43 J-0.0187 K0.
    N2940 G1 Y1.5927
    N2945 Y0.6608
    N2950 G17 G3 X-3.4892 Y0.648 I0.0128 J0.
    N2955 G1 X-3.4358
    N2960 G3 X-3.423 Y0.6608 I0. J0.0128
    N2965 G1 Y1.5926
    N2970 G3 X-3.4324 Y1.602 I-0.0094 J0.
    N2975 G1 X-3.6446
    N2980 G3 X-3.654 Y1.5926 I0. J-0.0094
    N2985 G1 Y0.5088
    N2990 G3 X-3.6412 Y0.496 I0.0128 J0.
    N2995 G1 X-3.2838
    N3000 G3 X-3.271 Y0.5088 I0. J0.0128
    N3005 G1 Y1.5927
    N3010 G3 X-3.2804 Y1.6021 I-0.0094 J0.
    N3015 G1 X-3.7969
    N3020 G3 X-3.8062 Y1.5927 I0. J-0.0094
    N3025 G1 Y0.835
    N3030 Y0.3437
    N3035 X-3.1187
    N3040 Y1.5927
    N3045 G3 X-3.119 Y1.5956 I-0.0187 J0.
    N3050 G1 X-3.1218 Y1.6137
    N3055 X-3.1224 Y1.6169 Z1.4303
    N3060 X-3.1228 Y1.62 Z1.4311
    N3065 X-3.1233 Y1.623 Z1.4325
    N3070 X-3.1237 Y1.6256 Z1.4344
    N3075 X-3.1241 Y1.6279 Z1.4367
    N3080 X-3.1244 Y1.6297 Z1.4394
    N3085 X-3.1246 Y1.6311 Z1.4423
    N3090 X-3.1247 Y1.6319 Z1.4455
    N3095 X-3.1248 Y1.6322 Z1.4487
    N3100 G0 Z2.1
    N3105 G53 G0 Z0.
    N3115 M11
    N3120 G0 A180.
    N3125 M10
    N3135 G0 X-2.7707 Y1.6
    N3140 G43 Z2.1 H8
    N3145 G0 Z1.7
    N3150 G1 Z1.5394 F15.
    N3155 Z1.3887
    N3160 X-2.7704 Y1.5999 Z1.3855
    N3165 X-2.7696 Y1.5996 Z1.3823
    N3170 X-2.7683 Y1.5991 Z1.3794
    N3175 X-2.7665 Y1.5984 Z1.3767
    N3180 X-2.7644 Y1.5976 Z1.3744
    N3185 X-2.7619 Y1.5967 Z1.3725
    N3190 X-2.7591 Y1.5956 Z1.3711
    N3195 X-2.7561 Y1.5945 Z1.3703
    N3200 X-2.7531 Y1.5934 Z1.37
    N3205 X-2.7513 Y1.5927
    N3210 G2 X-2.6727 Y1.5588 I-0.2945 J-0.7899
    N3215 G3 X-2.6554 Y1.5522 I0.0424 J0.0859
    N3220 G2 X-2.4715 Y1.4786 I-0.2263 J-0.8315
    N3225 G3 X-2.4604 Y1.4852 I0.0036 J0.0066
    N3230 G1 Y1.5927
    N3235 G3 X-2.4698 Y1.6021 I-0.0094 J0.
    N3240 G1 X-3.2455
    N3245 G3 X-3.2548 Y1.5927 I0. J-0.0094
    N3250 G1 Y1.5229
    N3255 G3 X-3.2421 Y1.5102 I0.0128 J0.
    N3260 X-3.136 Y1.5111 I0. J6.2473
    N3265 G2 X-3.03 Y1.512 I0.106 J-6.2464
    N3270 X-2.871 Y1.4921 I0. J-0.6463
    N3275 X-2.7211 Y1.4354 I-0.1744 J-0.6869
    N3280 G3 X-2.7009 Y1.4277 I0.0438 J0.0852
    N3285 G2 X-2.3383 Y1.2071 I-0.1785 J-0.7018
    N3290 G3 X-2.3284 Y1.2109 I0.0042 J0.0038
    N3295 G1 Y1.5927
    N3300 G3 X-2.3377 Y1.6021 I-0.0094 J0.
    N3305 G1 X-3.3656
    N3310 G3 X-3.3749 Y1.5927 I0. J-0.0094
    N3315 G1 Y1.4028
    N3320 G3 X-3.3622 Y1.3901 I0.0128 J0.
    N3325 X-3.1961 Y1.391 I0. J15.3236
    N3330 G2 X-3.03 Y1.3919 I0.1661 J-15.3227
    N3335 X-2.8936 Y1.374 I0. J-0.5289
    N3340 X-2.7658 Y1.3232 I-0.1511 J-0.5662
    N3345 G3 X-2.7421 Y1.3142 I0.0456 J0.0843
    N3350 G2 X-2.3658 Y1.044 I-0.139 J-0.5908
    N3355 G3 X-2.3409 Y1.0301 I0.0249 J0.0154
    N3360 G1 X-2.2211
    N3365 G3 X-2.2083 Y1.0428 I0. J0.0128
    N3370 G1 Y1.5927
    N3375 G3 X-2.2177 Y1.6021 I-0.0094 J0.
    N3380 G1 X-3.5176
    N3385 G3 X-3.527 Y1.5927 I0. J-0.0094
    N3390 G1 Y1.2508
    N3395 G3 X-3.5142 Y1.238 I0.0128 J0.
    N3400 G1 X-3.03 Y1.2398
    N3405 G2 X-2.9325 Y1.227 I0. J-0.3765
    N3410 X-2.8411 Y1.191 I-0.1128 J-0.4209
    N3415 G3 X-2.773 Y1.1652 I0.1361 J0.2565
    N3420 G2 X-2.4587 Y0.8915 I-0.1057 J-0.4387
    N3425 G3 X-2.4389 Y0.878 I0.0198 J0.0078
    N3430 G1 X-2.069
    N3435 G3 X-2.0563 Y0.8908 I0. J0.0128
    N3440 G1 Y1.5927
    N3445 G3 X-2.0656 Y1.6021 I-0.0094 J0.
    N3450 G1 X-3.6696
    N3455 G3 X-3.679 Y1.5927 I0. J-0.0094
    N3460 G1 Y1.0988
    N3465 G3 X-3.6662 Y1.086 I0.0128 J0.
    N3470 G1 X-3.03 Y1.0878
    N3475 G2 X-2.9541 Y1.0752 I0. J-0.2348
    N3480 X-2.8856 Y1.0403 I-0.0878 J-0.2572
    N3485 G3 X-2.8424 Y1.0236 I0.0549 J0.0781
    N3490 G2 X-2.5793 Y0.7387 I-0.0368 J-0.2979
    N3495 G3 X-2.5661 Y0.726 I0.0133 J0.0006
    N3500 G1 X-1.917
    N3505 G3 X-1.9042 Y0.7388 I0. J0.0128
    N3510 G1 Y1.5927
    N3515 G3 X-1.9136 Y1.6021 I-0.0094 J0.
    N3520 G1 X-3.8219
    N3525 G3 X-3.8312 Y1.5927 I0. J-0.0094
    N3530 G1 Y0.9338
    N3535 X-3.03
    N3540 G2 X-2.9392 Y0.8738 I0. J-0.0987
    N3545 G1 X-2.88
    N3550 G2 X-2.7312 Y0.725 I0. J-0.1487
    N3555 G1 Y0.5738
    N3560 X-1.752
    N3565 Y1.37
    N3570 Y1.5927
    N3575 G3 X-1.7522 Y1.5956 I-0.0187 J0.
    N3580 G1 X-1.7551 Y1.6137
    N3585 X-1.7556 Y1.6169 Z1.3703
    N3590 X-1.7561 Y1.62 Z1.3711
    N3595 X-1.7565 Y1.6229 Z1.3725
    N3600 X-1.757 Y1.6256 Z1.3744
    N3605 X-1.7573 Y1.6279 Z1.3767
    N3610 X-1.7576 Y1.6297 Z1.3794
    N3615 X-1.7578 Y1.6311 Z1.3823
    N3620 X-1.758 Y1.6319 Z1.3855
    N3625 Y1.6322 Z1.3887
    N3630 G0 Z2.1
    N3635 G1 X-2.4604 Y-1.6321 F500.
    N3640 G0 Z1.7
    N3645 G1 Z1.3887 F15.
    N3650 G19 G3 Y-1.6134 Z1.37 J0.0187 K0.
    N3655 G1 Y-1.5927
    N3660 Y-1.4852
    N3665 G17 G3 X-2.4715 Y-1.4786 I-0.0076 J0.
    N3670 G2 X-2.6554 Y-1.5522 I-0.4074 J0.7511
    N3675 G3 X-2.6727 Y-1.5588 I0.0252 J-0.0924
    N3680 G2 X-2.7513 Y-1.5927 I-0.3732 J0.7559
    N3685 G3 X-2.7478 Y-1.6109 I0.0033 J-0.0088
    N3690 G1 X-2.3375 Y-1.6021
    N3695 G3 X-2.3284 Y-1.5927 I-0.0002 J0.0094
    N3700 G1 Y-1.2109
    N3705 G3 X-2.3383 Y-1.2071 I-0.0057 J0.
    N3710 G2 X-2.7033 Y-1.4283 I-0.5418 J0.4822
    N3715 G3 X-2.7189 Y-1.4342 I0.0174 J-0.0696
    N3720 G2 X-2.8698 Y-1.4918 I-0.3263 J0.6285
    N3725 X-3.03 Y-1.5119 I-0.1602 J0.6266
    N3730 X-3.136 Y-1.511 I0. J6.2473
    N3735 G3 X-3.2421 Y-1.5101 I-0.106 J-6.2464
    N3740 X-3.2548 Y-1.5229 I0. J-0.0128
    N3745 G1 Y-1.5927
    N3750 G3 X-3.2455 Y-1.6021 I0.0094 J0.
    N3755 G1 X-2.2177
    N3760 G3 X-2.2083 Y-1.5927 I0. J0.0094
    N3765 G1 Y-1.0428
    N3770 G3 X-2.2211 Y-1.0301 I-0.0128 J0.
    N3775 G1 X-2.3409
    N3780 G3 X-2.3658 Y-1.0439 I0. J-0.0293
    N3785 G2 X-2.7421 Y-1.3142 I-0.513 J0.3173
    N3790 G3 X-2.7658 Y-1.3232 I0.0219 J-0.0933
    N3795 G2 X-2.8936 Y-1.374 I-0.2789 J0.5154
    N3800 X-3.03 Y-1.3919 I-0.1364 J0.511
    N3805 X-3.1961 Y-1.391 I0. J15.3236
    N3810 G3 X-3.3622 Y-1.3901 I-0.1661 J-15.3227
    N3815 X-3.3749 Y-1.4028 I0. J-0.0128
    N3820 G1 Y-1.5926
    N3825 G3 X-3.3656 Y-1.602 I0.0094 J0.
    N3830 G1 X-2.0656 Y-1.6021
    N3835 G3 X-2.0563 Y-1.5927 I0. J0.0094
    N3840 G1 Y-0.8908
    N3845 G3 X-2.069 Y-0.878 I-0.0128 J0.
    N3850 G1 X-2.4389
    N3855 G3 X-2.4587 Y-0.8915 I0. J-0.0213
    N3860 G2 X-2.773 Y-1.1652 I-0.4216 J0.1668
    N3865 G3 X-2.8411 Y-1.191 I0.068 J-0.2823
    N3870 G2 X-2.9325 Y-1.227 I-0.2043 J0.3849
    N3875 X-3.03 Y-1.2398 I-0.0975 J0.3636
    N3880 G1 X-3.5142 Y-1.238
    N3885 G3 X-3.527 Y-1.2508 I0. J-0.0128
    N3890 G1 Y-1.5927
    N3895 G3 X-3.5176 Y-1.6021 I0.0094 J0.
    N3900 G1 X-1.9136 Y-1.602
    N3905 G3 X-1.9042 Y-1.5926 I0. J0.0094
    N3910 G1 Y-0.7388
    N3915 G3 X-1.917 Y-0.726 I-0.0128 J0.
    N3920 G1 X-2.5661
    N3925 G3 X-2.5793 Y-0.7387 I0. J-0.0133
    N3930 G2 X-2.8423 Y-1.0236 I-0.2998 J0.0129
    N3935 G3 X-2.8857 Y-1.0403 I0.0118 J-0.0951
    N3940 G2 X-2.9542 Y-1.0752 I-0.1563 J0.2224
    N3945 X-3.03 Y-1.0878 I-0.0758 J0.2222
    N3950 G1 X-3.6662 Y-1.086
    N3955 G3 X-3.679 Y-1.0988 I0. J-0.0128
    N3960 G1 Y-1.5927
    N3965 G3 X-3.6696 Y-1.6021 I0.0094 J0.
    N3970 G1 X-1.7613
    N3975 G3 X-1.752 Y-1.5927 I0. J0.0094
    N3980 G1 Y-0.5737
    N3985 X-2.7312
    N3990 Y-0.725
    N3995 G2 X-2.88 Y-0.8737 I-0.1488 J0.
    N4000 G1 X-2.9392
    N4005 G2 X-3.03 Y-0.9337 I-0.0908 J0.0387
    N4010 G1 X-3.8312
    N4015 Y-1.37
    N4020 Y-1.5927
    N4025 G3 X-3.831 Y-1.5956 I0.0187 J0.
    N4030 G1 X-3.8282 Y-1.6137
    N4035 X-3.8276 Y-1.6169 Z1.3703
    N4040 X-3.8271 Y-1.62 Z1.3711
    N4045 X-3.8267 Y-1.6229 Z1.3725
    N4050 X-3.8263 Y-1.6256 Z1.3744
    N4055 X-3.8259 Y-1.6279 Z1.3767
    N4060 X-3.8256 Y-1.6297 Z1.3794
    N4065 X-3.8254 Y-1.6311 Z1.3823
    N4070 X-3.8253 Y-1.6319 Z1.3855
    N4075 X-3.8252 Y-1.6322 Z1.3887
    N4080 G0 Z2.1
    N4085 G1 X-3.423 Y-1.6321 F500.
    N4090 G0 Z1.7
    N4095 G1 Z1.4487 F15.
    N4100 G19 G3 Y-1.6134 Z1.43 J0.0187 K0.
    N4105 G1 Y-1.5927
    N4110 Y-0.6608
    N4115 G17 G3 X-3.4358 Y-0.648 I-0.0128 J0.
    N4120 G1 X-3.4892
    N4125 G3 X-3.502 Y-0.6608 I0. J-0.0128
    N4130 G1 Y-1.5926
    N4135 G3 X-3.4926 Y-1.602 I0.0094 J0.
    N4140 G1 X-3.2804
    N4145 G3 X-3.271 Y-1.5926 I0. J0.0094
    N4150 G1 Y-0.5088
    N4155 G3 X-3.2838 Y-0.496 I-0.0128 J0.
    N4160 G1 X-3.6412
    N4165 G3 X-3.654 Y-0.5088 I0. J-0.0128
    N4170 G1 Y-1.5927
    N4175 G3 X-3.6446 Y-1.6021 I0.0094 J0.
    N4180 G1 X-3.1281
    N4185 G3 X-3.1187 Y-1.5927 I0. J0.0094
    N4190 G1 Y-0.775
    N4195 Y-0.3438
    N4200 X-3.8062
    N4205 Y-1.5927
    N4210 G3 X-3.806 Y-1.5957 I0.0187 J0.
    N4215 G1 X-3.8032 Y-1.6137
    N4220 X-3.8026 Y-1.617 Z1.4303
    N4225 X-3.8022 Y-1.6201 Z1.4311
    N4230 X-3.8017 Y-1.623 Z1.4325
    N4235 X-3.8013 Y-1.6256 Z1.4344
    N4240 X-3.8009 Y-1.6279 Z1.4367
    N4245 X-3.8006 Y-1.6298 Z1.4394
    N4250 X-3.8004 Y-1.6311 Z1.4423
    N4255 X-3.8003 Y-1.632 Z1.4455
    N4260 X-3.8002 Y-1.6323 Z1.4487
    N4265 G0 Z2.1
    N4270 G1 X-3.502 Y1.6318 F500.
    N4275 G0 Z1.7
    N4280 G1 Z1.4487 F15.
    N4285 G19 G2 Y1.613 Z1.43 J-0.0187 K0.
    N4290 G1 Y1.5927
    N4295 Y0.6608
    N4300 G17 G3 X-3.4892 Y0.648 I0.0128 J0.
    N4305 G1 X-3.4358
    N4310 G3 X-3.423 Y0.6608 I0. J0.0128
    N4315 G1 Y1.5926
    N4320 G3 X-3.4324 Y1.602 I-0.0094 J0.
    N4325 G1 X-3.6446
    N4330 G3 X-3.654 Y1.5926 I0. J-0.0094
    N4335 G1 Y0.5088
    N4340 G3 X-3.6412 Y0.496 I0.0128 J0.
    N4345 G1 X-3.2838
    N4350 G3 X-3.271 Y0.5088 I0. J0.0128
    N4355 G1 Y1.5927
    N4360 G3 X-3.2804 Y1.6021 I-0.0094 J0.
    N4365 G1 X-3.7969
    N4370 G3 X-3.8062 Y1.5927 I0. J-0.0094
    N4375 G1 Y0.835
    N4380 Y0.3437
    N4385 X-3.1187
    N4390 Y1.5927
    N4395 G3 X-3.119 Y1.5956 I-0.0187 J0.
    N4400 G1 X-3.1218 Y1.6137
    N4405 X-3.1224 Y1.6169 Z1.4303
    N4410 X-3.1228 Y1.62 Z1.4311
    N4415 X-3.1233 Y1.623 Z1.4325
    N4420 X-3.1237 Y1.6256 Z1.4344
    N4425 X-3.1241 Y1.6279 Z1.4367
    N4430 X-3.1244 Y1.6297 Z1.4394
    N4435 X-3.1246 Y1.6311 Z1.4423
    N4440 X-3.1247 Y1.6319 Z1.4455
    N4445 X-3.1248 Y1.6322 Z1.4487
    N4450 G0 Z2.1
    N4455 G53 G0 Z0.
    N4465 M11
    N4470 G0 A90.
    N4475 M10
    N4485 G0 X-2.7707 Y1.6
    N4490 G43 Z2.1 H8
    N4495 G0 Z1.7
    N4500 G1 Z1.5394 F15.
    N4505 Z1.3887
    N4510 X-2.7704 Y1.5999 Z1.3855
    N4515 X-2.7696 Y1.5996 Z1.3823
    N4520 X-2.7683 Y1.5991 Z1.3794
    N4525 X-2.7665 Y1.5984 Z1.3767
    N4530 X-2.7644 Y1.5976 Z1.3744
    N4535 X-2.7619 Y1.5967 Z1.3725
    N4540 X-2.7591 Y1.5956 Z1.3711
    N4545 X-2.7561 Y1.5945 Z1.3703
    N4550 X-2.7531 Y1.5934 Z1.37
    N4555 X-2.7513 Y1.5927
    N4560 G2 X-2.6727 Y1.5588 I-0.2945 J-0.7899
    N4565 G3 X-2.6554 Y1.5522 I0.0424 J0.0859
    N4570 G2 X-2.4715 Y1.4786 I-0.2263 J-0.8315
    N4575 G3 X-2.4604 Y1.4852 I0.0036 J0.0066
    N4580 G1 Y1.5927
    N4585 G3 X-2.4698 Y1.6021 I-0.0094 J0.
    N4590 G1 X-3.2455
    N4595 G3 X-3.2548 Y1.5927 I0. J-0.0094
    N4600 G1 Y1.5229
    N4605 G3 X-3.2421 Y1.5102 I0.0128 J0.
    N4610 X-3.136 Y1.5111 I0. J6.2473
    N4615 G2 X-3.03 Y1.512 I0.106 J-6.2464
    N4620 X-2.871 Y1.4921 I0. J-0.6463
    N4625 X-2.7211 Y1.4354 I-0.1744 J-0.6869
    N4630 G3 X-2.7009 Y1.4277 I0.0438 J0.0852
    N4635 G2 X-2.3383 Y1.2071 I-0.1785 J-0.7018
    N4640 G3 X-2.3284 Y1.2109 I0.0042 J0.0038
    N4645 G1 Y1.5927
    N4650 G3 X-2.3377 Y1.6021 I-0.0094 J0.
    N4655 G1 X-3.3656
    N4660 G3 X-3.3749 Y1.5927 I0. J-0.0094
    N4665 G1 Y1.4028
    N4670 G3 X-3.3622 Y1.3901 I0.0128 J0.
    N4675 X-3.1961 Y1.391 I0. J15.3236
    N4680 G2 X-3.03 Y1.3919 I0.1661 J-15.3227
    N4685 X-2.8936 Y1.374 I0. J-0.5289
    N4690 X-2.7658 Y1.3232 I-0.1511 J-0.5662
    N4695 G3 X-2.7421 Y1.3142 I0.0456 J0.0843
    N4700 G2 X-2.3658 Y1.044 I-0.139 J-0.5908
    N4705 G3 X-2.3409 Y1.0301 I0.0249 J0.0154
    N4710 G1 X-2.2211
    N4715 G3 X-2.2083 Y1.0428 I0. J0.0128
    N4720 G1 Y1.5927
    N4725 G3 X-2.2177 Y1.6021 I-0.0094 J0.
    N4730 G1 X-3.5176
    N4735 G3 X-3.527 Y1.5927 I0. J-0.0094
    N4740 G1 Y1.2508
    N4745 G3 X-3.5142 Y1.238 I0.0128 J0.
    N4750 G1 X-3.03 Y1.2398
    N4755 G2 X-2.9325 Y1.227 I0. J-0.3765
    N4760 X-2.8411 Y1.191 I-0.1128 J-0.4209
    N4765 G3 X-2.773 Y1.1652 I0.1361 J0.2565
    N4770 G2 X-2.4587 Y0.8915 I-0.1057 J-0.4387
    N4775 G3 X-2.4389 Y0.878 I0.0198 J0.0078
    N4780 G1 X-2.069
    N4785 G3 X-2.0563 Y0.8908 I0. J0.0128
    N4790 G1 Y1.5927
    N4795 G3 X-2.0656 Y1.6021 I-0.0094 J0.
    N4800 G1 X-3.6696
    N4805 G3 X-3.679 Y1.5927 I0. J-0.0094
    N4810 G1 Y1.0988
    N4815 G3 X-3.6662 Y1.086 I0.0128 J0.
    N4820 G1 X-3.03 Y1.0878
    N4825 G2 X-2.9541 Y1.0752 I0. J-0.2348
    N4830 X-2.8856 Y1.0403 I-0.0878 J-0.2572
    N4835 G3 X-2.8424 Y1.0236 I0.0549 J0.0781
    N4840 G2 X-2.5793 Y0.7387 I-0.0368 J-0.2979
    N4845 G3 X-2.5661 Y0.726 I0.0133 J0.0006
    N4850 G1 X-1.917
    N4855 G3 X-1.9042 Y0.7388 I0. J0.0128
    N4860 G1 Y1.5927
    N4865 G3 X-1.9136 Y1.6021 I-0.0094 J0.
    N4870 G1 X-3.8219
    N4875 G3 X-3.8312 Y1.5927 I0. J-0.0094
    N4880 G1 Y0.9338
    N4885 X-3.03
    N4890 G2 X-2.9392 Y0.8738 I0. J-0.0987
    N4895 G1 X-2.88
    N4900 G2 X-2.7312 Y0.725 I0. J-0.1487
    N4905 G1 Y0.5738
    N4910 X-1.752
    N4915 Y1.37
    N4920 Y1.5927
    N4925 G3 X-1.7522 Y1.5956 I-0.0187 J0.
    N4930 G1 X-1.7551 Y1.6137
    N4935 X-1.7556 Y1.6169 Z1.3703
    N4940 X-1.7561 Y1.62 Z1.3711
    N4945 X-1.7565 Y1.6229 Z1.3725
    N4950 X-1.757 Y1.6256 Z1.3744
    N4955 X-1.7573 Y1.6279 Z1.3767
    N4960 X-1.7576 Y1.6297 Z1.3794
    N4965 X-1.7578 Y1.6311 Z1.3823
    N4970 X-1.758 Y1.6319 Z1.3855
    N4975 Y1.6322 Z1.3887
    N4980 G0 Z2.1
    N4985 G1 X-2.4604 Y-1.6321 F500.
    N4990 G0 Z1.7
    N4995 G1 Z1.3887 F15.
    N5000 G19 G3 Y-1.6134 Z1.37 J0.0187 K0.
    N5005 G1 Y-1.5927
    N5010 Y-1.4852
    N5015 G17 G3 X-2.4715 Y-1.4786 I-0.0076 J0.
    N5020 G2 X-2.6554 Y-1.5522 I-0.4074 J0.7511
    N5025 G3 X-2.6727 Y-1.5588 I0.0252 J-0.0924
    N5030 G2 X-2.7513 Y-1.5927 I-0.3732 J0.7559
    N5035 G3 X-2.7478 Y-1.6109 I0.0033 J-0.0088
    N5040 G1 X-2.3375 Y-1.6021
    N5045 G3 X-2.3284 Y-1.5927 I-0.0002 J0.0094
    N5050 G1 Y-1.2109
    N5055 G3 X-2.3383 Y-1.2071 I-0.0057 J0.
    N5060 G2 X-2.7033 Y-1.4283 I-0.5418 J0.4822
    N5065 G3 X-2.7189 Y-1.4342 I0.0174 J-0.0696
    N5070 G2 X-2.8698 Y-1.4918 I-0.3263 J0.6285
    N5075 X-3.03 Y-1.5119 I-0.1602 J0.6266
    N5080 X-3.136 Y-1.511 I0. J6.2473
    N5085 G3 X-3.2421 Y-1.5101 I-0.106 J-6.2464
    N5090 X-3.2548 Y-1.5229 I0. J-0.0128
    N5095 G1 Y-1.5927
    N5100 G3 X-3.2455 Y-1.6021 I0.0094 J0.
    N5105 G1 X-2.2177
    N5110 G3 X-2.2083 Y-1.5927 I0. J0.0094
    N5115 G1 Y-1.0428
    N5120 G3 X-2.2211 Y-1.0301 I-0.0128 J0.
    N5125 G1 X-2.3409
    N5130 G3 X-2.3658 Y-1.0439 I0. J-0.0293
    N5135 G2 X-2.7421 Y-1.3142 I-0.513 J0.3173
    N5140 G3 X-2.7658 Y-1.3232 I0.0219 J-0.0933
    N5145 G2 X-2.8936 Y-1.374 I-0.2789 J0.5154
    N5150 X-3.03 Y-1.3919 I-0.1364 J0.511
    N5155 X-3.1961 Y-1.391 I0. J15.3236
    N5160 G3 X-3.3622 Y-1.3901 I-0.1661 J-15.3227
    N5165 X-3.3749 Y-1.4028 I0. J-0.0128
    N5170 G1 Y-1.5926
    N5175 G3 X-3.3656 Y-1.602 I0.0094 J0.
    N5180 G1 X-2.0656 Y-1.6021
    N5185 G3 X-2.0563 Y-1.5927 I0. J0.0094
    N5190 G1 Y-0.8908
    N5195 G3 X-2.069 Y-0.878 I-0.0128 J0.
    N5200 G1 X-2.4389
    N5205 G3 X-2.4587 Y-0.8915 I0. J-0.0213
    N5210 G2 X-2.773 Y-1.1652 I-0.4216 J0.1668
    N5215 G3 X-2.8411 Y-1.191 I0.068 J-0.2823
    N5220 G2 X-2.9325 Y-1.227 I-0.2043 J0.3849
    N5225 X-3.03 Y-1.2398 I-0.0975 J0.3636
    N5230 G1 X-3.5142 Y-1.238
    N5235 G3 X-3.527 Y-1.2508 I0. J-0.0128
    N5240 G1 Y-1.5927
    N5245 G3 X-3.5176 Y-1.6021 I0.0094 J0.
    N5250 G1 X-1.9136 Y-1.602
    N5255 G3 X-1.9042 Y-1.5926 I0. J0.0094
    N5260 G1 Y-0.7388
    N5265 G3 X-1.917 Y-0.726 I-0.0128 J0.
    N5270 G1 X-2.5661
    N5275 G3 X-2.5793 Y-0.7387 I0. J-0.0133
    N5280 G2 X-2.8423 Y-1.0236 I-0.2998 J0.0129
    N5285 G3 X-2.8857 Y-1.0403 I0.0118 J-0.0951
    N5290 G2 X-2.9542 Y-1.0752 I-0.1563 J0.2224
    N5295 X-3.03 Y-1.0878 I-0.0758 J0.2222
    N5300 G1 X-3.6662 Y-1.086
    N5305 G3 X-3.679 Y-1.0988 I0. J-0.0128
    N5310 G1 Y-1.5927
    N5315 G3 X-3.6696 Y-1.6021 I0.0094 J0.
    N5320 G1 X-1.7613
    N5325 G3 X-1.752 Y-1.5927 I0. J0.0094
    N5330 G1 Y-0.5737
    N5335 X-2.7312
    N5340 Y-0.725
    N5345 G2 X-2.88 Y-0.8737 I-0.1488 J0.
    N5350 G1 X-2.9392
    N5355 G2 X-3.03 Y-0.9337 I-0.0908 J0.0387
    N5360 G1 X-3.8312
    N5365 Y-1.37
    N5370 Y-1.5927
    N5375 G3 X-3.831 Y-1.5956 I0.0187 J0.
    N5380 G1 X-3.8282 Y-1.6137
    N5385 X-3.8276 Y-1.6169 Z1.3703
    N5390 X-3.8271 Y-1.62 Z1.3711
    N5395 X-3.8267 Y-1.6229 Z1.3725
    N5400 X-3.8263 Y-1.6256 Z1.3744
    N5405 X-3.8259 Y-1.6279 Z1.3767
    N5410 X-3.8256 Y-1.6297 Z1.3794
    N5415 X-3.8254 Y-1.6311 Z1.3823
    N5420 X-3.8253 Y-1.6319 Z1.3855
    N5425 X-3.8252 Y-1.6322 Z1.3887
    N5430 G0 Z2.1
    N5435 G1 X-3.423 Y-1.6321 F500.
    N5440 G0 Z1.7
    N5445 G1 Z1.4487 F15.
    N5450 G19 G3 Y-1.6134 Z1.43 J0.0187 K0.
    N5455 G1 Y-1.5927
    N5460 Y-0.6608
    N5465 G17 G3 X-3.4358 Y-0.648 I-0.0128 J0.
    N5470 G1 X-3.4892
    N5475 G3 X-3.502 Y-0.6608 I0. J-0.0128
    N5480 G1 Y-1.5926
    N5485 G3 X-3.4926 Y-1.602 I0.0094 J0.
    N5490 G1 X-3.2804
    N5495 G3 X-3.271 Y-1.5926 I0. J0.0094
    N5500 G1 Y-0.5088
    N5505 G3 X-3.2838 Y-0.496 I-0.0128 J0.
    N5510 G1 X-3.6412
    N5515 G3 X-3.654 Y-0.5088 I0. J-0.0128
    N5520 G1 Y-1.5927
    N5525 G3 X-3.6446 Y-1.6021 I0.0094 J0.
    N5530 G1 X-3.1281
    N5535 G3 X-3.1187 Y-1.5927 I0. J0.0094
    N5540 G1 Y-0.775
    N5545 Y-0.3438
    N5550 X-3.8062
    N5555 Y-1.5927
    N5560 G3 X-3.806 Y-1.5957 I0.0187 J0.
    N5565 G1 X-3.8032 Y-1.6137
    N5570 X-3.8026 Y-1.617 Z1.4303
    N5575 X-3.8022 Y-1.6201 Z1.4311
    N5580 X-3.8017 Y-1.623 Z1.4325
    N5585 X-3.8013 Y-1.6256 Z1.4344
    N5590 X-3.8009 Y-1.6279 Z1.4367
    N5595 X-3.8006 Y-1.6298 Z1.4394
    N5600 X-3.8004 Y-1.6311 Z1.4423
    N5605 X-3.8003 Y-1.632 Z1.4455
    N5610 X-3.8002 Y-1.6323 Z1.4487
    N5615 G0 Z2.1
    N5620 G1 X-3.502 Y1.6318 F500.
    N5625 G0 Z1.7
    N5630 G1 Z1.4487 F15.
    N5635 G19 G2 Y1.613 Z1.43 J-0.0187 K0.
    N5640 G1 Y1.5927
    N5645 Y0.6608
    N5650 G17 G3 X-3.4892 Y0.648 I0.0128 J0.
    N5655 G1 X-3.4358
    N5660 G3 X-3.423 Y0.6608 I0. J0.0128
    N5665 G1 Y1.5926
    N5670 G3 X-3.4324 Y1.602 I-0.0094 J0.
    N5675 G1 X-3.6446
    N5680 G3 X-3.654 Y1.5926 I0. J-0.0094
    N5685 G1 Y0.5088
    N5690 G3 X-3.6412 Y0.496 I0.0128 J0.
    N5695 G1 X-3.2838
    N5700 G3 X-3.271 Y0.5088 I0. J0.0128
    N5705 G1 Y1.5927
    N5710 G3 X-3.2804 Y1.6021 I-0.0094 J0.
    N5715 G1 X-3.7969
    N5720 G3 X-3.8062 Y1.5927 I0. J-0.0094
    N5725 G1 Y0.835
    N5730 Y0.3437
    N5735 X-3.1187
    N5740 Y1.5927
    N5745 G3 X-3.119 Y1.5956 I-0.0187 J0.
    N5750 G1 X-3.1218 Y1.6137
    N5755 X-3.1224 Y1.6169 Z1.4303
    N5760 X-3.1228 Y1.62 Z1.4311
    N5765 X-3.1233 Y1.623 Z1.4325
    N5770 X-3.1237 Y1.6256 Z1.4344
    N5775 X-3.1241 Y1.6279 Z1.4367
    N5780 X-3.1244 Y1.6297 Z1.4394
    N5785 X-3.1246 Y1.6311 Z1.4423
    N5790 X-3.1247 Y1.6319 Z1.4455
    N5795 X-3.1248 Y1.6322 Z1.4487
    N5800 G0 Z2.1
    N5805 M5
    N5810 G53 G0 Z0.
    (2D .1094 Finish Top)
    N5820 M9
    N5825 M1
    N5830 T3 M6
    N5835 S6000 M3
    N5840 G54
    N5845 M11
    N5850 G0 A0.
    N5855 M10
    N5860 M8
    N5870 G0 X-3.8175 Y1.5652
    N5875 G43 Z2.1 H3
    N5880 T4
    N5885 G0 Z1.7
    N5890 G1 Z1.5394 F15.
    N5895 Z1.4409 F5.
    N5900 G18 G3 X-3.8284 Z1.43 I-0.0109 K0.
    N5905 G1 X-3.8394 F15.
    N5910 G17 G3 X-3.8503 Y1.5543 I0. J-0.0109
    N5915 G1 Y0.835
    N5920 Y0.2997
    N5925 X-3.0747
    N5930 Y1.5543
    N5935 G3 X-3.0856 Y1.5652 I-0.0109 J0.
    N5940 G1 X-3.0966
    N5945 G18 G3 X-3.1075 Z1.4409 I0. K0.0109
    N5950 G0 Z1.7
    N5955 Y-1.5652
    N5960 G1 Z1.5394 F5.
    N5965 Z1.4409
    N5970 G2 X-3.0966 Z1.43 I0.0109 K0.
    N5975 G1 X-3.0856 F15.
    N5980 G17 G3 X-3.0747 Y-1.5543 I0. J0.0109
    N5985 G1 Y-0.775
    N5990 Y-0.2997
    N5995 X-3.8503
    N6000 Y-1.5543
    N6005 G3 X-3.8394 Y-1.5652 I0.0109 J0.
    N6010 G1 X-3.8284
    N6015 G18 G2 X-3.8175 Z1.4409 I0. K0.0109
    N6020 G0 Z2.1
    N6025 X-1.7407
    N6030 Z1.7
    N6035 G1 Z1.5394 F15.
    N6040 Z1.3809 F5.
    N6045 G2 X-1.7298 Z1.37 I0.0109 K0.
    N6050 G1 X-1.7189 F15.
    N6055 G17 G3 X-1.7079 Y-1.5543 I0. J0.0109
    N6060 G1 Y-0.5297
    N6065 X-2.7753
    N6070 Y-0.725
    N6075 G2 X-2.88 Y-0.8297 I-0.1047 J0.
    N6080 G1 X-2.9753
    N6085 Y-0.835
    N6090 G2 X-3.03 Y-0.8897 I-0.0547 J0.
    N6095 G1 X-3.8753
    N6100 Y-1.37
    N6105 Y-1.5543
    N6110 G3 X-3.8644 Y-1.5652 I0.0109 J0.
    N6115 G1 X-3.8534
    N6120 G18 G2 X-3.8425 Z1.3809 I0. K0.0109
    N6125 G0 Z1.7
    N6130 Y1.5652
    N6135 G1 Z1.5394 F5.
    N6140 Z1.3809
    N6145 G3 X-3.8534 Z1.37 I-0.0109 K0.
    N6150 G1 X-3.8644 F15.
    N6155 G17 G3 X-3.8753 Y1.5543 I0. J-0.0109
    N6160 G1 Y0.8897
    N6165 X-3.03
    N6170 G2 X-2.9753 Y0.835 I0. J-0.0547
    N6175 G1 Y0.8297
    N6180 X-2.88
    N6185 G2 X-2.7753 Y0.725 I0. J-0.1047
    N6190 G1 Y0.5297
    N6195 X-1.7079
    N6200 Y1.37
    N6205 Y1.5543
    N6210 G3 X-1.7189 Y1.5652 I-0.0109 J0.
    N6215 G1 X-1.7298
    N6220 G18 G3 X-1.7407 Z1.3809 I0. K0.0109
    N6225 G0 Z2.1
    N6230 G53 G0 Z0.
    N6240 M11
    N6245 G0 A270.
    N6250 M10
    N6255 G17
    N6260 G0 X-3.8175 Y1.5652
    N6265 G43 Z2.1 H3
    N6270 G0 Z1.7
    N6275 G1 Z1.5394 F15.
    N6280 Z1.4409 F5.
    N6285 G18 G3 X-3.8284 Z1.43 I-0.0109 K0.
    N6290 G1 X-3.8394 F15.
    N6295 G17 G3 X-3.8503 Y1.5543 I0. J-0.0109
    N6300 G1 Y0.835
    N6305 Y0.2997
    N6310 X-3.0747
    N6315 Y1.5543
    N6320 G3 X-3.0856 Y1.5652 I-0.0109 J0.
    N6325 G1 X-3.0966
    N6330 G18 G3 X-3.1075 Z1.4409 I0. K0.0109
    N6335 G0 Z1.7
    N6340 Y-1.5652
    N6345 G1 Z1.5394 F5.
    N6350 Z1.4409
    N6355 G2 X-3.0966 Z1.43 I0.0109 K0.
    N6360 G1 X-3.0856 F15.
    N6365 G17 G3 X-3.0747 Y-1.5543 I0. J0.0109
    N6370 G1 Y-0.775
    N6375 Y-0.2997
    N6380 X-3.8503
    N6385 Y-1.5543
    N6390 G3 X-3.8394 Y-1.5652 I0.0109 J0.
    N6395 G1 X-3.8284
    N6400 G18 G2 X-3.8175 Z1.4409 I0. K0.0109
    N6405 G0 Z2.1
    N6410 X-1.7407
    N6415 Z1.7
    N6420 G1 Z1.5394 F15.
    N6425 Z1.3809 F5.
    N6430 G2 X-1.7298 Z1.37 I0.0109 K0.
    N6435 G1 X-1.7189 F15.
    N6440 G17 G3 X-1.7079 Y-1.5543 I0. J0.0109
    N6445 G1 Y-0.5297
    N6450 X-2.7753
    N6455 Y-0.725
    N6460 G2 X-2.88 Y-0.8297 I-0.1047 J0.
    N6465 G1 X-2.9753
    N6470 Y-0.835
    N6475 G2 X-3.03 Y-0.8897 I-0.0547 J0.
    N6480 G1 X-3.8753
    N6485 Y-1.37
    N6490 Y-1.5543
    N6495 G3 X-3.8644 Y-1.5652 I0.0109 J0.
    N6500 G1 X-3.8534
    N6505 G18 G2 X-3.8425 Z1.3809 I0. K0.0109
    N6510 G0 Z1.7
    N6515 Y1.5652
    N6520 G1 Z1.5394 F5.
    N6525 Z1.3809
    N6530 G3 X-3.8534 Z1.37 I-0.0109 K0.
    N6535 G1 X-3.8644 F15.
    N6540 G17 G3 X-3.8753 Y1.5543 I0. J-0.0109
    N6545 G1 Y0.8897
    N6550 X-3.03
    N6555 G2 X-2.9753 Y0.835 I0. J-0.0547
    N6560 G1 Y0.8297
    N6565 X-2.88
    N6570 G2 X-2.7753 Y0.725 I0. J-0.1047
    N6575 G1 Y0.5297
    N6580 X-1.7079
    N6585 Y1.37
    N6590 Y1.5543
    N6595 G3 X-1.7189 Y1.5652 I-0.0109 J0.
    N6600 G1 X-1.7298
    N6605 G18 G3 X-1.7407 Z1.3809 I0. K0.0109
    N6610 G0 Z2.1
    N6615 G53 G0 Z0.
    N6625 M11
    N6630 G0 A180.
    N6635 M10
    N6640 G17
    N6645 G0 X-3.8175 Y1.5652
    N6650 G43 Z2.1 H3
    N6655 G0 Z1.7
    N6660 G1 Z1.5394 F15.
    N6665 Z1.4409 F5.
    N6670 G18 G3 X-3.8284 Z1.43 I-0.0109 K0.
    N6675 G1 X-3.8394 F15.
    N6680 G17 G3 X-3.8503 Y1.5543 I0. J-0.0109
    N6685 G1 Y0.835
    N6690 Y0.2997
    N6695 X-3.0747
    N6700 Y1.5543
    N6705 G3 X-3.0856 Y1.5652 I-0.0109 J0.
    N6710 G1 X-3.0966
    N6715 G18 G3 X-3.1075 Z1.4409 I0. K0.0109
    N6720 G0 Z1.7
    N6725 Y-1.5652
    N6730 G1 Z1.5394 F5.
    N6735 Z1.4409
    N6740 G2 X-3.0966 Z1.43 I0.0109 K0.
    N6745 G1 X-3.0856 F15.
    N6750 G17 G3 X-3.0747 Y-1.5543 I0. J0.0109
    N6755 G1 Y-0.775
    N6760 Y-0.2997
    N6765 X-3.8503
    N6770 Y-1.5543
    N6775 G3 X-3.8394 Y-1.5652 I0.0109 J0.
    N6780 G1 X-3.8284
    N6785 G18 G2 X-3.8175 Z1.4409 I0. K0.0109
    N6790 G0 Z2.1
    N6795 X-1.7407
    N6800 Z1.7
    N6805 G1 Z1.5394 F15.
    N6810 Z1.3809 F5.
    N6815 G2 X-1.7298 Z1.37 I0.0109 K0.
    N6820 G1 X-1.7189 F15.
    N6825 G17 G3 X-1.7079 Y-1.5543 I0. J0.0109
    N6830 G1 Y-0.5297
    N6835 X-2.7753
    N6840 Y-0.725
    N6845 G2 X-2.88 Y-0.8297 I-0.1047 J0.
    N6850 G1 X-2.9753
    N6855 Y-0.835
    N6860 G2 X-3.03 Y-0.8897 I-0.0547 J0.
    N6865 G1 X-3.8753
    N6870 Y-1.37
    N6875 Y-1.5543
    N6880 G3 X-3.8644 Y-1.5652 I0.0109 J0.
    N6885 G1 X-3.8534
    N6890 G18 G2 X-3.8425 Z1.3809 I0. K0.0109
    N6895 G0 Z1.7
    N6900 Y1.5652
    N6905 G1 Z1.5394 F5.
    N6910 Z1.3809
    N6915 G3 X-3.8534 Z1.37 I-0.0109 K0.
    N6920 G1 X-3.8644 F15.
    N6925 G17 G3 X-3.8753 Y1.5543 I0. J-0.0109
    N6930 G1 Y0.8897
    N6935 X-3.03
    N6940 G2 X-2.9753 Y0.835 I0. J-0.0547
    N6945 G1 Y0.8297
    N6950 X-2.88
    N6955 G2 X-2.7753 Y0.725 I0. J-0.1047
    N6960 G1 Y0.5297
    N6965 X-1.7079
    N6970 Y1.37
    N6975 Y1.5543
    N6980 G3 X-1.7189 Y1.5652 I-0.0109 J0.
    N6985 G1 X-1.7298
    N6990 G18 G3 X-1.7407 Z1.3809 I0. K0.0109
    N6995 G0 Z2.1
    N7000 G53 G0 Z0.
    N7010 M11
    N7015 G0 A90.
    N7020 M10
    N7025 G17
    N7030 G0 X-3.8175 Y1.5652
    N7035 G43 Z2.1 H3
    N7040 G0 Z1.7
    N7045 G1 Z1.5394 F15.
    N7050 Z1.4409 F5.
    N7055 G18 G3 X-3.8284 Z1.43 I-0.0109 K0.
    N7060 G1 X-3.8394 F15.
    N7065 G17 G3 X-3.8503 Y1.5543 I0. J-0.0109
    N7070 G1 Y0.835
    N7075 Y0.2997
    N7080 X-3.0747
    N7085 Y1.5543
    N7090 G3 X-3.0856 Y1.5652 I-0.0109 J0.
    N7095 G1 X-3.0966
    N7100 G18 G3 X-3.1075 Z1.4409 I0. K0.0109
    N7105 G0 Z1.7
    N7110 Y-1.5652
    N7115 G1 Z1.5394 F5.
    N7120 Z1.4409
    N7125 G2 X-3.0966 Z1.43 I0.0109 K0.
    N7130 G1 X-3.0856 F15.
    N7135 G17 G3 X-3.0747 Y-1.5543 I0. J0.0109
    N7140 G1 Y-0.775
    N7145 Y-0.2997
    N7150 X-3.8503
    N7155 Y-1.5543
    N7160 G3 X-3.8394 Y-1.5652 I0.0109 J0.
    N7165 G1 X-3.8284
    N7170 G18 G2 X-3.8175 Z1.4409 I0. K0.0109
    N7175 G0 Z2.1
    N7180 X-1.7407
    N7185 Z1.7
    N7190 G1 Z1.5394 F15.
    N7195 Z1.3809 F5.
    N7200 G2 X-1.7298 Z1.37 I0.0109 K0.
    N7205 G1 X-1.7189 F15.
    N7210 G17 G3 X-1.7079 Y-1.5543 I0. J0.0109
    N7215 G1 Y-0.5297
    N7220 X-2.7753
    N7225 Y-0.725
    N7230 G2 X-2.88 Y-0.8297 I-0.1047 J0.
    N7235 G1 X-2.9753
    N7240 Y-0.835
    N7245 G2 X-3.03 Y-0.8897 I-0.0547 J0.
    N7250 G1 X-3.8753
    N7255 Y-1.37
    N7260 Y-1.5543
    N7265 G3 X-3.8644 Y-1.5652 I0.0109 J0.
    N7270 G1 X-3.8534
    N7275 G18 G2 X-3.8425 Z1.3809 I0. K0.0109
    N7280 G0 Z1.7
    N7285 Y1.5652
    N7290 G1 Z1.5394 F5.
    N7295 Z1.3809
    N7300 G3 X-3.8534 Z1.37 I-0.0109 K0.
    N7305 G1 X-3.8644 F15.
    N7310 G17 G3 X-3.8753 Y1.5543 I0. J-0.0109
    N7315 G1 Y0.8897
    N7320 X-3.03
    N7325 G2 X-2.9753 Y0.835 I0. J-0.0547
    N7330 G1 Y0.8297
    N7335 X-2.88
    N7340 G2 X-2.7753 Y0.725 I0. J-0.1047
    N7345 G1 Y0.5297
    N7350 X-1.7079
    N7355 Y1.37
    N7360 Y1.5543
    N7365 G3 X-1.7189 Y1.5652 I-0.0109 J0.
    N7370 G1 X-1.7298
    N7375 G18 G3 X-1.7407 Z1.3809 I0. K0.0109
    N7380 G0 Z2.1
    N7385 M5
    N7390 G53 G0 Z0.
    (2D .0625 Finish Top)
    N7400 M9
    N7405 M1
    N7410 T4 M6
    N7415 S6000 M3
    N7420 G54
    N7425 M11
    N7430 G0 A0.
    N7435 M10
    N7440 M8
    N7445 G17
    N7450 G0 X-3.855 Y1.5371
    N7455 G43 Z2.1 H4
    N7460 T2
    N7465 G0 Z1.7
    N7470 G1 Z1.5394 F12.
    N7475 Z1.4362 F4.
    N7480 G18 G3 X-3.8612 Z1.43 I-0.0063 K0.
    N7485 G1 X-3.8675 F12.
    N7490 G17 G3 X-3.8737 Y1.5309 I0. J-0.0062
    N7495 G1 Y0.835
    N7500 Y0.2762
    N7505 X-3.0512
    N7510 Y1.5308
    N7515 G3 X-3.0575 Y1.537 I-0.0063 J0.
    N7520 G1 X-3.0637
    N7525 G18 G3 X-3.07 Z1.4362 I0. K0.0063
    N7530 G0 Z1.7
    N7535 Y-1.5371
    N7540 G1 Z1.5394 F4.
    N7545 Z1.4362
    N7550 G2 X-3.0638 Z1.43 I0.0062 K0.
    N7555 G1 X-3.0575 F12.
    N7560 G17 G3 X-3.0512 Y-1.5309 I0. J0.0062
    N7565 G1 Y-0.775
    N7570 Y-0.2763
    N7575 X-3.8737
    N7580 Y-1.5309
    N7585 G3 X-3.8675 Y-1.5371 I0.0063 J0.
    N7590 G1 X-3.8613
    N7595 G18 G2 X-3.855 Z1.4362 I0. K0.0063
    N7600 G0 Z2.1
    N7605 X-1.7032
    N7610 Z1.7
    N7615 G1 Z1.5394 F12.
    N7620 Z1.3762 F4.
    N7625 G2 X-1.697 Z1.37 I0.0062 K0.
    N7630 G1 X-1.6907 F12.
    N7635 G17 G3 X-1.6845 Y-1.5309 I0. J0.0062
    N7640 G1 Y-0.5062
    N7645 X-2.7987
    N7650 Y-0.725
    N7655 G2 X-2.88 Y-0.8062 I-0.0813 J0.
    N7660 G1 X-2.9987
    N7665 Y-0.835
    N7670 G2 X-3.03 Y-0.8662 I-0.0312 J0.
    N7675 G1 X-3.8987
    N7680 Y-1.37
    N7685 Y-1.5309
    N7690 G3 X-3.8925 Y-1.5371 I0.0063 J0.
    N7695 G1 X-3.8862
    N7700 G18 G2 X-3.88 Z1.3762 I0. K0.0062
    N7705 G0 Z1.7
    N7710 Y1.5371
    N7715 G1 Z1.5394 F4.
    N7720 Z1.3762
    N7725 G3 X-3.8862 Z1.37 I-0.0062 K0.
    N7730 G1 X-3.8925 F12.
    N7735 G17 G3 X-3.8987 Y1.5309 I0. J-0.0062
    N7740 G1 Y0.8663
    N7745 X-3.03
    N7750 G2 X-2.9987 Y0.835 I0. J-0.0312
    N7755 G1 Y0.8063
    N7760 X-2.88
    N7765 G2 X-2.7987 Y0.725 I0. J-0.0812
    N7770 G1 Y0.5063
    N7775 X-1.6845
    N7780 Y1.37
    N7785 Y1.5309
    N7790 G3 X-1.6907 Y1.5371 I-0.0063 J0.
    N7795 G1 X-1.697
    N7800 G18 G3 X-1.7032 Z1.3762 I0. K0.0062
    N7805 G0 Z2.1
    N7810 G53 G0 Z0.
    N7820 M11
    N7825 G0 A270.
    N7830 M10
    N7835 G17
    N7840 G0 X-3.855 Y1.5371
    N7845 G43 Z2.1 H4
    N7850 G0 Z1.7
    N7855 G1 Z1.5394 F12.
    N7860 Z1.4362 F4.
    N7865 G18 G3 X-3.8612 Z1.43 I-0.0063 K0.
    N7870 G1 X-3.8675 F12.
    N7875 G17 G3 X-3.8737 Y1.5309 I0. J-0.0062
    N7880 G1 Y0.835
    N7885 Y0.2762
    N7890 X-3.0512
    N7895 Y1.5308
    N7900 G3 X-3.0575 Y1.537 I-0.0063 J0.
    N7905 G1 X-3.0637
    N7910 G18 G3 X-3.07 Z1.4362 I0. K0.0063
    N7915 G0 Z1.7
    N7920 Y-1.5371
    N7925 G1 Z1.5394 F4.
    N7930 Z1.4362
    N7935 G2 X-3.0638 Z1.43 I0.0062 K0.
    N7940 G1 X-3.0575 F12.
    N7945 G17 G3 X-3.0512 Y-1.5308 I0. J0.0062
    N7950 G1 Y-0.775
    N7955 Y-0.2763
    N7960 X-3.8737
    N7965 Y-1.5308
    N7970 G3 X-3.8675 Y-1.5371 I0.0063 J0.
    N7975 G1 X-3.8613
    N7980 G18 G2 X-3.855 Z1.4362 I0. K0.0063
    N7985 G0 Z2.1
    N7990 X-1.7032
    N7995 Z1.7
    N8000 G1 Z1.5394 F12.
    N8005 Z1.3762 F4.
    N8010 G2 X-1.697 Z1.37 I0.0062 K0.
    N8015 G1 X-1.6907 F12.
    N8020 G17 G3 X-1.6845 Y-1.5308 I0. J0.0062
    N8025 G1 Y-0.5062
    N8030 X-2.7987
    N8035 Y-0.725
    N8040 G2 X-2.88 Y-0.8062 I-0.0813 J0.
    N8045 G1 X-2.9987
    N8050 Y-0.835
    N8055 G2 X-3.03 Y-0.8662 I-0.0312 J0.
    N8060 G1 X-3.8987
    N8065 Y-1.37
    N8070 Y-1.5308
    N8075 G3 X-3.8925 Y-1.5371 I0.0063 J0.
    N8080 G1 X-3.8862
    N8085 G18 G2 X-3.88 Z1.3762 I0. K0.0062
    N8090 G0 Z1.7
    N8095 Y1.5371
    N8100 G1 Z1.5394 F4.
    N8105 Z1.3762
    N8110 G3 X-3.8862 Z1.37 I-0.0062 K0.
    N8115 G1 X-3.8925 F12.
    N8120 G17 G3 X-3.8987 Y1.5309 I0. J-0.0062
    N8125 G1 Y0.8663
    N8130 X-3.03
    N8135 G2 X-2.9987 Y0.835 I0. J-0.0312
    N8140 G1 Y0.8063
    N8145 X-2.88
    N8150 G2 X-2.7987 Y0.725 I0. J-0.0812
    N8155 G1 Y0.5063
    N8160 X-1.6845
    N8165 Y1.37
    N8170 Y1.5309
    N8175 G3 X-1.6907 Y1.5371 I-0.0063 J0.
    N8180 G1 X-1.697
    N8185 G18 G3 X-1.7032 Z1.3762 I0. K0.0062
    N8190 G0 Z2.1
    N8195 G53 G0 Z0.
    N8205 M11
    N8210 G0 A180.
    N8215 M10
    N8220 G17
    N8225 G0 X-3.855 Y1.5371
    N8230 G43 Z2.1 H4
    N8235 G0 Z1.7
    N8240 G1 Z1.5394 F12.
    N8245 Z1.4362 F4.
    N8250 G18 G3 X-3.8612 Z1.43 I-0.0063 K0.
    N8255 G1 X-3.8675 F12.
    N8260 G17 G3 X-3.8737 Y1.5309 I0. J-0.0062
    N8265 G1 Y0.835
    N8270 Y0.2762
    N8275 X-3.0512
    N8280 Y1.5308
    N8285 G3 X-3.0575 Y1.537 I-0.0063 J0.
    N8290 G1 X-3.0637
    N8295 G18 G3 X-3.07 Z1.4362 I0. K0.0063
    N8300 G0 Z1.7
    N8305 Y-1.5371
    N8310 G1 Z1.5394 F4.
    N8315 Z1.4362
    N8320 G2 X-3.0638 Z1.43 I0.0062 K0.
    N8325 G1 X-3.0575 F12.
    N8330 G17 G3 X-3.0512 Y-1.5309 I0. J0.0062
    N8335 G1 Y-0.775
    N8340 Y-0.2763
    N8345 X-3.8737
    N8350 Y-1.5309
    N8355 G3 X-3.8675 Y-1.5371 I0.0063 J0.
    N8360 G1 X-3.8613
    N8365 G18 G2 X-3.855 Z1.4362 I0. K0.0063
    N8370 G0 Z2.1
    N8375 X-1.7032
    N8380 Z1.7
    N8385 G1 Z1.5394 F12.
    N8390 Z1.3762 F4.
    N8395 G2 X-1.697 Z1.37 I0.0062 K0.
    N8400 G1 X-1.6907 F12.
    N8405 G17 G3 X-1.6845 Y-1.5309 I0. J0.0062
    N8410 G1 Y-0.5062
    N8415 X-2.7987
    N8420 Y-0.725
    N8425 G2 X-2.88 Y-0.8062 I-0.0813 J0.
    N8430 G1 X-2.9987
    N8435 Y-0.835
    N8440 G2 X-3.03 Y-0.8662 I-0.0312 J0.
    N8445 G1 X-3.8987
    N8450 Y-1.37
    N8455 Y-1.5309
    N8460 G3 X-3.8925 Y-1.5371 I0.0063 J0.
    N8465 G1 X-3.8862
    N8470 G18 G2 X-3.88 Z1.3762 I0. K0.0062
    N8475 G0 Z1.7
    N8480 Y1.5371
    N8485 G1 Z1.5394 F4.
    N8490 Z1.3762
    N8495 G3 X-3.8862 Z1.37 I-0.0062 K0.
    N8500 G1 X-3.8925 F12.
    N8505 G17 G3 X-3.8987 Y1.5309 I0. J-0.0062
    N8510 G1 Y0.8663
    N8515 X-3.03
    N8520 G2 X-2.9987 Y0.835 I0. J-0.0312
    N8525 G1 Y0.8063
    N8530 X-2.88
    N8535 G2 X-2.7987 Y0.725 I0. J-0.0812
    N8540 G1 Y0.5063
    N8545 X-1.6845
    N8550 Y1.37
    N8555 Y1.5309
    N8560 G3 X-1.6907 Y1.5371 I-0.0063 J0.
    N8565 G1 X-1.697
    N8570 G18 G3 X-1.7032 Z1.3762 I0. K0.0062
    N8575 G0 Z2.1
    N8580 G53 G0 Z0.
    N8590 M11
    N8595 G0 A90.
    N8600 M10
    N8605 G17
    N8610 G0 X-3.855 Y1.5371
    N8615 G43 Z2.1 H4
    N8620 G0 Z1.7
    N8625 G1 Z1.5394 F12.
    N8630 Z1.4362 F4.
    N8635 G18 G3 X-3.8612 Z1.43 I-0.0063 K0.
    N8640 G1 X-3.8675 F12.
    N8645 G17 G3 X-3.8737 Y1.5308 I0. J-0.0062
    N8650 G1 Y0.835
    N8655 Y0.2762
    N8660 X-3.0512
    N8665 Y1.5308
    N8670 G3 X-3.0575 Y1.537 I-0.0063 J0.
    N8675 G1 X-3.0637
    N8680 G18 G3 X-3.07 Z1.4362 I0. K0.0063
    N8685 G0 Z1.7
    N8690 Y-1.5371
    N8695 G1 Z1.5394 F4.
    N8700 Z1.4362
    N8705 G2 X-3.0638 Z1.43 I0.0062 K0.
    N8710 G1 X-3.0575 F12.
    N8715 G17 G3 X-3.0512 Y-1.5309 I0. J0.0062
    N8720 G1 Y-0.775
    N8725 Y-0.2763
    N8730 X-3.8737
    N8735 Y-1.5309
    N8740 G3 X-3.8675 Y-1.5371 I0.0063 J0.
    N8745 G1 X-3.8613
    N8750 G18 G2 X-3.855 Z1.4362 I0. K0.0063
    N8755 G0 Z2.1
    N8760 X-1.7032
    N8765 Z1.7
    N8770 G1 Z1.5394 F12.
    N8775 Z1.3762 F4.
    N8780 G2 X-1.697 Z1.37 I0.0062 K0.
    N8785 G1 X-1.6907 F12.
    N8790 G17 G3 X-1.6845 Y-1.5309 I0. J0.0062
    N8795 G1 Y-0.5062
    N8800 X-2.7987
    N8805 Y-0.725
    N8810 G2 X-2.88 Y-0.8062 I-0.0813 J0.
    N8815 G1 X-2.9987
    N8820 Y-0.835
    N8825 G2 X-3.03 Y-0.8662 I-0.0312 J0.
    N8830 G1 X-3.8987
    N8835 Y-1.37
    N8840 Y-1.5309
    N8845 G3 X-3.8925 Y-1.5371 I0.0063 J0.
    N8850 G1 X-3.8862
    N8855 G18 G2 X-3.88 Z1.3762 I0. K0.0062
    N8860 G0 Z1.7
    N8865 Y1.5371
    N8870 G1 Z1.5394 F4.
    N8875 Z1.3762
    N8880 G3 X-3.8862 Z1.37 I-0.0062 K0.
    N8885 G1 X-3.8925 F12.
    N8890 G17 G3 X-3.8987 Y1.5308 I0. J-0.0062
    N8895 G1 Y0.8663
    N8900 X-3.03
    N8905 G2 X-2.9987 Y0.835 I0. J-0.0312
    N8910 G1 Y0.8063
    N8915 X-2.88
    N8920 G2 X-2.7987 Y0.725 I0. J-0.0812
    N8925 G1 Y0.5063
    N8930 X-1.6845
    N8935 Y1.37
    N8940 Y1.5308
    N8945 G3 X-1.6907 Y1.5371 I-0.0063 J0.
    N8950 G1 X-1.697
    N8955 G18 G3 X-1.7032 Z1.3762 I0. K0.0062
    N8960 G0 Z2.1
    N8965 M5
    N8970 G53 G0 Z0.
    (Drill Clamp Holes)
    N8980 M9
    N8985 M1
    N8990 T2 M6
    N8995 S5700 M3
    N9000 G54
    N9005 M11
    N9010 G0 A0.
    N9015 M10
    N9020 M8
    N9025 G17
    N9030 G0 X-3.4625 Y-0.605
    N9035 G43 Z2.1 H2
    N9040 T9
    N9050 G0 Z1.7
    N9055 Z1.63
    N9060 Z1.51
    N9065 G1 Z1.3797 F29.
    N9070 G0 Z1.3838
    N9075 G1 Z1.3295 F29.
    N9080 G0 Z1.3335
    N9085 G1 Z1.2792 F29.
    N9090 G0 Z1.2833
    N9095 G1 Z1.229 F29.
    N9100 G0 Z1.233
    N9105 G1 Z1.1787 F29.
    N9110 G0 Z1.1828
    N9115 G1 Z1.1285 F29.
    N9120 G0 Z1.1325
    N9125 G1 Z1.0782 F29.
    N9130 G0 Z1.0823
    N9135 G1 Z1.028 F29.
    N9140 G0 Z1.032
    N9145 G1 Z0.9777 F29.
    N9150 G0 Z0.9818
    N9155 G1 Z0.9275 F29.
    N9160 G0 Z0.9315
    N9165 G1 Z0.8772 F29.
    N9170 G0 Z0.8813
    N9175 G1 Z0.827 F29.
    N9180 G0 Z1.7
    N9185 Z0.907
    N9190 G1 Z0.7767 F29.
    N9195 G0 Z0.7808
    N9200 G1 Z0.7265 F29.
    N9205 G0 Z0.7305
    N9210 G1 Z0.7 F29.
    N9215 G0 Z1.7
    N9225 Y0.605
    N9230 Z1.63
    N9235 Z1.51
    N9240 G1 Z1.3797 F29.
    N9245 G0 Z1.3838
    N9250 G1 Z1.3295 F29.
    N9255 G0 Z1.3335
    N9260 G1 Z1.2792 F29.
    N9265 G0 Z1.2833
    N9270 G1 Z1.229 F29.
    N9275 G0 Z1.233
    N9280 G1 Z1.1787 F29.
    N9285 G0 Z1.1828
    N9290 G1 Z1.1285 F29.
    N9295 G0 Z1.1325
    N9300 G1 Z1.0782 F29.
    N9305 G0 Z1.0823
    N9310 G1 Z1.028 F29.
    N9315 G0 Z1.032
    N9320 G1 Z0.9777 F29.
    N9325 G0 Z0.9818
    N9330 G1 Z0.9275 F29.
    N9335 G0 Z0.9315
    N9340 G1 Z0.8772 F29.
    N9345 G0 Z0.8813
    N9350 G1 Z0.827 F29.
    N9355 G0 Z1.7
    N9360 Z0.907
    N9365 G1 Z0.7767 F29.
    N9370 G0 Z0.7808
    N9375 G1 Z0.7265 F29.
    N9380 G0 Z0.7305
    N9385 G1 Z0.7 F29.
    N9390 G0 Z1.7
    N9395 Z2.1
    N9400 G53 G0 Z0.
    (Drill Clamp Holes)
    N9410 M11
    N9415 G0 A270.
    N9420 M10
    N9430 G0 X-3.4625 Y-0.605
    N9435 G43 Z2.1 H2
    N9445 G0 Z1.7
    N9450 Z1.63
    N9455 Z1.51
    N9460 G1 Z1.3797 F29.
    N9465 G0 Z1.3838
    N9470 G1 Z1.3295 F29.
    N9475 G0 Z1.3335
    N9480 G1 Z1.2792 F29.
    N9485 G0 Z1.2833
    N9490 G1 Z1.229 F29.
    N9495 G0 Z1.233
    N9500 G1 Z1.1787 F29.
    N9505 G0 Z1.1828
    N9510 G1 Z1.1285 F29.
    N9515 G0 Z1.1325
    N9520 G1 Z1.0782 F29.
    N9525 G0 Z1.0823
    N9530 G1 Z1.028 F29.
    N9535 G0 Z1.032
    N9540 G1 Z0.9777 F29.
    N9545 G0 Z0.9818
    N9550 G1 Z0.9275 F29.
    N9555 G0 Z0.9315
    N9560 G1 Z0.8772 F29.
    N9565 G0 Z0.8813
    N9570 G1 Z0.827 F29.
    N9575 G0 Z1.7
    N9580 Z0.907
    N9585 G1 Z0.7767 F29.
    N9590 G0 Z0.7808
    N9595 G1 Z0.7265 F29.
    N9600 G0 Z0.7305
    N9605 G1 Z0.7 F29.
    N9610 G0 Z1.7
    N9620 Y0.605
    N9625 Z1.63
    N9630 Z1.51
    N9635 G1 Z1.3797 F29.
    N9640 G0 Z1.3838
    N9645 G1 Z1.3295 F29.
    N9650 G0 Z1.3335
    N9655 G1 Z1.2792 F29.
    N9660 G0 Z1.2833
    N9665 G1 Z1.229 F29.
    N9670 G0 Z1.233
    N9675 G1 Z1.1787 F29.
    N9680 G0 Z1.1828
    N9685 G1 Z1.1285 F29.
    N9690 G0 Z1.1325
    N9695 G1 Z1.0782 F29.
    N9700 G0 Z1.0823
    N9705 G1 Z1.028 F29.
    N9710 G0 Z1.032
    N9715 G1 Z0.9777 F29.
    N9720 G0 Z0.9818
    N9725 G1 Z0.9275 F29.
    N9730 G0 Z0.9315
    N9735 G1 Z0.8772 F29.
    N9740 G0 Z0.8813
    N9745 G1 Z0.827 F29.
    N9750 G0 Z1.7
    N9755 Z0.907
    N9760 G1 Z0.7767 F29.
    N9765 G0 Z0.7808
    N9770 G1 Z0.7265 F29.
    N9775 G0 Z0.7305
    N9780 G1 Z0.7 F29.
    N9785 G0 Z1.7
    N9790 Z2.1
    N9795 G53 G0 Z0.
    (Drill Clamp Holes)
    N9805 M11
    N9810 G0 A180.
    N9815 M10
    N9825 G0 X-3.4625 Y-0.605
    N9830 G43 Z2.1 H2
    N9840 G0 Z1.7
    N9845 Z1.63
    N9850 Z1.51
    N9855 G1 Z1.3797 F29.
    N9860 G0 Z1.3838
    N9865 G1 Z1.3295 F29.
    N9870 G0 Z1.3335
    N9875 G1 Z1.2792 F29.
    N9880 G0 Z1.2833
    N9885 G1 Z1.229 F29.
    N9890 G0 Z1.233
    N9895 G1 Z1.1787 F29.
    N9900 G0 Z1.1828
    N9905 G1 Z1.1285 F29.
    N9910 G0 Z1.1325
    N9915 G1 Z1.0782 F29.
    N9920 G0 Z1.0823
    N9925 G1 Z1.028 F29.
    N9930 G0 Z1.032
    N9935 G1 Z0.9777 F29.
    N9940 G0 Z0.9818
    N9945 G1 Z0.9275 F29.
    N9950 G0 Z0.9315
    N9955 G1 Z0.8772 F29.
    N9960 G0 Z0.8813
    N9965 G1 Z0.827 F29.
    N9970 G0 Z1.7
    N9975 Z0.907
    N9980 G1 Z0.7767 F29.
    N9985 G0 Z0.7808
    N9990 G1 Z0.7265 F29.
    N9995 G0 Z0.7305
    N10000 G1 Z0.7 F29.
    N10005 G0 Z1.7
    N10015 Y0.605
    N10020 Z1.63
    N10025 Z1.51
    N10030 G1 Z1.3797 F29.
    N10035 G0 Z1.3838
    N10040 G1 Z1.3295 F29.
    N10045 G0 Z1.3335
    N10050 G1 Z1.2792 F29.
    N10055 G0 Z1.2833
    N10060 G1 Z1.229 F29.
    N10065 G0 Z1.233
    N10070 G1 Z1.1787 F29.
    N10075 G0 Z1.1828
    N10080 G1 Z1.1285 F29.
    N10085 G0 Z1.1325
    N10090 G1 Z1.0782 F29.
    N10095 G0 Z1.0823
    N10100 G1 Z1.028 F29.
    N10105 G0 Z1.032
    N10110 G1 Z0.9777 F29.
    N10115 G0 Z0.9818
    N10120 G1 Z0.9275 F29.
    N10125 G0 Z0.9315
    N10130 G1 Z0.8772 F29.
    N10135 G0 Z0.8813
    N10140 G1 Z0.827 F29.
    N10145 G0 Z1.7
    N10150 Z0.907
    N10155 G1 Z0.7767 F29.
    N10160 G0 Z0.7808
    N10165 G1 Z0.7265 F29.
    N10170 G0 Z0.7305
    N10175 G1 Z0.7 F29.
    N10180 G0 Z1.7
    N10185 Z2.1
    N10190 G53 G0 Z0.
    (Drill Clamp Holes)
    N10200 M11
    N10205 G0 A90.
    N10210 M10
    N10220 G0 X-3.4625 Y-0.605
    N10225 G43 Z2.1 H2
    N10235 G0 Z1.7
    N10240 Z1.63
    N10245 Z1.51
    N10250 G1 Z1.3797 F29.
    N10255 G0 Z1.3838
    N10260 G1 Z1.3295 F29.
    N10265 G0 Z1.3335
    N10270 G1 Z1.2792 F29.
    N10275 G0 Z1.2833
    N10280 G1 Z1.229 F29.
    N10285 G0 Z1.233
    N10290 G1 Z1.1787 F29.
    N10295 G0 Z1.1828
    N10300 G1 Z1.1285 F29.
    N10305 G0 Z1.1325
    N10310 G1 Z1.0782 F29.
    N10315 G0 Z1.0823
    N10320 G1 Z1.028 F29.
    N10325 G0 Z1.032
    N10330 G1 Z0.9777 F29.
    N10335 G0 Z0.9818
    N10340 G1 Z0.9275 F29.
    N10345 G0 Z0.9315
    N10350 G1 Z0.8772 F29.
    N10355 G0 Z0.8813
    N10360 G1 Z0.827 F29.
    N10365 G0 Z1.7
    N10370 Z0.907
    N10375 G1 Z0.7767 F29.
    N10380 G0 Z0.7808
    N10385 G1 Z0.7265 F29.
    N10390 G0 Z0.7305
    N10395 G1 Z0.7 F29.
    N10400 G0 Z1.7
    N10410 Y0.605
    N10415 Z1.63
    N10420 Z1.51
    N10425 G1 Z1.3797 F29.
    N10430 G0 Z1.3838
    N10435 G1 Z1.3295 F29.
    N10440 G0 Z1.3335
    N10445 G1 Z1.2792 F29.
    N10450 G0 Z1.2833
    N10455 G1 Z1.229 F29.
    N10460 G0 Z1.233
    N10465 G1 Z1.1787 F29.
    N10470 G0 Z1.1828
    N10475 G1 Z1.1285 F29.
    N10480 G0 Z1.1325
    N10485 G1 Z1.0782 F29.
    N10490 G0 Z1.0823
    N10495 G1 Z1.028 F29.
    N10500 G0 Z1.032
    N10505 G1 Z0.9777 F29.
    N10510 G0 Z0.9818
    N10515 G1 Z0.9275 F29.
    N10520 G0 Z0.9315
    N10525 G1 Z0.8772 F29.
    N10530 G0 Z0.8813
    N10535 G1 Z0.827 F29.
    N10540 G0 Z1.7
    N10545 Z0.907
    N10550 G1 Z0.7767 F29.
    N10555 G0 Z0.7808
    N10560 G1 Z0.7265 F29.
    N10565 G0 Z0.7305
    N10570 G1 Z0.7 F29.
    N10575 G0 Z1.7
    N10580 Z2.1
    N10585 M5
    N10590 G53 G0 Z0.
    (Drill6)
    N10600 M9
    N10605 M1
    N10610 T9 M6
    (.173 Drill)
    N10615 S5000 M3
    N10620 G54
    N10625 M11
    N10630 G0 A0.
    N10635 M10
    N10640 M8
    N10650 G0 X-1.3474 Y-0.3728
    N10655 G43 Z2.1 H9
    N10660 T7
    N10670 G0 Z1.7
    N10675 Z1.65
    N10680 Z1.53
    N10685 G1 Z1.4068 F39.37
    N10690 G0 Z1.4108
    N10695 G1 Z1.3635 F39.37
    N10700 G0 Z1.3675
    N10705 G1 Z1.3203 F39.37
    N10710 G0 Z1.3243
    N10715 G1 Z1.277 F39.37
    N10720 G0 Z1.281
    N10725 G1 Z1.2338 F39.37
    N10730 G0 Z1.2378
    N10735 G1 Z1.1905 F39.37
    N10740 G0 Z1.1945
    N10745 G1 Z1.1473 F39.37
    N10750 G0 Z1.1513
    N10755 G1 Z1.104 F39.37
    N10760 G0 Z1.108
    N10765 G1 Z1.0608 F39.37
    N10770 G0 Z1.0648
    N10775 G1 Z1.0175 F39.37
    N10780 G0 Z1.0215
    N10785 G1 Z0.9743 F39.37
    N10790 G0 Z0.9783
    N10795 G1 Z0.931 F39.37
    N10800 G0 Z1.7
    N10805 Z1.011
    N10810 G1 Z0.8878 F39.37
    N10815 G0 Z0.8918
    N10820 G1 Z0.8445 F39.37
    N10825 G0 Z0.8485
    N10830 G1 Z0.8013 F39.37
    N10835 G0 Z0.8053
    N10840 G1 Z0.758 F39.37
    N10845 G0 Z0.762
    N10850 G1 Z0.7148 F39.37
    N10855 G0 Z0.7188
    N10860 G1 Z0.7 F39.37
    N10865 G0 Z1.7
    N10870 Y0.3728
    N10875 Z1.65
    N10880 Z1.53
    N10885 G1 Z1.4068 F39.37
    N10890 G0 Z1.4108
    N10895 G1 Z1.3635 F39.37
    N10900 G0 Z1.3675
    N10905 G1 Z1.3203 F39.37
    N10910 G0 Z1.3243
    N10915 G1 Z1.277 F39.37
    N10920 G0 Z1.281
    N10925 G1 Z1.2338 F39.37
    N10930 G0 Z1.2378
    N10935 G1 Z1.1905 F39.37
    N10940 G0 Z1.1945
    N10945 G1 Z1.1473 F39.37
    N10950 G0 Z1.1513
    N10955 G1 Z1.104 F39.37
    N10960 G0 Z1.108
    N10965 G1 Z1.0608 F39.37
    N10970 G0 Z1.0648
    N10975 G1 Z1.0175 F39.37
    N10980 G0 Z1.0215
    N10985 G1 Z0.9743 F39.37
    N10990 G0 Z0.9783
    N10995 G1 Z0.931 F39.37
    N11000 G0 Z1.7
    N11005 Z1.011
    N11010 G1 Z0.8878 F39.37
    N11015 G0 Z0.8918
    N11020 G1 Z0.8445 F39.37
    N11025 G0 Z0.8485
    N11030 G1 Z0.8013 F39.37
    N11035 G0 Z0.8053
    N11040 G1 Z0.758 F39.37
    N11045 G0 Z0.762
    N11050 G1 Z0.7148 F39.37
    N11055 G0 Z0.7188
    N11060 G1 Z0.7 F39.37
    N11065 G0 Z1.7
    N11070 Z2.1
    (Drill7)
    N11075 G1 X-0.815 Y0. F500.
    N11080 G0 Z2.1
    N11090 Z1.7
    N11095 G98 G81 X-0.815 Y0. Z1.3742 R1.64 F39.37
    N11100 G80
    N11105 G0 Z2.1
    N11110 G53 G0 Z0.
    (Drill6)
    N11120 M11
    N11125 G0 A270.
    N11130 M10
    N11140 G0 X-1.3474 Y-0.3728
    N11145 G43 Z2.1 H9
    N11155 G0 Z1.7
    N11160 Z1.65
    N11165 Z1.53
    N11170 G1 Z1.4068 F39.37
    N11175 G0 Z1.4108
    N11180 G1 Z1.3635 F39.37
    N11185 G0 Z1.3675
    N11190 G1 Z1.3203 F39.37
    N11195 G0 Z1.3243
    N11200 G1 Z1.277 F39.37
    N11205 G0 Z1.281
    N11210 G1 Z1.2338 F39.37
    N11215 G0 Z1.2378
    N11220 G1 Z1.1905 F39.37
    N11225 G0 Z1.1945
    N11230 G1 Z1.1473 F39.37
    N11235 G0 Z1.1513
    N11240 G1 Z1.104 F39.37
    N11245 G0 Z1.108
    N11250 G1 Z1.0608 F39.37
    N11255 G0 Z1.0648
    N11260 G1 Z1.0175 F39.37
    N11265 G0 Z1.0215
    N11270 G1 Z0.9743 F39.37
    N11275 G0 Z0.9783
    N11280 G1 Z0.931 F39.37
    N11285 G0 Z1.7
    N11290 Z1.011
    N11295 G1 Z0.8878 F39.37
    N11300 G0 Z0.8918
    N11305 G1 Z0.8445 F39.37
    N11310 G0 Z0.8485
    N11315 G1 Z0.8013 F39.37
    N11320 G0 Z0.8053
    N11325 G1 Z0.758 F39.37
    N11330 G0 Z0.762
    N11335 G1 Z0.7148 F39.37
    N11340 G0 Z0.7188
    N11345 G1 Z0.7 F39.37
    N11350 G0 Z1.7
    N11355 Y0.3728
    N11360 Z1.65
    N11365 Z1.53
    N11370 G1 Z1.4068 F39.37
    N11375 G0 Z1.4108
    N11380 G1 Z1.3635 F39.37
    N11385 G0 Z1.3675
    N11390 G1 Z1.3203 F39.37
    N11395 G0 Z1.3243
    N11400 G1 Z1.277 F39.37
    N11405 G0 Z1.281
    N11410 G1 Z1.2338 F39.37
    N11415 G0 Z1.2378
    N11420 G1 Z1.1905 F39.37
    N11425 G0 Z1.1945
    N11430 G1 Z1.1473 F39.37
    N11435 G0 Z1.1513
    N11440 G1 Z1.104 F39.37
    N11445 G0 Z1.108
    N11450 G1 Z1.0608 F39.37
    N11455 G0 Z1.0648
    N11460 G1 Z1.0175 F39.37
    N11465 G0 Z1.0215
    N11470 G1 Z0.9743 F39.37
    N11475 G0 Z0.9783
    N11480 G1 Z0.931 F39.37
    N11485 G0 Z1.7
    N11490 Z1.011
    N11495 G1 Z0.8878 F39.37
    N11500 G0 Z0.8918
    N11505 G1 Z0.8445 F39.37
    N11510 G0 Z0.8485
    N11515 G1 Z0.8013 F39.37
    N11520 G0 Z0.8053
    N11525 G1 Z0.758 F39.37
    N11530 G0 Z0.762
    N11535 G1 Z0.7148 F39.37
    N11540 G0 Z0.7188
    N11545 G1 Z0.7 F39.37
    N11550 G0 Z1.7
    N11555 Z2.1
    (Drill7)
    N11560 G1 X-0.815 Y0. F500.
    N11565 G0 Z2.1
    N11575 Z1.7
    N11580 G98 G81 X-0.815 Y0. Z1.3742 R1.64 F39.37
    N11585 G80
    N11590 G0 Z2.1
    N11595 G53 G0 Z0.
    (Drill6)
    N11605 M11
    N11610 G0 A180.
    N11615 M10
    N11625 G0 X-1.3474 Y-0.3728
    N11630 G43 Z2.1 H9
    N11640 G0 Z1.7
    N11645 Z1.65
    N11650 Z1.53
    N11655 G1 Z1.4067 F39.37
    N11660 G0 Z1.4107
    N11665 G1 Z1.3635 F39.37
    N11670 G0 Z1.3675
    N11675 G1 Z1.3202 F39.37
    N11680 G0 Z1.3242
    N11685 G1 Z1.277 F39.37
    N11690 G0 Z1.281
    N11695 G1 Z1.2337 F39.37
    N11700 G0 Z1.2377
    N11705 G1 Z1.1905 F39.37
    N11710 G0 Z1.1945
    N11715 G1 Z1.1472 F39.37
    N11720 G0 Z1.1512
    N11725 G1 Z1.104 F39.37
    N11730 G0 Z1.108
    N11735 G1 Z1.0607 F39.37
    N11740 G0 Z1.0647
    N11745 G1 Z1.0175 F39.37
    N11750 G0 Z1.0215
    N11755 G1 Z0.9742 F39.37
    N11760 G0 Z0.9782
    N11765 G1 Z0.931 F39.37
    N11770 G0 Z1.7
    N11775 Z1.011
    N11780 G1 Z0.8877 F39.37
    N11785 G0 Z0.8917
    N11790 G1 Z0.8445 F39.37
    N11795 G0 Z0.8485
    N11800 G1 Z0.8012 F39.37
    N11805 G0 Z0.8052
    N11810 G1 Z0.758 F39.37
    N11815 G0 Z0.762
    N11820 G1 Z0.7147 F39.37
    N11825 G0 Z0.7187
    N11830 G1 Z0.7 F39.37
    N11835 G0 Z1.7
    N11840 Y0.3728
    N11845 Z1.65
    N11850 Z1.53
    N11855 G1 Z1.4067 F39.37
    N11860 G0 Z1.4107
    N11865 G1 Z1.3635 F39.37
    N11870 G0 Z1.3675
    N11875 G1 Z1.3202 F39.37
    N11880 G0 Z1.3242
    N11885 G1 Z1.277 F39.37
    N11890 G0 Z1.281
    N11895 G1 Z1.2337 F39.37
    N11900 G0 Z1.2377
    N11905 G1 Z1.1905 F39.37
    N11910 G0 Z1.1945
    N11915 G1 Z1.1472 F39.37
    N11920 G0 Z1.1512
    N11925 G1 Z1.104 F39.37
    N11930 G0 Z1.108
    N11935 G1 Z1.0607 F39.37
    N11940 G0 Z1.0647
    N11945 G1 Z1.0175 F39.37
    N11950 G0 Z1.0215
    N11955 G1 Z0.9742 F39.37
    N11960 G0 Z0.9782
    N11965 G1 Z0.931 F39.37
    N11970 G0 Z1.7
    N11975 Z1.011
    N11980 G1 Z0.8877 F39.37
    N11985 G0 Z0.8917
    N11990 G1 Z0.8445 F39.37
    N11995 G0 Z0.8485
    N12000 G1 Z0.8012 F39.37
    N12005 G0 Z0.8052
    N12010 G1 Z0.758 F39.37
    N12015 G0 Z0.762
    N12020 G1 Z0.7147 F39.37
    N12025 G0 Z0.7187
    N12030 G1 Z0.7 F39.37
    N12035 G0 Z1.7
    N12040 Z2.1
    (Drill7)
    N12045 G1 X-0.815 Y0. F500.
    N12050 G0 Z2.1
    N12060 Z1.7
    N12065 G98 G81 X-0.815 Y0. Z1.3742 R1.64 F39.37
    N12070 G80
    N12075 G0 Z2.1
    N12080 G53 G0 Z0.
    (Drill6)
    N12090 M11
    N12095 G0 A90.
    N12100 M10
    N12110 G0 X-1.3474 Y-0.3728
    N12115 G43 Z2.1 H9
    N12125 G0 Z1.7
    N12130 Z1.65
    N12135 Z1.53
    N12140 G1 Z1.4068 F39.37
    N12145 G0 Z1.4108
    N12150 G1 Z1.3635 F39.37
    N12155 G0 Z1.3675
    N12160 G1 Z1.3203 F39.37
    N12165 G0 Z1.3243
    N12170 G1 Z1.277 F39.37
    N12175 G0 Z1.281
    N12180 G1 Z1.2338 F39.37
    N12185 G0 Z1.2378
    N12190 G1 Z1.1905 F39.37
    N12195 G0 Z1.1945
    N12200 G1 Z1.1473 F39.37
    N12205 G0 Z1.1513
    N12210 G1 Z1.104 F39.37
    N12215 G0 Z1.108
    N12220 G1 Z1.0608 F39.37
    N12225 G0 Z1.0648
    N12230 G1 Z1.0175 F39.37
    N12235 G0 Z1.0215
    N12240 G1 Z0.9743 F39.37
    N12245 G0 Z0.9783
    N12250 G1 Z0.931 F39.37
    N12255 G0 Z1.7
    N12260 Z1.011
    N12265 G1 Z0.8878 F39.37
    N12270 G0 Z0.8918
    N12275 G1 Z0.8445 F39.37
    N12280 G0 Z0.8485
    N12285 G1 Z0.8013 F39.37
    N12290 G0 Z0.8053
    N12295 G1 Z0.758 F39.37
    N12300 G0 Z0.762
    N12305 G1 Z0.7148 F39.37
    N12310 G0 Z0.7188
    N12315 G1 Z0.7 F39.37
    N12320 G0 Z1.7
    N12325 Y0.3728
    N12330 Z1.65
    N12335 Z1.53
    N12340 G1 Z1.4068 F39.37
    N12345 G0 Z1.4108
    N12350 G1 Z1.3635 F39.37
    N12355 G0 Z1.3675
    N12360 G1 Z1.3203 F39.37
    N12365 G0 Z1.3243
    N12370 G1 Z1.277 F39.37
    N12375 G0 Z1.281
    N12380 G1 Z1.2338 F39.37
    N12385 G0 Z1.2378
    N12390 G1 Z1.1905 F39.37
    N12395 G0 Z1.1945
    N12400 G1 Z1.1473 F39.37
    N12405 G0 Z1.1513
    N12410 G1 Z1.104 F39.37
    N12415 G0 Z1.108
    N12420 G1 Z1.0608 F39.37
    N12425 G0 Z1.0648
    N12430 G1 Z1.0175 F39.37
    N12435 G0 Z1.0215
    N12440 G1 Z0.9743 F39.37
    N12445 G0 Z0.9783
    N12450 G1 Z0.931 F39.37
    N12455 G0 Z1.7
    N12460 Z1.011
    N12465 G1 Z0.8878 F39.37
    N12470 G0 Z0.8918
    N12475 G1 Z0.8445 F39.37
    N12480 G0 Z0.8485
    N12485 G1 Z0.8013 F39.37
    N12490 G0 Z0.8053
    N12495 G1 Z0.758 F39.37
    N12500 G0 Z0.762
    N12505 G1 Z0.7148 F39.37
    N12510 G0 Z0.7188
    N12515 G1 Z0.7 F39.37
    N12520 G0 Z1.7
    N12525 Z2.1
    (Drill7)
    N12530 G1 X-0.815 Y0. F500.
    N12535 G0 Z2.1
    N12545 Z1.7
    N12550 G98 G81 X-0.815 Y0. Z1.3742 R1.64 F39.37
    N12555 G80
    N12560 G0 Z2.1
    N12565 M5
    N12570 M9
    N12575 G53 G0 Z0.
    N12580 M11
    N12585 G0 A0.
    N12590 M10
    N12600 X-2.035
    N12605 G53 Y0.
    N12610 M30
    May 2016
    Default Re: Fusion 360 and 4th Axis Issue--STUMPED!!
    I was about to respond with a similar problem I had, but then I looked at your code.
    Is it just me, or is there no return to G54 after the first drill is finished and does a G53 Z0 retract move? It looks like the rest of the drilling ops are in G53 - I suspect that may be the issue...?
