It depend on a postprocessor setting. Lines in lead in are linearized. Also i do not know your operation setting. Can you share your fusion project?
Hi evryone!
When I generate toolpath size of program is really too big. Most of all g-code are the lead's in and out lines. For example:
I trying to mill big chamfer (hole with 8x45degrees), please see in atchament (geometry and toolpath). I Paste a few Lines of G-code
Did any of you try to reduce numbers of line?
LEAD'S IN:
X4.773 Y-7.029 X4.791 Y-7.016
X5.928 Y-6.052
X6.177 Y-5.834
X7.27 Y-4.397
X7.275 Y-4.389
X8.014 Y-2.802
X8.051 Y-2.717
X8.053 Y-2.71
X8.448 Y-0.905
Y0.905
X8.055 Y2.702
X7.3 Y4.346
X7.282 Y4.377
X7.225 Y4.459
X6.182 Y5.828
X5.122 Y6.736
X4.792 Y7.015
X4.774 Y7.028
X3.352 Y7.784
G3 X2.845 Y7.629 P0.375
X2.821 Y7.574 P0.375
G1 X1.629 Y4.071
X0 Y0
machining geometry:
Z-2.5
G2 X0.097 Y-0.013 P0.375
G1 X1.395 Y-0.362
G3 X1.854 Y-0.097 P0.375
X1.867 Y0 P0.375
X-0.001 Y1.868 P1.868
X-1.869 Y0 P1.868
X-0.001 Y-1.868 P1.868
X1.867 Y0 P1.868
G2 X3.689 Y3.686 P4.64
G3 X4.146 Y7.111 P2.443
X3.352 Y7.784 P2.443
G1 X3.154 Y7.889
X1.368 Y8.385
Best Regards.
Postprocessors, VBA macros, .NET programming.
www.ccsoftcz.com
Hello! Thanks for reply, I Have much work to do, so I'm guest here.
The problem is in linearized lead's in and out.
On forst photo is conturing without radius on leads on and out's and postprocesr settings
The program size: 7KB
The same part but with radius on lead's:
Size 11KB
I try to reduce programs size, Machine is old (cincinnnati Dart 500 98r. ) with small memory and really slow transfer from computer.
Best regards!
