In Autodesk CAM there is no parameter for "tool engagement angle" specifically. Instead the adaptive tool paths use the "step over" value, which is then converted internally to an engagement angle. The engagement angle can be calculated from the step over with some math.
HSM Machining > Calculating Tool Engagement Angle, Radial Depth of Cut
C|
