Andrew,
Any chance you could post the file?
I have had similar issues in Fusion that seemed arduous to work around. Other CAM software I've used over the years typically had a single command for "select chain" which always made things very simple. It either selected the whole chain, or if it stopped somewhere you knew that was the exact point of a mis-match in geometry. I have yet to find a method to do this in Fusion.
PM
