G code issue with arc ijk
Results 1 to 2 of 2
Thread: G code issue with arc ijk
    Jun 2017
    United Kingdom
    Default G code issue with arc ijk
    one i put my g code generted from fushion 360 when i have a arc mach3 throws up these erors is there a easy fix to it as im a complete newbie to g code
    r i j k i know there to do with the arc and g17 but i either want to get rid of the arc in the tool path or is there another way
    regards
    thought id edit and include this
    G1 Z-9.6 F960
    X-76.398 Y-30.614 Z-9.678
    X-76.392 Y-30.592 Z-9.753
    X-76.383 Y-30.556 Z-9.822
    X-76.371 Y-30.508 Z-9.883
    X-76.356 Y-30.449 Z-9.933
    X-76.338 Y-30.382 Z-9.97
    X-76.32 Y-30.309 Z-9.992
    X-76.3 Y-30.234 Z-10
    G17 G3 X-75.987 Y-28.056 P10.212 <<<<this line>>>
    G1 Y-27.906
    X-76.145 Y-27.113
    X-76.239 Y-26.311
    X-76.296 Y-25.504
    X-76.329 Y-24.697
    Member mactec54's Avatar
    Jan 2005
    Default Re: G code issue with arc ijk
    Quote Originally Posted by gr3g0rs View Post
    regards
    G1 Z-9.6 F960
    G1 Y-27.906
    X-76.145 Y-27.113
    X-76.239 Y-26.311
    X-76.296 Y-25.504
    X-76.329 Y-24.697
    To fix the I & J in Mach3 it's quite simple, if this is the problem, under Confg. and then General Config you will find the I & J settings
    Yes that line is not right, seems you have a post processor that needs some work
    Attached Thumbnails Attached Thumbnails G code issue with arc ijk-j-settings-png
    Mactec54
