HSMExpress - simple task
Results 1 to 4 of 4
Thread: HSMExpress - simple task
    Jul 2006
    Default HSMExpress - simple task
    I am trying to get the hang of HSMExpress. I've gone through the two 2.5d tutorials which are included, now I'm trying to apply what I've learned to a real part.
    I can't figure out how to machine the notch in the front of the part in the image. It seems like such a simple task and would only take minutes to program manually, but no matter what I try I can't get it to work properly. Unfortunately I won't have access to SolidWorks/HSMExpress over the weekend, so I'm hoping somebody can at least point me in the right direction for when I get back to work Tuesday morning. What milling strategy do I use, and what edges or faces do I select for the geometry? I need to approach from the side so I can use CDC.
    Is there a way to manually create or edit the tool paths?
    Also, is it possible to mill the angle with a ballnose in Express, or would I need Works?
    HSMExpress - simple task-part1-png
    Here is the basic finish tool path for the notch. Yes, this is what I'm stuck on! It should be so simple, but everything I try seems to only work with a closed tool path.
    HSMExpress - simple task-part2-png
    Jul 2006
    Default Re: HSMExpress - simple task
    I figured it out. 2D contouring, I just had to uncheck "Propagate along Z". It's the simple things that get you hung up!
    I still need to figure out how to cut the angle with a ball end mill. Can it be done with Express?
    Feb 2009
    Quote Originally Posted by Jester966 View Post
    It is possible by using the trace tool path and a manually created line that puts the ball mill tangent to the face to cut. Something like this:
    HSMExpress - simple task-tracepath-jpg
    Then you put that single trace operation into a linear pattern using one of the chamfer edges as the guide.
    HSMExpress - simple task-tracepattern-jpg
    C|
    May 2017
    Czech Republic
    edit: deleted, accidentally replied to solved post
