I have used my newly installed haas just fine for adaptive clearing, but trying to run contour 2d toolpaths seems to mess with it...
I have noticed this repeatable issue, my axis all stop moving, the code line doesn't progress, but the DRO still continues to count as if the axis are moving in Z.
The toolpath came out of fusion 360, and it freezes on either line 75, or won't move onto line 80, so I'm not sure what is wrong?
here is the G code excerpt, I am using the haas generic post processor, and the machine is TM1
Any advice is very welcome about where I have gone wrong
% O00006 (hole centre as g54) (T1 D=10. CR=0. - ZMIN=-5. - flat end mill) N10 G90 G94 G17 N15 G21 N20 G53 G0 Z0.
The layout/format of the program is not suitable to run on a Haas control
This line is incorrect, for any control N20 G53 G0 Z0. If you need to do this for some unknown reason, only use it like this G0Z0. a G53 does not belong in this line
Check this Feed move it may need a ( F3.9. ) a dot at the end, Feed moves normally need a dot/period at the end
With a Haas control the T1M6 command takes the tool to Z0, Z0 is Tool Change Position
Get to know your control, the Haas manual has lots of examples of how your program should look, if you are not sure about something like this, they also have some great videos that they have been doing
Is your Haas a new generation? Autodesk has two new generation processors with and without the ability to insert pic's and video but you have to enter Haas mill into the fields to bring these up.
