Need Help! HSM & Tapping
Results 1 to 4 of 4
Thread: HSM & Tapping
    Registered SoCalPlaneDoc's Avatar
    Mar 2012
    USA!
    Default HSM & Tapping
    Automated Machinery Designer - PCNC1100 Series III upgrade, Graziano Sag 12 Lathe
    Solidworks 2016 (SW Certified), HSMWorks
    Feb 2009
    Default Re: HSM & Tapping
    Quote Originally Posted by SoCalPlaneDoc View Post
    Anyone have any guidance on how to do tapping using HSMworks?
    rigid and/or tension compression?
    Not sure what your question is specifically. I do rigid tapping and it works great. It's the same as a drill operation, except you select tapping for the cycle type instead of drilling or deep drilling or whatever. Heights are set the same as drilling. Feed is determined by tap size and spindle RPM, so only spindle RPM needs to be set.
    C|
    Mar 2012
    USA!
    Quote Originally Posted by cygnus x-1 View Post
    "same as a drill operation, except you select tapping for the cycle type instead of drilling"
    C|
    That's the info I needed.. thanks...
    T/C tapping on a Tormach.
    Mar 2012
    USA!
    OK, now I'm interested in trying tapping using a multi-flute thread mill.. looks like it needs to go down to the bottom of the hole, move to the side, go one turn around the hole, then extract...
    anyone know the jazzy way of doing this in HSMworks?
HSM & Tapping
HSM & Tapping
