Any way to get simulation to actually simulate your machine's acceleration?
Results 1 to 5 of 5
Thread: Any way to get simulation to actually simulate your machine's acceleration?
    Member GJeff's Avatar
    Jan 2013
    Default Any way to get simulation to actually simulate your machine's acceleration?
    I know what my machine's accel values are, and if Fusion 360 did, it might actually be able to give me some accurate simulation times. With a lot of tight corners, I end up with 2x or more actual machining time than their best case scenario estimates. It's hard to compare which toolpaths are best if I don't know the actual times for them.
    Mar 2014
    Netherlands
    Default Re: Any way to get simulation to actually simulate your machine's acceleration?
    You can write a postprocessor to incorporate these times. Take the setup-sheet as a basis. It will take you some time though...
    Aug 2012
    Germany
    Quote Originally Posted by Arjand View Post
    the post processor is involved in the simulation in Fusion360?
    Mar 2014
    Netherlands
    Quote Originally Posted by MarcusWolschon View Post
    No, but you can influence the cycle time calculation on the setup sheet
    Verstuurd vanaf mijn SM-G955F met Tapatalk
    Aug 2012
    Germany
    Okay.
    Thanks.
